[PATCH] tester: Add support for arm/fvp_cortex_r52 BSP
Sebastian Huber
Wed Dec 16 08:16:08 UTC 2020
Update #4202.
.../rtems/testing/bsps/fvp_cortex_r52x1.ini | 38 +++++++++++++++++++
.../rtems/testing/bsps/fvp_cortex_r52x2.ini | 38 +++++++++++++++++++
.../rtems/testing/bsps/fvp_cortex_r52x4.ini | 38 +++++++++++++++++++
3 files changed, 114 insertions(+)
create mode 100644 tester/rtems/testing/bsps/fvp_cortex_r52x1.ini
create mode 100644 tester/rtems/testing/bsps/fvp_cortex_r52x2.ini
create mode 100644 tester/rtems/testing/bsps/fvp_cortex_r52x4.ini
diff --git a/tester/rtems/testing/bsps/fvp_cortex_r52x1.ini b/tester/rtems/testing/bsps/fvp_cortex_r52x1.ini
new file mode 100644
index 0000000..d1e42c6
--- /dev/null
+++ b/tester/rtems/testing/bsps/fvp_cortex_r52x1.ini
@@ -0,0 +1,38 @@
+# RTEMS Tools Project (http://www.rtems.org/)
+# Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+# This file is part of the RTEMS Tools package in 'rtems-tools'.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions are met:
+# 1. Redistributions of source code must retain the above copyright notice,
+# this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright notice,
+# this list of conditions and the following disclaimer in the documentation
+# and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
+# The arm/fvp_cortex_r52 BSP
+[fvp_cortex_r52x1]
+bsp = fvp_cortex_r52
+arch = arm
+tester = %{_rtscripts}/run.cfg
+bsp_run_cmd = FVP_BaseR_Cortex-R52x1
+bsp_run_opts = -C bp.vis.disable_visualisation=1 -a
diff --git a/tester/rtems/testing/bsps/fvp_cortex_r52x2.ini b/tester/rtems/testing/bsps/fvp_cortex_r52x2.ini
index 0000000..e8e8bf1
--- /dev/null
+++ b/tester/rtems/testing/bsps/fvp_cortex_r52x2.ini
@@ -0,0 +1,38 @@
+[fvp_cortex_r52x2]
+arch = arm
+bsp_run_cmd = FVP_BaseR_Cortex-R52x2
diff --git a/tester/rtems/testing/bsps/fvp_cortex_r52x4.ini b/tester/rtems/testing/bsps/fvp_cortex_r52x4.ini
index 0000000..5b64a8b
--- /dev/null
+++ b/tester/rtems/testing/bsps/fvp_cortex_r52x4.ini
@@ -0,0 +1,38 @@
+[fvp_cortex_r52x4]
+arch = arm
+bsp_run_cmd = FVP_BaseR_Cortex-R52x4
2.26.2
