[PATCH 08/13] bsps/arm: Add arm-data-cache-loop-set-way.h
Sebastian Huber
Tue Dec 22 13:01:05 UTC 2020
This makes it possible to reuse this loop.
Update #4202.
.../dev/cache/arm-data-cache-loop-set-way.h | 96 +++++++++++++++++++
.../shared/cache/cache-v7ar-disable-data.S | 71 ++------------
2 files changed, 105 insertions(+), 62 deletions(-)
create mode 100644 bsps/arm/include/dev/cache/arm-data-cache-loop-set-way.h
diff --git a/bsps/arm/include/dev/cache/arm-data-cache-loop-set-way.h b/bsps/arm/include/dev/cache/arm-data-cache-loop-set-way.h
new file mode 100644
index 0000000000..f5dc792aa2
--- /dev/null
+++ b/bsps/arm/include/dev/cache/arm-data-cache-loop-set-way.h
@@ -0,0 +1,96 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2018 embedded brains GmbH
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+.macro ARM_DATA_CACHE_LOOP_SET_WAY CRM
+ /* Get cache levels (LoC) from CLIDR */
+ mrc p15, 1, r1, c0, c0, 1
+ mov r2, r1, lsr #24
+ ands r2, r2, #0x7
+ beq 5f
+ /* Start with level 0 */
+ mov r3, #0
+ /* Flush level specified by r3 */
+1:
+ /* Check cache type and skip this level if there is no data cache */
+ add r4, r3, r3, lsl #1
+ lsr r5, r1, r4
+ and r5, r5, #0x7
+ cmp r5, #2
+ blt 4f
+ /* Read CCSIDR */
+ lsl r4, r3, #1
+ mcr p15, 2, r4, c0, c0, 0
+ isb
+ mrc p15, 1, r5, c0, c0, 0
+ /* Get cache line power */
+ and r6, r5, #0x7
+ add r6, r6, #4
+ /* Get ways minus one */
+ mov r7, #0x3ff
+ ands r7, r7, r5, lsr #3
+ /* Get way shift */
+ clz r8, r7
+ /* Get sets minus one */
+ mov r9, #0x7fff
+ ands r9, r9, r5, lsr #13
+ /* Loop over ways */
+2:
+ mov r10, r9
+ /* Loop over sets */
+3:
+ orr r11, r4, r7, lsl r8
+ orr r11, r11, r10, lsl r6
+ /* Cache operation by set and way */
+ mcr p15, 0, r11, c7, \CRM, 2
+ subs r10, r10, #1
+ bge 3b
+ subs r7, r7, #1
+ bge 2b
+ /* Next level */
+4:
+ add r3, r3, #1
+ cmp r2, r3
+ bgt 1b
+ /* Done */
+5:
+.endm
diff --git a/bsps/arm/shared/cache/cache-v7ar-disable-data.S b/bsps/arm/shared/cache/cache-v7ar-disable-data.S
index 543a3fdaf4..a5b4b7a3d1 100644
--- a/bsps/arm/shared/cache/cache-v7ar-disable-data.S
+++ b/bsps/arm/shared/cache/cache-v7ar-disable-data.S
@@ -27,7 +27,9 @@
#include <rtems/asm.h>
-#if __ARM_ARCH >= 7 && (__ARM_ARCH_PROFILE == 65 || __ARM_ARCH_PROFILE == 82)
+#include <dev/cache/arm-data-cache-loop-set-way.h>
+#if __ARM_ARCH >= 7 && (__ARM_ARCH_PROFILE == 'A' || __ARM_ARCH_PROFILE == 'R')
.globl rtems_cache_disable_data
.syntax unified
@@ -53,68 +55,13 @@ FUNCTION_ENTRY(rtems_cache_disable_data)
mcr p15, 0, r1, c1, c0, 0
isb
- /* Get cache levels (LoC) from CLIDR */
- mrc p15, 1, r1, c0, c0, 1
- mov r2, r1, lsr #24
- ands r2, r2, #0x7
- beq .Ldone
- /* Start with level 0 */
- mov r3, #0
-.Lflush_level:
- /* Flush level specified by r3 */
- /* Check cache type */
- add r4, r3, r3, lsl #1
- lsr r5, r1, r4
- and r5, r5, #0x7
- cmp r5, #2
- blt .Lno_data_cache
- /* Read CCSIDR */
- lsl r4, r3, #1
- mcr p15, 2, r4, c0, c0, 0
- isb
- mrc p15, 1, r5, c0, c0, 0
- /* Get cache line power */
- and r6, r5, #0x7
- add r6, r6, #4
- /* Get ways minus one */
- mov r7, #0x3ff
- ands r7, r7, r5, lsr #3
- /* Get way shift */
- clz r8, r7
- /* Get sets minus one */
- mov r9, #0x7fff
- ands r9, r9, r5, lsr #13
-.Lloop_over_ways:
- mov r10, r9
-.Lloop_over_sets:
- orr r11, r4, r7, lsl r8
- orr r11, r11, r10, lsl r6
- /* Clean and invalidate by set and way */
- mcr p15, 0, r11, c7, c14, 2
- subs r10, r10, #1
- bge .Lloop_over_sets
- subs r7, r7, #1
- bge .Lloop_over_ways
-.Lno_data_cache:
- /* Next level */
- add r3, r3, #1
- cmp r2, r3
- bgt .Lflush_level
+ * Clean and invalidate the sets and ways of all data or unified cache
+ * levels using DCCISW (Data Cache line Clean and Invalidate by
+ * Set/Way).
+ ARM_DATA_CACHE_LOOP_SET_WAY c14
-.Ldone:
/* Restore interrupts */
msr CPSR_fc, r0
2.26.2
