[PATCH 04/13] arm: Add support for Arm PMSAv8-32
Sebastian Huber
Tue Dec 22 13:01:01 UTC 2020
Update #4202.
.../score/cpu/arm/aarch32-psma-init-default.c | 60 ++++
cpukit/score/cpu/arm/aarch32-psma-init.c | 194 +++++++++++
.../arm/include/rtems/score/aarch32-pmsa.h | 314 ++++++++++++++++++
spec/build/cpukit/cpuarm.yml | 2 +
4 files changed, 570 insertions(+)
create mode 100644 cpukit/score/cpu/arm/aarch32-psma-init-default.c
create mode 100644 cpukit/score/cpu/arm/aarch32-psma-init.c
create mode 100644 cpukit/score/cpu/arm/include/rtems/score/aarch32-pmsa.h
diff --git a/cpukit/score/cpu/arm/aarch32-psma-init-default.c b/cpukit/score/cpu/arm/aarch32-psma-init-default.c
new file mode 100644
index 0000000000..da710d77fc
--- /dev/null
+++ b/cpukit/score/cpu/arm/aarch32-psma-init-default.c
@@ -0,0 +1,60 @@
+ * @file
+ * @ingroup RTEMSScoreCPUARMPMSAv8
+ * @brief This source file contains the implementation of
+ * _AArch32_PMSA_Initialize_default().
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/aarch32-pmsa.h>
+#if __ARM_ARCH >= 8 && __ARM_ARCH_PROFILE == 'R'
+void _AArch32_PMSA_Initialize_default( void )
+ _AArch32_PMSA_Initialize(
+ AARCH32_PMSA_MEM_ATTR(
+ AARCH32_PMSA_MEM_ATTR_DEFAULT_CACHED,
+ AARCH32_PMSA_MEM_ATTR_DEFAULT_UNCACHED,
+ AARCH32_PMSA_MEM_ATTR_DEFAULT_DEVICE,
+ 0
+ 0,
+ _AArch32_PMSA_Sections,
+ _AArch32_PMSA_Section_count
+#endif
diff --git a/cpukit/score/cpu/arm/aarch32-psma-init.c b/cpukit/score/cpu/arm/aarch32-psma-init.c
index 0000000000..de75d2a733
--- /dev/null
+++ b/cpukit/score/cpu/arm/aarch32-psma-init.c
@@ -0,0 +1,194 @@
+ * @file
+ * _AArch32_PMSA_Initialize().
+ * are met:
+#endif
+#include <rtems/score/aarch32-system-registers.h>
+#include <rtems/score/cpu.h>
+#define AARCH32_PSMA_REGION_MAX \
+ ( ( AARCH32_MPUIR_REGION_MASK >> AARCH32_MPUIR_REGION_SHIFT ) + 1 )
+typedef struct {
+ uint32_t base;
+ uint32_t limit;
+ uint32_t attributes;
+} AArch32_PMSA_Region;
+static void _AArch32_PMSA_Configure(
+ const AArch32_PMSA_Region *regions,
+ size_t region_used,
+ size_t region_max
+ size_t ri;
+ uint32_t sctlr;
+ for ( ri = 0 ; ri < region_used; ++ri ) {
+ uint32_t prbar;
+ uint32_t prlar;
+ uint32_t attr;
+ prbar = regions[ ri ].base;
+ prlar = regions[ ri ].limit;
+ attr = regions[ ri ].attributes;
+ prbar |= ( attr >> 6 ) & 0x3fU;
+ prlar |= attr & 0x3fU;
+ _AArch32_Write_prselr( ri );
+ _ARM_Instruction_synchronization_barrier();
+ _AArch32_Write_prbar( prbar );
+ _AArch32_Write_prlar( prlar );
+ for ( ri = region_used ; ri < region_max; ++ri ) {
+ _AArch32_Write_prbar( 0 );
+ _AArch32_Write_prlar( 0 );
+ _ARM_Data_synchronization_barrier();
+ sctlr = _AArch32_Read_sctlr();
+ sctlr |= AARCH32_SCTLR_M | AARCH32_SCTLR_I | AARCH32_SCTLR_C;
+ sctlr &= ~AARCH32_SCTLR_BR;
+ _AArch32_Write_sctlr( sctlr );
+void _AArch32_PMSA_Initialize(
+ uint32_t memory_attributes_0,
+ uint32_t memory_attributes_1,
