[rtems-docs PATCH v2] user/testing: Add coverage analysis instructions
Gedare Bloom
gedare at rtems.org
Mon Feb 3 23:26:46 UTC 2020
looks OK to me.
On Mon, Feb 3, 2020 at 3:06 AM Vijay Kumar Banerjee
<vijaykumar9597 at gmail.com> wrote:
> user/testing/coverage.rst | 68 +++++++++++++++++++++++++++++++++++++++
> user/testing/index.rst | 1 +
> 2 files changed, 69 insertions(+)
> create mode 100644 user/testing/coverage.rst
> diff --git a/user/testing/coverage.rst b/user/testing/coverage.rst
> new file mode 100644
> index 0000000..4f2266e
> --- /dev/null
> +++ b/user/testing/coverage.rst
> @@ -0,0 +1,68 @@
> +.. SPDX-License-Identifier: CC-BY-SA-4.0
> +.. Copyright (C) 2019 Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
> +Coverage Analysis
> +RTEMS is used in many critical systems. It is important that the RTEMS Project
> +ensure that the RTEMS product is tested as thoroughly as possible. With this
> +goal in mind, the RTEMS test suite was expanded with the goal that 100% of the
> +RTEMS executive is tested.
> +RTEMS-TESTER takes the following arguments to produce coverage reports:
> +`--coverage :`
> + When the coverage option is enabled the tester produces coverage reports for
> + all the symbols in cpukit. To generate a coverage report for a specific
> + symbol-set ( e.g.: score) the symbol-set is passed as an argument to the
> + option, e.g.: --coverage=score.
> +`--no-clean :`
> + Tells the script not to delete the .cov trace files generated while running
> + the coverage. These trace files are used for debugging purposes and will not
> + be needed for a normal user.
> +For example: To generate a coverage report of hello.exe for leon3 on SIS, the
> +following command is used:
> +.. code-block:: none
> + rtems-test \
> + --rtems-tools=$HOME/development/rtems/5 \
> + --log=coverage_analysis.log \
> + --no-clean \
> + --coverage \
> + --rtems-bsp=leon3-sis-cov \
> + $HOME/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/samples/hello.exe
> +The command will create the coverage report in the following tree structure:
> + ├── coverage_analysis.log
> + ├── leon3-sis-coverage
> + │ └── score
> + │ ├── annotated.html
> + │ ├── annotated.txt
> + │ ├── branch.html
> + │ ├── branch.txt
> + │ ├── covoar.css
> + │ ├── ExplanationsNotFound.txt
> + │ ├── index.html
> + │ ├── no_range_uncovered.html
> + │ ├── no_range_uncovered.txt
> + │ ├── NotReferenced.html
> + │ ├── sizes.html
> + │ ├── sizes.txt
> + │ ├── summary.txt
> + │ ├── symbolSummary.html
> + │ ├── symbolSummary.txt
> + │ ├── table.js
> + │ ├── uncovered.html
> + │ └── uncovered.txt
> + └── leon3-sis-report.html
> +The html on top of the directory, i.e., leon3-sis-report.html is the top level
> +navigation for the coverage analysis report and will let the user browse through
> +all the generated reports from different subsystems.
> diff --git a/user/testing/index.rst b/user/testing/index.rst
> index a938af4..3d36fab 100644
> --- a/user/testing/index.rst
> +++ b/user/testing/index.rst
> @@ -43,6 +43,7 @@ extension.
> tests
> configuration
> + coverage
> consoles
> simulation
> gdb-jtag
> 2.21.1
