[PATCH v2 00/10] Rework work area initialization
Mon Feb 3 06:35:51 UTC 2020
----- Am 3. Feb 2020 um 7:10 schrieb Chris Johns chrisj at rtems.org:
> On 3/2/20 4:27 pm, Sebastian Huber wrote:
>> ----- Am 3. Feb 2020 um 0:01 schrieb Chris Johns chrisj at rtems.org:
>>> On 3/2/20 12:28 am, Sebastian Huber wrote:
>>> I am not sure what the "demand" is and where it is coming from.
>> Currently, the workspace and C program heap area always initialized.  With this
>> patch, they are only initialized if they are used. So, a future application
>> which only uses statically allocated resources, will not have the heap handler
>> in its executable.
> Is the reason why and approach for making a fully static application documented
> anywhere? How will a user know this exists?
I work on this for a couple of years. It is a series of lots of small steps. The first major step was the introduction of self-contained synchronization objects in Newlib in 2015. Once it is done it should be documented the Classic API Guide maybe under Key Concepts.
> I assume this helps low memory targets?
Yes, it helps low memory targets, debugging, and applications which don't need dynamic memory at all.
