About Beaglebone Black device tree
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Sun Feb 2 17:34:23 UTC 2020
On Sun, Feb 2, 2020 at 9:49 PM Christian Mauderer <list at c-mauderer.de>
wrote:
> On 31/01/2020 17:43, Vijay Kumar Banerjee wrote:
> > On Fri, Jan 31, 2020 at 9:59 PM Christian Mauderer <list at c-mauderer.de
> > <mailto:list at c-mauderer.de>> wrote:
> > On 31/01/2020 17:25, Christian Mauderer wrote:
> > > On 31/01/2020 16:04, Vijay Kumar Banerjee wrote:
> > >> Hi,
> > >> While trying to run an rtems-littlevgl app on BBB, I found that
> > the device
> > >> tree generated from the freebsd source matching the freebsd-org
> > >> HEAD commit doesn't work with the app and framebuffer device fails
> > >> to open. This is most likely due to the changes in the freebsd dts
> > >> sources because of which the overlay isn't working as expected.
> > > If I remember correctly, SD card doesn't work either with a FDT
> > that is
> > > too new.
> > >> I haven't had a detailed look at what's missing and the u-boot
> isn't
> > >> reporting any error in applying the overlay either. I checked
> > that the
> > >> device tree built from freebsd tree matching the following commit
> > >> works:
> > >> 19a6ceb89dbacf74697d493e48c388767126d418
> > > At the moment that's the right one. But that can change if someone
> > > updates libbsd again.
> > And I have to correct myself: That is not the right one. The current
> > libbsd HEAD should work with
> 6b0307a0a5184339393f555d5d424190d8a8277a.
> > I meant to say that the framebuffer doesn't work with the current HEAD
> > (6b0307).
> > I checked with a previous commit, which is 19a6ce and found it working.
> > I should have been clear in the problem statement, sorry about that.
> Thats not good. But the correct way would be to find out what's wrong
> and fix it. Did they add a fix in a future FreeBSD version?
> Most likely the overlay isn't working as expected. I'll have to have a
detailed
look to figure out what's going on there.
> > >> This brings up two questions:
> > >> 1. Should we add the commit hash in the user manual so that the
> > user can
> > >> build
> > >> from source matching that commits instead of HEAD. This can
> be a
> > >> problem
> > >> as other codes ported from freebsd might break if the device
> tree
> > >> doesn't
> > >> match the HEAD commit of freebsd-org
> > > Adding a fixed commit id isn't really a good idea either. It is
> nearly
> > > guaranteed that no one updates it if libbsd is updated. It would be
> > > better to add instructions how to find out which commit should be
> > used.
> > The command would be:
> > git ls-files -s freebsd-org
> > It works regardless whether the sub-module is initialized or not.
> > >> 2. How do we manage the device tree overlays required by RTEMS or
> > libbsd?
> > >> I guess only BBB uses an overlay currently. Can we add a BSD
> > license to
> > >> the overlay and add it somewhere in rtems or rtems-libbsd
> > repository and
> > >> maintain it?
> > > I think you wrote the overlay so you can add any license you want.
> But
> > > I'm really not sure where to put it. We currently don't have a
> > location
> > > for that. Do you have a good suggestion?
> > How about rtemsbsd/sys/dts/arm/overlays ?
> > Following the freebsd tree freebsd/sys/dts/arm/overlays/
> Following the FreeBSD tree is a good point. But would they be visible
> there? Beneath that: We currently don't have support for building the
> overlays. Do you have an idea how that could look like?
> keeping it visible will be a problem. For building the overlay, we can use
dtc
and add a script to build the overlay. I see that rsb has a build package
for
devel/dtc.bset as well.
> Best regards
> Christian
> > > Best regards
> > > Christian
> > >> Best regards,
> > >> Vijay>
> > >> _______________________________________________
> > >> devel mailing list
> > >> devel at rtems.org <mailto:devel at rtems.org>
> > >> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200202/c8febfa9/attachment.html>