+ const AArch32_PMSA_Section *sections,
+ size_t section_count
+ AArch32_PMSA_Region regions[ AARCH32_PSMA_REGION_MAX ];
+ size_t ri;
+ size_t si;
+ size_t region_used;
+ size_t region_max;
+ _AArch32_Write_mair0( memory_attributes_0 );
+ _AArch32_Write_mair1( memory_attributes_1 );
+ region_max = ( _AArch32_Read_mpuir() & AARCH32_MPUIR_REGION_MASK ) >>
+ AARCH32_MPUIR_REGION_SHIFT;
+ region_used = 0;
+ for ( si = 0; si < section_count; ++si ) {
+ uint32_t base;
+ uint32_t limit;
+ uint32_t attr;
+ base = sections[ si ].begin;
+ limit = sections[ si ].end;
+ attr = sections[ si ].attributes;
+ if ( base == limit ) {
+ continue;
+ base = RTEMS_ALIGN_DOWN( base, AARCH32_PMSA_MIN_REGION_ALIGN );
+ limit = RTEMS_ALIGN_DOWN( limit - 1, AARCH32_PMSA_MIN_REGION_ALIGN );
+ for ( ri = 0; ri < region_used; ++ri ) {
+ uint32_t region_base;
+ uint32_t region_limit;
+ uint32_t region_attr;
+ region_base = regions[ ri ].base;
+ region_limit = regions[ ri ].limit;
+ region_attr = regions[ ri ].attributes;
+ if (
+ limit + AARCH32_PMSA_MIN_REGION_ALIGN == region_base &&
+ attr == region_attr
+ /* Merge section with existing region */
+ regions[ ri ].base = base;
+ break;
+ } else if (
+ base == region_limit + AARCH32_PMSA_MIN_REGION_ALIGN &&
+ regions[ ri ].limit = limit;
+ break;
+ } else if ( limit < region_base ) {
+ size_t i;
+ if ( region_used >= region_max ) {
+ return;
+ for ( i = ri; i < region_used; ++i ) {
+ regions[ i + 1 ] = regions[ i ];
+ /* New first region */
+ ++region_used;
+ regions[ ri ].attributes = attr;
+ break;
+ if ( ri == region_used ) {
+ return;
+ /* New last region */
+ ++region_used;
+ _AArch32_PMSA_Configure( regions, region_used, region_max );
+#endif
diff --git a/cpukit/score/cpu/arm/include/rtems/score/aarch32-pmsa.h b/cpukit/score/cpu/arm/include/rtems/score/aarch32-pmsa.h
index 0000000000..ea25828bb6
--- /dev/null
+++ b/cpukit/score/cpu/arm/include/rtems/score/aarch32-pmsa.h
@@ -0,0 +1,314 @@
+ * @file
+ * @brief This header file provides the API to manage an Arm PMSAv8-32 based
+ * Memory Protection Unit (MPU).
+ * are met:
+#ifndef _RTEMS_SCORE_AARCH32_PMSA_H
+#define _RTEMS_SCORE_AARCH32_PMSA_H
+#include <stddef.h>
+#include <stdint.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @defgroup RTEMSScoreCPUARMPMSAv8 PMSAv8-32 Support
+ * @brief This group provides support functions to manage an Arm PMSAv8-32
+ * (Protected Memory System Architecture) based Memory Protection Unit (MPU).
+#define AARCH32_PMSA_MIN_REGION_ALIGN 64
+#define AARCH32_PMSA_ATTR_EN 0x1U
+#define AARCH32_PMSA_ATTR_IDX_SHIFT 1
+#define AARCH32_PMSA_ATTR_IDX_MASK 0xeU
+#define AARCH32_PMSA_ATTR_IDX( _idx ) \
+ ( ( _idx ) << AARCH32_PMSA_ATTR_IDX_SHIFT )
+#define AARCH32_PMSA_ATTR_XN 0x6U
+#define AARCH32_PMSA_ATTR_AP_SHIFT 7
+#define AARCH32_PMSA_ATTR_AP_MASK 0x18U
+#define AARCH32_PMSA_ATTR_AP( _ap ) \
+ ( ( _ap ) << AARCH32_PMSA_ATTR_AP_SHIFT )
