[PATCH 06/13] bsps/arm: Invalidate branch predictors earlier
Tue Dec 22 13:01:03 UTC 2020
Make sure the branch predictors are invalidated before the first branch
is executed.
Update #4202.
 bsps/arm/include/bsp/arm-a9mpcore-start.h    |  2 --
 bsps/arm/raspberrypi/start/bspstarthooks.c   |  1 -
 bsps/arm/shared/start/start.S                | 11 +++++++++++
 bsps/arm/xilinx-zynq/start/bspstarthooks.c   |  1 -
 bsps/arm/xilinx-zynqmp/start/bspstarthooks.c |  1 -
 5 files changed, 11 insertions(+), 5 deletions(-)
diff --git a/bsps/arm/include/bsp/arm-a9mpcore-start.h b/bsps/arm/include/bsp/arm-a9mpcore-start.h
index 2a64ffc1d6..98d1a2e295 100644
--- a/bsps/arm/include/bsp/arm-a9mpcore-start.h
+++ b/bsps/arm/include/bsp/arm-a9mpcore-start.h
@@ -140,8 +140,6 @@ BSP_START_TEXT_SECTION static inline void arm_a9mpcore_start_hook_0(void)
     (volatile a9mpcore_scu *) BSP_ARM_A9MPCORE_SCU_BASE;
   uint32_t cpu_id = arm_cortex_a9_get_multiprocessor_cpu_id();
-  arm_cp15_branch_predictor_invalidate_all();
   if (cpu_id == 0) {
     arm_a9mpcore_start_scu_enable(scu);
diff --git a/bsps/arm/raspberrypi/start/bspstarthooks.c b/bsps/arm/raspberrypi/start/bspstarthooks.c
index c46c4f5cbf..b050cb695e 100644
--- a/bsps/arm/raspberrypi/start/bspstarthooks.c
+++ b/bsps/arm/raspberrypi/start/bspstarthooks.c
@@ -110,7 +110,6 @@ void BSP_START_TEXT_SECTION bsp_start_hook_0(void)
     rtems_cache_invalidate_entire_data();
   rtems_cache_invalidate_entire_instruction();
   arm_cp15_tlb_invalidate();
   arm_cp15_flush_prefetch_buffer();
diff --git a/bsps/arm/shared/start/start.S b/bsps/arm/shared/start/start.S
index 9ebc2818e5..f4880dfcf0 100644
--- a/bsps/arm/shared/start/start.S
+++ b/bsps/arm/shared/start/start.S
@@ -181,6 +181,17 @@ _start:
 	mov	r13, #0
 #endif
+#if __ARM_ARCH >= 7
+	 * Write to BPIALL (Branch Predictor Invalidate All) to invalidate all
+	 * branch predictors.  There is no need to use BPIALLIS (Branch
+	 * Predictor Invalidate All, Inner Shareable) since this code is
+	 * executed on all processors used by RTEMS.
+	mov	r0, #0
+	mcr	p15, 0, r0, c7, c5, 6
+#endif
 #ifdef RTEMS_SMP
 	/* Read MPIDR and get current processor index */
 	mrc	p15, 0, r7, c0, c0, 5
diff --git a/bsps/arm/xilinx-zynq/start/bspstarthooks.c b/bsps/arm/xilinx-zynq/start/bspstarthooks.c
index a0f0fbacf6..0fc2a2590d 100644
--- a/bsps/arm/xilinx-zynq/start/bspstarthooks.c
+++ b/bsps/arm/xilinx-zynq/start/bspstarthooks.c
@@ -66,7 +66,6 @@ BSP_START_TEXT_SECTION void bsp_start_hook_0(void)
    * are required there.
   arm_cp15_data_cache_invalidate_all_levels();
   arm_a9mpcore_start_hook_0();
diff --git a/bsps/arm/xilinx-zynqmp/start/bspstarthooks.c b/bsps/arm/xilinx-zynqmp/start/bspstarthooks.c
index 9ab8d965f3..bc3f0fbe5e 100644
--- a/bsps/arm/xilinx-zynqmp/start/bspstarthooks.c
+++ b/bsps/arm/xilinx-zynqmp/start/bspstarthooks.c
@@ -72,7 +72,6 @@ BSP_START_TEXT_SECTION void bsp_start_hook_0(void)
2.26.2
