V5.x porting guide or prototypical example?
Joel Sherrill
joel at rtems.org
Mon Feb 3 22:25:25 UTC 2020
On Sun, Feb 2, 2020 at 11:39 PM Sebastian Huber <
> Hello Andrei,
> ----- Am 3. Feb 2020 um 4:14 schrieb groups at chichak.ca:
> > \Good day,
> > A while back I put together a BSP for STM32F7 based on the STM32F407 BSP
> for an
> > early version of RTEMS 5.
> > Now that RTEMS 5 became 5.0, the BSP structure has moved around quite a
> bit and
> > I need to redo my BSP.
> > Is there a porting guide for 5.0 yet, or is there a shining example of a
> BSP
> > that I should emulate?
> unfortunately, there is no porting guide available. We discuss currently
> the introduction of a new build system. If it is not very urgent, then I
> would wait a bit with the porting.
> You can also start right now and use the stm32f4 BSP as an example. The
> relevant directories are:
> bsps/arm/stm32f4 (sources)
> c/src/lib/libbsp/arm/stm32f4 (build system)
It isn't too bad Andrei. libcpu and libchip are now in bsps/shared. There
is a single
bsps/include and the Makefile.am just lists files.
If you have questions, just ask.
--joel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200203/731282c4/attachment.html>