+#define AARCH32_PMSA_ATTR_AP_EL1_RW_EL0_NO 0x0U
+#define AARCH32_PMSA_ATTR_AP_EL1_RW_EL0_RW 0x1U
+#define AARCH32_PMSA_ATTR_AP_EL1_RO_EL0_NO 0x2U
+#define AARCH32_PMSA_ATTR_AP_EL1_RO_EL0_RO 0x3U
+#define AARCH32_PMSA_ATTR_SH_SHIFT 9
+#define AARCH32_PMSA_ATTR_SH_MASK 0x600U
+#define AARCH32_PMSA_ATTR_SH( _sh ) \
+ ( ( _sh ) << AARCH32_PMSA_ATTR_SH_SHIFT )
+#define AARCH32_PMSA_ATTR_SH_NO 0x0U
+#define AARCH32_PMSA_ATTR_SH_RES 0x1U
+#define AARCH32_PMSA_ATTR_SH_OUTER 0x2U
+#define AARCH32_PMSA_ATTR_SH_INNER 0x3U
+#define AARCH32_PMSA_MEM_DEVICE_NG_NR_NE 0x00U
+#define AARCH32_PMSA_MEM_DEVICE_NG_NR_E 0x04U
+#define AARCH32_PMSA_MEM_DEVICE_NG_R_E 0x08U
+#define AARCH32_PMSA_MEM_DEVICE_G_R_E 0x0cU
+#define AARCH32_PMSA_MEM_OUTER_WTT 0x00U
+#define AARCH32_PMSA_MEM_OUTER_NC 0x40U
+#define AARCH32_PMSA_MEM_OUTER_WBT 0x40U
+#define AARCH32_PMSA_MEM_OUTER_WTNT 0x80U
+#define AARCH32_PMSA_MEM_OUTER_WBNT 0xc0U
+#define AARCH32_PMSA_MEM_OUTER_RA 0x20U
+#define AARCH32_PMSA_MEM_OUTER_WA 0x10U
+#define AARCH32_PMSA_MEM_INNER_WTT 0x00U
+#define AARCH32_PMSA_MEM_INNER_NC 0x40U
+#define AARCH32_PMSA_MEM_INNER_WBT 0x40U
+#define AARCH32_PMSA_MEM_INNER_WTNT 0x80U
+#define AARCH32_PMSA_MEM_INNER_WBNT 0xc0U
+#define AARCH32_PMSA_MEM_INNER_RA 0x02U
+#define AARCH32_PMSA_MEM_INNER_WA 0x01U
+#define AARCH32_PMSA_MEM_ATTR( _ma0, _ma1, _ma2, _ma3 ) \
+ ( ( _ma0 ) | ( ( _ma1 ) << 8 ) | ( ( _ma1 ) << 16 ) | ( ( _ma1 ) << 24 ) )
+#define AARCH32_PMSA_MEM_ATTR_DEFAULT_CACHED \
+ ( AARCH32_PMSA_MEM_OUTER_WBNT | \
+ AARCH32_PMSA_MEM_OUTER_RA | \
+ AARCH32_PMSA_MEM_OUTER_WA | \
+ AARCH32_PMSA_MEM_INNER_WBNT | \
+ AARCH32_PMSA_MEM_INNER_RA | \
+ AARCH32_PMSA_MEM_INNER_WA )
+#define AARCH32_PMSA_MEM_ATTR_DEFAULT_UNCACHED \
+ ( AARCH32_PMSA_MEM_OUTER_NC | \
+ AARCH32_PMSA_MEM_INNER_NC )
+#define AARCH32_PMSA_MEM_ATTR_DEFAULT_DEVICE \
+ AARCH32_PMSA_MEM_DEVICE_NG_NR_NE
+#define AARCH32_PMSA_CODE_CACHED \
+ ( AARCH32_PMSA_ATTR_EN | \
+ AARCH32_PMSA_ATTR_AP( AARCH32_PMSA_ATTR_AP_EL1_RO_EL0_NO ) | \
+ AARCH32_PMSA_ATTR_SH( AARCH32_PMSA_ATTR_SH_NO ) | \
+ AARCH32_PMSA_ATTR_IDX( 0U ) )
+#define AARCH32_PMSA_CODE_UNCACHED \
+ AARCH32_PMSA_ATTR_IDX( 1U ) )
+#define AARCH32_PMSA_DATA_READ_ONLY_CACHED \
+ AARCH32_PMSA_ATTR_XN | \
+ AARCH32_PMSA_ATTR_SH( AARCH32_PMSA_ATTR_SH_OUTER ) | \
+#define AARCH32_PMSA_DATA_READ_ONLY_UNCACHED \
+#define AARCH32_PMSA_DATA_READ_WRITE_CACHED \
+ AARCH32_PMSA_ATTR_AP_EL1_RW_EL0_NO | \
+#define AARCH32_PMSA_DATA_READ_WRITE_UNCACHED \
+ AARCH32_PMSA_ATTR_AP( AARCH32_PMSA_ATTR_AP_EL1_RW_EL0_NO ) | \
+#define AARCH32_PMSA_DEVICE \
+ AARCH32_PMSA_ATTR_IDX( 2U ) )
+ * @brief The default section definitions shall be used by the BSP to define
+ * ::_AArch32_PMSA_Sections.
+ * In addition to the default section definitions, the BSP should provide
+ * section definitions for the memory-mapped devices and other memory areas.
