[PATCH v1] zynq: Add support for SDHCI devices
Kinsey Moore
kinsey.moore at oarcorp.com
Mon Dec 21 21:27:06 UTC 2020
libbsd.py | 1 +
rtemsbsd/include/bsp/nexus-devices.h | 3 +
.../include/machine/rtems-bsd-nexus-bus.h | 29 ++
rtemsbsd/sys/dev/sdhci/arasan_sdhci.c | 343 ++++++++++++++++++
4 files changed, 376 insertions(+)
create mode 100644 rtemsbsd/sys/dev/sdhci/arasan_sdhci.c
diff --git a/libbsd.py b/libbsd.py
index 909c0037..8bcb779d 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -226,6 +226,7 @@ class rtems(builder.Module):
'sys/dev/ffec/if_ffec_mcf548x.c',
'sys/dev/ffec/if_ffec_mpc8xx.c',
'sys/dev/input/touchscreen/tsc_lpc32xx.c',
+ 'sys/dev/sdhci/arasan_sdhci.c',
'sys/dev/smc/if_smc_nexus.c',
'sys/dev/stmac/if_stmac.c',
'sys/dev/tsec/if_tsec_nexus.c',
diff --git a/rtemsbsd/include/bsp/nexus-devices.h b/rtemsbsd/include/bsp/nexus-devices.h
index 51bca3aa..c3c43dc9 100644
--- a/rtemsbsd/include/bsp/nexus-devices.h
+++ b/rtemsbsd/include/bsp/nexus-devices.h
@@ -97,8 +97,11 @@ RTEMS_BSD_DRIVER_FEC;
#include <bsp/irq.h>
RTEMS_BSD_DRIVER_XILINX_ZYNQ_SLCR;
+RTEMS_BSD_DRIVER_XILINX_ZYNQ_SDHCI0;
+RTEMS_BSD_DRIVER_XILINX_ZYNQ_SDHCI1;
RTEMS_BSD_DRIVER_XILINX_ZYNQ_CGEM0(ZYNQ_IRQ_ETHERNET_0);
RTEMS_BSD_DRIVER_E1000PHY;
+RTEMS_BSD_DRIVER_MMC;
#elif defined(LIBBSP_AARCH64_XILINX_ZYNQMP_BSP_H)
diff --git a/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h b/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
index f1ca66d7..5c95d2c3 100644
--- a/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
+++ b/rtemsbsd/include/machine/rtems-bsd-nexus-bus.h
@@ -117,6 +117,35 @@ extern "C" {
&zy7_slcr_res[0])
#endif /* RTEMS_BSD_DRIVER_XILINX_ZYNQ_SLCR */
+ * Xilinx Zynq Arasan SDIO Driver.
+#if !defined(RTEMS_BSD_DRIVER_XILINX_ZYNQ_SDHCI)
+ #define RTEMS_BSD_DRIVER_XILINX_ZYNQ_SDHCI(_num, _base, _irq) \
+ static const rtems_bsd_device_resource arasan_sdhci ## _num ## _res[] = { \
+ .type = RTEMS_BSD_RES_MEMORY, \
+ .start_request = 0, \
+ .start_actual = (_base) \
+ .type = RTEMS_BSD_RES_IRQ, \
+ .start_actual = (_irq) \
+ RTEMS_BSD_DEFINE_NEXUS_DEVICE(arasan_sdhci, _num, \
+ RTEMS_ARRAY_SIZE(arasan_sdhci ## _num ## _res), \
+ &arasan_sdhci ## _num ## _res[0])
+#endif /* RTEMS_BSD_DRIVER_XILINX_ZYNQ_SDHCI */
+#if !defined(RTEMS_BSD_DRIVER_XILINX_ZYNQ_SDHCI0)
+ #define RTEMS_BSD_DRIVER_XILINX_ZYNQ_SDHCI0 \
+ RTEMS_BSD_DRIVER_XILINX_ZYNQ_SDHCI(0, 0xE0100000, 56)
+#endif /* RTEMS_BSD_DRIVER_XILINX_ZYNQ_SDHCI0 */
+#if !defined(RTEMS_BSD_DRIVER_XILINX_ZYNQ_SDHCI1)
+ #define RTEMS_BSD_DRIVER_XILINX_ZYNQ_SDHCI1 \
+ RTEMS_BSD_DRIVER_XILINX_ZYNQ_SDHCI(1, 0xE0101000, 79)
+#endif /* RTEMS_BSD_DRIVER_XILINX_ZYNQ_SDHCI1 */
* LPC32XX Power Control (PWR).
diff --git a/rtemsbsd/sys/dev/sdhci/arasan_sdhci.c b/rtemsbsd/sys/dev/sdhci/arasan_sdhci.c
new file mode 100644
index 00000000..42574f16
--- /dev/null
+++ b/rtemsbsd/sys/dev/sdhci/arasan_sdhci.c
@@ -0,0 +1,343 @@
+#include <machine/rtems-bsd-kernel-space.h>
+ * Copyright (c) 2019 Navigation Technology Associates Inc.
