Report on failing tests with thread stack protection and their resolution.
Utkarsh Rai
utkarsh.rai60 at gmail.com
Thu Dec 17 23:34:38 UTC 2020
On Thu, Dec 17, 2020 at 8:23 PM Sebastian Huber <
> Hello,
> On 03/12/2020 01:53, Utkarsh Rai wrote:
> > +rtems_status_code _Memory_protection_Disable( void )
> > + uint32_t access_flags;
> > + access_flags = translate_flags( RTEMS_READ_WRITE );
> > + _Thread_Iterate( set_memory_flags, &access_flags );
> > + return RTEMS_SUCCESSFUL;
> using _Thread_Iterate() for this is quite bad in terms of performance
> and it may also lead to unpredictable behaviour.
Yes, this is wrong. Simply disabling the protection for just 'the_thread'
should be sufficient in our case.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201218/4ebd95b9/attachment.html>