+#define AARCH32_PMSA_DEFAULT_SECTIONS \
+ .begin = (uint32_t) bsp_section_fast_text_begin, \
+ .end = (uint32_t) bsp_section_fast_text_end, \
+ .attributes = AARCH32_PMSA_CODE_CACHED \
+ .begin = (uint32_t) bsp_section_fast_data_begin, \
+ .end = (uint32_t) bsp_section_fast_data_end, \
+ .attributes = AARCH32_PMSA_DATA_READ_WRITE_CACHED \
+ .begin = (uint32_t) bsp_section_start_begin, \
+ .end = (uint32_t) bsp_section_start_end, \
+ .begin = (uint32_t) bsp_section_vector_begin, \
+ .end = (uint32_t) bsp_section_vector_end, \
+ .begin = (uint32_t) bsp_section_text_begin, \
+ .end = (uint32_t) bsp_section_text_end, \
+ .begin = (uint32_t) bsp_section_rodata_begin, \
+ .end = (uint32_t) bsp_section_rodata_end, \
+ .attributes = AARCH32_PMSA_DATA_READ_ONLY_CACHED \
+ .begin = (uint32_t) bsp_section_data_begin, \
+ .end = (uint32_t) bsp_section_data_end, \
+ .begin = (uint32_t) bsp_section_bss_begin, \
+ .end = (uint32_t) bsp_section_bss_end, \
+ .begin = (uint32_t) bsp_section_rtemsstack_begin, \
+ .end = (uint32_t) bsp_section_rtemsstack_end, \
+ .begin = (uint32_t) bsp_section_work_begin, \
+ .end = (uint32_t) bsp_section_work_end, \
+ .begin = (uint32_t) bsp_section_stack_begin, \
+ .end = (uint32_t) bsp_section_stack_end, \
+ .begin = (uint32_t) bsp_section_nocache_begin, \
+ .end = (uint32_t) bsp_section_nocache_end, \
+ .attributes = AARCH32_PMSA_DATA_READ_WRITE_UNCACHED \
+ .begin = (uint32_t) bsp_section_nocachenoload_begin, \
+ .end = (uint32_t) bsp_section_nocachenoload_end, \
+ * @brief The section definition is used to initialize the Memory Protection
+ * Unit (MPU).
+ * A section is empty if the begin address is equal to the end address.
+typedef struct {
+ * @brief This member defines the begin address of the section.
+ uint32_t begin;
+ * @brief This member defines the end address of the section.
+ uint32_t end;
+ * @brief This member defines the attributes of the section.
+} AArch32_PMSA_Section;
+ * @brief Initializes the Memory Protection Unit (MPU).
+ * The section definitions are used to define the regions of the MPU. Sections
+ * are merged if possible to reduce the count of used regions. If too many
+ * regions are used, then the MPU is not enabled. Overlapping section
+ * definitions result in undefined system behaviour.
+ * @param memory_attributes_0 are the memory attributes for MAIR0.
+ * @param memory_attributes_1 are the memory attributes for MAIR1.
+ * @param sections is the array with section definitions.
+ * @param section_count is the count of section definitions.
+ * @brief This array provides section definitions to initialize the memory
+ * protection unit (MPU).
+ * The BSP shall provide the section definitions with the help of
+ * ::AARCH32_PMSA_DEFAULT_SECTIONS. The section count is provided by
+ * ::_AArch32_PMSA_Section_count.
+extern const AArch32_PMSA_Section _AArch32_PMSA_Sections[];
+ * @brief This constant provides the count of elements in
+extern const size_t _AArch32_PMSA_Section_count;
+ * @brief Initializes the Memory Protection Unit (MPU) using the section
+ * definitions with default memory attributes.
+ * Calls _AArch32_PMSA_Initialize() using ::_AArch32_PMSA_Sections and
+ * ::_AArch32_PMSA_Section_count and the default memory attributes.
+void _AArch32_PMSA_Initialize_default( void );
+#ifdef __cplusplus
+#endif
+#endif /* _RTEMS_SCORE_AARCH32_PMSA_H */
diff --git a/spec/build/cpukit/cpuarm.yml b/spec/build/cpukit/cpuarm.yml
index 6bbbb08c36..0861fb1118 100644
--- a/spec/build/cpukit/cpuarm.yml
+++ b/spec/build/cpukit/cpuarm.yml
@@ -30,6 +30,8 @@ install:
- cpukit/score/cpu/arm/include/rtems/score/paravirt.h
links: []
source:
+- cpukit/score/cpu/arm/aarch32-psma-init.c
+- cpukit/score/cpu/arm/aarch32-psma-init-default.c
- cpukit/score/cpu/arm/__aeabi_read_tp.c
- cpukit/score/cpu/arm/arm-context-validate.S
- cpukit/score/cpu/arm/arm-context-volatile-clobber.S
2.26.2