+ * All rights reserved.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+ * SDHCI driver glue for Zynq 7000 SDHCI
+#include <rtems/bsd/local/opt_mmccam.h>
+#include <sys/param.h>
+#include <sys/systm.h>
+#include <sys/types.h>
+#include <sys/bus.h>
+#include <sys/callout.h>
+#include <sys/kernel.h>
+#include <sys/libkern.h>
+#include <sys/lock.h>
+#include <sys/malloc.h>
+#include <sys/module.h>
+#include <sys/mutex.h>
+#include <rtems/bsd/sys/resource.h>
+#include <sys/rman.h>
+#include <sys/sysctl.h>
+#include <sys/taskqueue.h>
+#include <sys/time.h>
+#include <machine/bus.h>
+#include <machine/resource.h>
+#ifdef __arm__
+#include <machine/intr.h>
+#endif
+#include <dev/ofw/ofw_bus.h>
+#include <dev/ofw/ofw_bus_subr.h>
+#include <dev/mmc/bridge.h>
+#include <dev/sdhci/sdhci.h>
+#include <rtems/bsd/local/mmcbr_if.h>
+#include <rtems/bsd/local/sdhci_if.h>
+struct arasan_sdhci_softc {
+ device_t dev;
+ struct resource * mem_res;
+ struct resource * irq_res;
+ void * intr_cookie;
+ struct sdhci_slot slot;
+ bool slot_init_done;
+static inline uint16_t
+RD2(struct arasan_sdhci_softc *sc, bus_size_t off)
+ return (bus_read_2(sc->mem_res, off));
+static inline void
+WR2(struct arasan_sdhci_softc *sc, bus_size_t off, uint16_t val)
+ bus_write_2(sc->mem_res, off, val);
+static inline uint32_t
+RD4(struct arasan_sdhci_softc *sc, bus_size_t off)
+ return (bus_read_4(sc->mem_res, off));
+static inline void
+WR4(struct arasan_sdhci_softc *sc, bus_size_t off, uint32_t val)
+ bus_write_4(sc->mem_res, off, val);
+static uint8_t
+arasan_sdhci_read_1(device_t dev, struct sdhci_slot *slot, bus_size_t off)
+ struct arasan_sdhci_softc *sc = device_get_softc(dev);
+ return ((RD4(sc, off & ~3) >> (off & 3) * 8) & 0xff);
+static uint16_t
+arasan_sdhci_read_2(device_t dev, struct sdhci_slot *slot, bus_size_t off)
+ return (RD2(sc, off));
+static uint32_t
+arasan_sdhci_read_4(device_t dev, struct sdhci_slot *slot, bus_size_t off)
+ uint32_t val32, wrk32;
+ val32 = RD4(sc, off);
+ if (off == SDHCI_CAPABILITIES) {
+ val32 &= ~SDHCI_CAN_DO_8BITBUS;
+ return (val32);
+ return val32;
+static void
+arasan_sdhci_read_multi_4(device_t dev, struct sdhci_slot *slot, bus_size_t off,
+ uint32_t *data, bus_size_t count)
+ bus_read_multi_4(sc->mem_res, off, data, count);
+static void
+arasan_sdhci_write_1(device_t dev, struct sdhci_slot *slot, bus_size_t off, uint8_t val)
+ uint32_t val32;
+ val32 = RD4(sc, off & ~3);
+ val32 &= ~(0xff << (off & 3) * 8);
+ val32 |= (val << (off & 3) * 8);
+ WR4(sc, off & ~3, val32);
+static void
+arasan_sdhci_write_2(device_t dev, struct sdhci_slot *slot, bus_size_t off, uint16_t val)
+ WR2(sc, off, val);
+static void
+arasan_sdhci_write_4(device_t dev, struct sdhci_slot *slot, bus_size_t off, uint32_t val)
+ WR4(sc, off, val);
+static void
+arasan_sdhci_write_multi_4(device_t dev, struct sdhci_slot *slot, bus_size_t off,
+ bus_write_multi_4(sc->mem_res, off, data, count);
+static void
+arasan_sdhci_intr(void *arg)
+ struct arasan_sdhci_softc *sc = arg;
+ sdhci_generic_intr(&sc->slot);
+static int
+arasan_sdhci_get_ro(device_t bus, device_t child)
+ struct arasan_sdhci_softc *sc = device_get_softc(bus);
+ return (RD4(sc, SDHCI_PRESENT_STATE) & SDHCI_WRITE_PROTECT);
+static bool
+arasan_sdhci_get_card_present(device_t dev, struct sdhci_slot *slot)
