MSYS2 build: header file missing
Robin Müller
robin.mueller.m at gmail.com
Fri Dec 18 11:49:18 UTC 2020
If I understand correctly, the BSPs can be installed with waf only if the
tool suite for the given architecture has been installed.
Problem is, the RSB build will fail even if a tiny component is
problematic.
I thought the tool suite itself is installed using the build commands
required by the sources (make, automake, etc).
Is it possible to also build these sources with waf?
I have tried this cross compiling on linux for windows (I used x86_64
instead of i686) because everything was working on Linux, but there are
issues with the SIS tool for sparc-rtems6..
But SIS is now also problematic on the Windows machine where I almost
managed to build everything.
Everything except SIS was built by the RSB and I copied the installed files
manually to install them and tried to build a BSP (is there actually some
script like do-install which will perform this step?)
But now some RTEMS tool is missing (rtems-bin2c):
$ ./waf configure --prefix=$RTEMS_TOOLS --rtems-bsp=sparc/erc32
Setting top to :
C:/Users/Robin/Documents/RTEMS/rtems-tools/src/rtems
Setting out to :
C:/Users/Robin/Documents/RTEMS/rtems-tools/src/rtems/build
Configure board support package (BSP) : sparc/erc32
Checking for program 'sparc-rtems6-gcc' :
C:/Users/Robin/Documents/RTEMS/rtems-tools/rtems/6/bin/sparc-rtems6-gcc.exe
Checking for program 'sparc-rtems6-g++' :
C:/Users/Robin/Documents/RTEMS/rtems-tools/rtems/6/bin/sparc-rtems6-g++.exe
Checking for program 'sparc-rtems6-ar' :
C:/Users/Robin/Documents/RTEMS/rtems-tools/rtems/6/bin/sparc-rtems6-ar.exe
Checking for program 'sparc-rtems6-ld' :
C:/Users/Robin/Documents/RTEMS/rtems-tools/rtems/6/bin/sparc-rtems6-ld.exe
Checking for program 'ar' :
Checking for program 'g++, c++' :
Checking for program 'gas, gcc' :
Checking for program 'gcc, cc' :
Checking for program 'rtems-bin2c' : not found
Could not find the program ['rtems-bin2c']
(complete log in
C:/Users/Robin/Documents/RTEMS/rtems-tools/src/rtems/build/config.log)
In general the build process on Windows seems to be more "brittle" than on
Linux, so maybe installers would be a good idea? I generally installed
cross-compilers (e.g. arm-none-eabi-gcc) on Windows
using installers (for example https://xpack.github.io/arm-none-eabi-gcc/)
and have made very good experience with that.
Kind Regards
Robin
On Fri, 18 Dec 2020 at 12:24, Sebastian Huber <
> On 18/12/2020 11:35, Chris Johns wrote:
> >> Since all parts of RTEMS build now with waf I think it is possible to
> build RTEMS applications on Windows without having to install MSYS2/MinGW.
> It should work with only a Python installation, but I haven't tested this
> yet.
> > This maybe true In theory but I have not been able to achieve it.
> What was the missing piece?
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201218/37ad1112/attachment.html>
