Ticket #3515
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Sat Feb 1 16:52:22 UTC 2020
On Sat, Feb 1, 2020 at 9:31 PM Bran S <archsbran at gmail.com> wrote:
> On Sat, 1 Feb 2020 at 18:44, Vijay Kumar Banerjee <
> vijaykumar9597 at gmail.com> wrote:
> > On Sat, Feb 1, 2020 at 12:57 PM Bran S <archsbran at gmail.com> wrote:
> >> On Thu, 30 Jan 2020 at 05:52, Chris Johns <chrisj at rtems.org> wrote:
> >> > On 29/1/20 7:03 pm, Bran S wrote:
> >> > > Hi Guys,
> >> > > I am trying to solve #3515
> >> > > https://devel.rtems.org/ticket/3515 <
> https://devel.rtems.org/ticket/3515>
> >> > Nice and thanks.
> >> > > For this issue covoar is required.
> >> > > So I cloned https://git.rtems.org/rtems-tools/ <
> https://git.rtems.org/rtems-tools/>
> >> > > This is my directory structure:
> >> > > $HOME/quick-start/src/rtems - Main RTEMS repo
> >> > > $HOME/quick-start/src/rsb - Source Builder
> >> > > $HOME/quick-start/src/rtems-tools - The one that I have recently
> cloned
> >> > > But running `rtems-test --list-bsps` inside
> '$HOME/quick-start/src/rtems-tools'
> >> > > gives "error: RTEMS Toolkit python wrapper not found, plrease
> report"
> >> > > Any ideas on how to resolve this error ?
> >> > What does `type rtems-test` say?
> >> > Have you built a set of sparc tools?
> >> > Have you build the leon3 BSP and all the tests?
> >> > I am not sure what happens if the `rtems-test` is run in the source
> tree while
> >> > picking up a version from your path. Maybe `./tester/rtems-test ...`
> works?
> > Hi Bran,
> > Thanks for taking up this ticket.
> >> It is now working my $PATH was wrongly set with rtems/4.11 instead of
> rtems/5.
> >> I have corrected it. It now contains '$HOME/quick-start/rtems/5/bin'
> > Nice.
> >> Moving on to the next problem:
> https://devel.rtems.org/wiki/GCI/Documentation/CoverageAnalysis/Coverage#RunningRTEMS-TESTERforCoverageanalysis
> >> I was reading this to know more about covoar.
> >> So as mentioned above I ran
> >> `rtems-test --rtems-tools=/home/user45/quick-start/rtems/5/
> >> --log=coverage_analysis.log --no-clean --coverage=score
> >> --rtems-bsp=leon3-qemu-cov
> /home/user45/quick-start/build/b-leon3/sparc-rtems5/c/leon3/testsuites/samples/hello.exe`
> >> And the output was: https://paste.debian.net/1128608/
> >> `qemu-system-sparc` not being installed seems to be the cause for the
> error.
> >> So I followed suggestion found here:
> >> https://lists.rtems.org/pipermail/users/2018-January/065583.html
> >> Ran the commands as:
> >> $ cd /quick-start/src/rsb/rtems/
> >> The rsb directory contains rtems source builder.
> >> $ ../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/5
> >> devel/qemu.bset
> > You need devel/qemu-couverture.bset but while trying to build it, I see
> the same error
> > as you see with qemu.bset
> >> Running this further gives errors and reports it into
> >> 'rsb-report-glib-2.39.3-x86_64-linux-gnu-1.txt'
> >> Full output of above command is at: https://paste.debian.net/1128609/
> >> The content of 'rsb-report-glib-2.39.3-x86_64-linux-gnu-1.txt' is
> >> here: https://paste.debian.net/1128610/
> >> In file 'rsb-report-glib-2.39.3-x86_64-linux-gnu-1.txt' (at
> >> https://paste.debian.net/1128610/) the first error occurs at line 385,
> >> which is:
> >> ../../glib-2.39.3/glib/gdate.c:2497:7: error: format not a string
> >> literal, format string not checked [-Werror=format-nonliteral]
> >>        tmplen = strftime (tmpbuf, tmpbufsize, locale_format, &tm);
> >>   CC       libglib_2_0_la-gdir.lo
> >>   CC       libglib_2_0_la-genviron.lo
> >> cc1: some warnings being treated as errors
> >> Makefile:1782: recipe for target 'libglib_2_0_la-gdate.lo' failed
> >> make[4]: *** [libglib_2_0_la-gdate.lo] Error 1
> >> This happens to be a known error/bug (Ref:
> >> https://bugs.freedesktop.org/show_bug.cgi?id=95326)
> >> and a patch is available for it here:
> https://gitlab.gnome.org/GNOME/glib/commit/8cdbc7fb2c8c876902e457abe46ee18a0b134486
> >> Following the patch I manually made changes into
> '$HOME/quick-start/src/rsb/rtems/build/glib-2.39.3-x86_64-linux-gnu-1/glib-2.39.3/glib/gdate.c'
> >> But the problem is that as soon as I run
> >> `../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/5
> >> devel/qemu.bset`
> >> My manual changes to the gdate.c disappear and I get the same error as
> >> before. I don't know what is going on.