+ return (RD4(sc, SDHCI_PRESENT_STATE) & SDHCI_CARD_PRESENT);
+static int
+arasan_sdhci_detach(device_t dev)
+ if (sc->slot_init_done)
+ sdhci_cleanup_slot(&sc->slot);
+ if (sc->intr_cookie != NULL)
+ bus_teardown_intr(dev, sc->irq_res, sc->intr_cookie);
+ if (sc->irq_res != NULL)
+ bus_release_resource(dev, SYS_RES_IRQ,
+ rman_get_rid(sc->irq_res), sc->irq_res);
+ if (sc->mem_res != NULL) {
+ bus_release_resource(dev, SYS_RES_MEMORY,
+ rman_get_rid(sc->mem_res), sc->mem_res);
+ return (0);
+static int
+arasan_sdhci_attach(device_t dev)
+ int rid, err;
+ sc->dev = dev;
+ rid = 0;
+ sc->mem_res = bus_alloc_resource_any(dev, SYS_RES_MEMORY, &rid,
+ RF_ACTIVE);
+ if (!sc->mem_res) {
+ device_printf(dev, "cannot allocate memory window\n");
+ err = ENXIO;
+ goto fail;
+ rid = 0;
+ sc->irq_res = bus_alloc_resource_any(dev, SYS_RES_IRQ, &rid,
+ RF_ACTIVE);
+ if (!sc->irq_res) {
+ device_printf(dev, "cannot allocate interrupt\n");
+ err = ENXIO;
+ goto fail;
+ if (bus_setup_intr(dev, sc->irq_res, INTR_TYPE_BIO | INTR_MPSAFE,
+ NULL, arasan_sdhci_intr, sc, &sc->intr_cookie)) {
+ device_printf(dev, "cannot setup interrupt handler\n");
+ err = ENXIO;
+ goto fail;
+ sc->slot.quirks |= SDHCI_QUIRK_DATA_TIMEOUT_USES_SDCLK;
+ sc->slot.quirks |= SDHCI_QUIRK_BROKEN_AUTO_STOP;
+ * DMA is not really broken, it just isn't implemented yet.
+ sc->slot.quirks |= SDHCI_QUIRK_BROKEN_DMA;
+ sc->slot.max_clk = 50000000;
+ sdhci_init_slot(dev, &sc->slot, 0);
+ sc->slot_init_done = true;
+ bus_generic_probe(dev);
+ bus_generic_attach(dev);
+ sdhci_start_slot(&sc->slot);
+ return (0);
+fail:
+ arasan_sdhci_detach(dev);
+ return (err);
+static int
+arasan_sdhci_probe(device_t dev)
+ device_set_desc(dev, "Zynq-7000 SDHCI");
+ return (0);
+static device_method_t arasan_sdhci_methods[] = {
+ /* Device interface */
+ DEVMETHOD(device_probe, arasan_sdhci_probe),
+ DEVMETHOD(device_attach, arasan_sdhci_attach),
+ DEVMETHOD(device_detach, arasan_sdhci_detach),
+ /* Bus interface */
+ DEVMETHOD(bus_read_ivar, sdhci_generic_read_ivar),
+ DEVMETHOD(bus_write_ivar, sdhci_generic_write_ivar),
+ /* MMC bridge interface */
+ DEVMETHOD(mmcbr_update_ios, sdhci_generic_update_ios),
+ DEVMETHOD(mmcbr_request, sdhci_generic_request),
+ DEVMETHOD(mmcbr_get_ro, arasan_sdhci_get_ro),
+ DEVMETHOD(mmcbr_acquire_host, sdhci_generic_acquire_host),
+ DEVMETHOD(mmcbr_release_host, sdhci_generic_release_host),
+ /* SDHCI accessors */
+ DEVMETHOD(sdhci_read_1, arasan_sdhci_read_1),
+ DEVMETHOD(sdhci_read_2, arasan_sdhci_read_2),
+ DEVMETHOD(sdhci_read_4, arasan_sdhci_read_4),
+ DEVMETHOD(sdhci_read_multi_4, arasan_sdhci_read_multi_4),
+ DEVMETHOD(sdhci_write_1, arasan_sdhci_write_1),
+ DEVMETHOD(sdhci_write_2, arasan_sdhci_write_2),
+ DEVMETHOD(sdhci_write_4, arasan_sdhci_write_4),
+ DEVMETHOD(sdhci_write_multi_4, arasan_sdhci_write_multi_4),
+ DEVMETHOD(sdhci_get_card_present,arasan_sdhci_get_card_present),
+ DEVMETHOD_END
+static devclass_t arasan_sdhci_devclass;
+static driver_t arasan_sdhci_driver = {
+ "arasan_sdhci",
+ arasan_sdhci_methods,
+ sizeof(struct arasan_sdhci_softc),
+DRIVER_MODULE(arasan_sdhci, nexus, arasan_sdhci_driver, arasan_sdhci_devclass, 0, 0);
+MODULE_DEPEND(arasan_sdhci, sdhci, 1, 1, 1);
+#ifndef MMCCAM
+MMC_DECLARE_BRIDGE(arasan_sdhci);
+#endif
2.20.1