> > I applied the patch that you found along with another patch and built
> the souces, glib built
> > successfully, but unfortunately the couverture-qemu itself failed to
> build. Here's the log:
> > https://paste.ofcode.org/KmJCNZrJyQNev6R4FSUafe
> > Here I'm pasting the diff to add patches to RSB:
> > diff --git a/bare/config/devel/glib-2.39.3-1.cfg
> b/bare/config/devel/glib-2.39.3-1.cfg
> > index d86fe28..0bada15 100644
> > --- a/bare/config/devel/glib-2.39.3-1.cfg
> > +++ b/bare/config/devel/glib-2.39.3-1.cfg
> > @@ -14,6 +14,10 @@
> >  %hash sha256 glib-%{glib_version}.tar.xz
> d9fa6c9aa645a5e688a3bb29013bb83801b19ee767d99e33ff52e004e1cc5fc8
> > +#Patch to supress string literal warning
> > +%patch add glib
> https://gitlab.gnome.org/GNOME/glib/commit/0817af40e8c74c721c30f6ef482b1f53d12044c7.patch
> > +%patch add glib
> https://gitlab.gnome.org/GNOME/glib/commit/566e1d61a500267c7849ad0b2552feec9c9a29a6.patch
> >  # The GLib build instructions. We use 2.x.x Release 1.
> > You can apply the above diff into your rtems-source-builder and try to
> build couverture qemu.
> > Most likely it will fail it seems.
> >> After this I found out that `qemu4.bset` is also present so I ran
> >> devel/qemu4.bset
> >> It seems to have run successfully here is the full output:
> >> https://paste.debian.net/1128611/
> >> Seems like qemu-system-sparc is now installed. But still while running
> >> I get the same error related to qemu-system-sparc.
> >> Here is the full output: https://paste.debian.net/1128612/
> >> But this time there is a little difference.
> >> Earlier it exited with exit code 2. see (
> https://paste.debian.net/1128608/)
> >> Now it is exiting with exit code 1. see (
> https://paste.debian.net/1128612/)
> >> Note: To see the exit code on the above 2 links you may have to use
> >> the horizontal scroll.
> >> What am I doing wrong ? Please suggest a way to solve this. I am just
> >> trying to run a simple rtems-test coverage.
> > For now, I suggest you to use --rtems-bsp=leon3-sis-cov instead of qemu,
> > this is give you the reports and you can start focusing on your main
> ticket.
> Thanks for the suggestion, leon3-sis-cov works, with a minor error as:
> error: copying tree (4):
> /home/user45/quick-start/rtems/5/share/rtems/tester/covoar/covoar.css
> -> /home/user45/quick-start/leon3-sis-coverage/score: [Errno 2] No
> such file or directory:
> '/home/user45/quick-start/rtems/5/share/rtems/tester/covoar/covoar.css'
> This was fixed a few days ago. Please update to the current HEAD of
rtems-tools and
do a `./waf clean build install`
> But the leon3-sis-report.html gives the coverage report. I am still
> studying the leon3-sis-coverage directory.
> Great!
After updating the rtems-tools, go for a full samples directory run.
(just replace the /path/to/samples/hello.exe in your command with
/path/to/samples/ )
> On a sidenote I see that you worked on this as your gsoc project.
> Please mention any source which proved to be helpful in understanding
> rtems better.
docs (docs.rtems.org) is the best place to know about rtems and in case of
any doubt, you can always post to the users@ and devel@ lists, the community
is very helpful and welcoming :)
Also, for coverage analysis, the wiki page that you found, has almost all
the information
that I could collect regarding stuff related to rtems coverage analysis.
You won't need
so much detailed theory to start the project. Your main focus for ticket
#3515 is how
the tools are generating the reports. You'll soon have to dive into covoar/
to figure out
where it's causing the problem. For individually running the exe files in
covoar, you can
use the command for covoar which is noted on the ticket page of #3515.
Best regards,
Vijay
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200201/e7f4a83b/attachment-0001.html>
