[PATCH] sysinit: Add RTEMS_SYSINIT_ZERO_MEMORY
Tue Feb 4 13:15:31 UTC 2020
Use a dedicate system initialization step to zero the memory used for
the workspace and C program heap.
This avoids dead code in case CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY is
not configured.
 cpukit/Makefile.am                     |  2 ++
 cpukit/include/rtems/confdefs.h        | 15 +++++++++-----
 cpukit/include/rtems/config.h          | 11 ++--------
 cpukit/include/rtems/score/memory.h    | 13 ++++++++++++
 cpukit/include/rtems/sysinit.h         |  3 ++-
 cpukit/sapi/src/sysinitverbose.c       | 10 ++++++++-
 cpukit/score/src/memoryzerobeforeuse.c | 34 +++++++++++++++++++++++++++++++
 cpukit/score/src/memoryzerofreeareas.c | 37 ++++++++++++++++++++++++++++++++++
 cpukit/score/src/wkspace.c             |  6 ------
 testsuites/sptests/sp54/init.c         |  2 ++
 10 files changed, 111 insertions(+), 22 deletions(-)
 create mode 100644 cpukit/score/src/memoryzerobeforeuse.c
 create mode 100644 cpukit/score/src/memoryzerofreeareas.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 2bfa2ddabd..b9ab123b49 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -854,6 +854,8 @@ librtemscpu_a_SOURCES += score/src/heapgreedy.c
 librtemscpu_a_SOURCES += score/src/heapnoextend.c
 librtemscpu_a_SOURCES += score/src/memoryallocate.c
 librtemscpu_a_SOURCES += score/src/memoryfill.c
+librtemscpu_a_SOURCES += score/src/memoryzerobeforeuse.c
+librtemscpu_a_SOURCES += score/src/memoryzerofreeareas.c
 librtemscpu_a_SOURCES += score/src/objectallocate.c
 librtemscpu_a_SOURCES += score/src/objectclose.c
 librtemscpu_a_SOURCES += score/src/objectextendinformation.c
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index 7d0d3fbeab..982e3ddb56 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -2778,11 +2778,6 @@ struct _reent *__getreent(void)
     CONFIGURE_TASK_STACK_ALLOCATOR_INIT,      /* stack allocator init */
     CONFIGURE_TASK_STACK_ALLOCATOR,           /* stack allocator */
     CONFIGURE_TASK_STACK_DEALLOCATOR,         /* stack deallocator */
-    #ifdef CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY /* true to clear memory */
-      true,
-    #else
-      false,
-    #endif
     #ifdef CONFIGURE_UNIFIED_WORK_AREAS       /* true for unified work areas */
       true,
     #else
@@ -2807,6 +2802,16 @@ struct _reent *__getreent(void)
     #endif
+  #ifdef CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY
+    const bool _Memory_Zero_before_use = true;
+    RTEMS_SYSINIT_ITEM(
+      _Memory_Zero_free_areas,
+      RTEMS_SYSINIT_ZERO_MEMORY,
+      RTEMS_SYSINIT_ORDER_MIDDLE
+  #endif
   #if CONFIGURE_RECORD_PER_PROCESSOR_ITEMS > 0
     #if (CONFIGURE_RECORD_PER_PROCESSOR_ITEMS & (CONFIGURE_RECORD_PER_PROCESSOR_ITEMS - 1)) != 0
       #error "CONFIGURE_RECORD_PER_PROCESSOR_ITEMS must be a power of two"
diff --git a/cpukit/include/rtems/config.h b/cpukit/include/rtems/config.h
index 15e944dd2f..fac5c6e009 100644
--- a/cpukit/include/rtems/config.h
+++ b/cpukit/include/rtems/config.h
@@ -29,6 +29,7 @@
 #include <rtems/score/isr.h>
+#include <rtems/score/memory.h>
 #include <rtems/score/userextdata.h>
 #include <rtems/score/watchdogticks.h>
 #include <rtems/rtems/config.h>
@@ -148,14 +149,6 @@ typedef struct {
   rtems_stack_free_hook          stack_free_hook;
-   * If this element is TRUE, then RTEMS will zero the Executive Workspace.
-   * When this element is FALSE, it is assumed that the BSP or invoking
-   * environment has ensured that memory was cleared before RTEMS was
-   * invoked.
-  bool                           do_zero_of_workspace;
    * @brief Specifies if a unified work area is used or not.
@@ -241,7 +234,7 @@ uint32_t rtems_configuration_get_maximum_extensions( void );
   * RTEMS is responsible for zeroing the Executive Workspace.
 #define rtems_configuration_get_do_zero_of_workspace() \
-   (Configuration.do_zero_of_workspace)
+  _Memory_Zero_before_use
 #define rtems_configuration_get_number_of_initial_extensions() \
   ((uint32_t) _User_extensions_Initial_count)
diff --git a/cpukit/include/rtems/score/memory.h b/cpukit/include/rtems/score/memory.h
index f26c7f4031..ffc4897ed5 100644
--- a/cpukit/include/rtems/score/memory.h
+++ b/cpukit/include/rtems/score/memory.h
@@ -331,6 +331,19 @@ void *_Memory_Allocate(
 void _Memory_Fill( const Memory_Information *information, int c );
+ * @brief Indicates if the memory is zeroed during system initialization.
+ * This value is provided via <rtems/confdefs.h> in case
+ * CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY is defined.
+extern const bool _Memory_Zero_before_use;
+ * @brief Zeros all free memory areas of the system.
+void _Memory_Zero_free_areas( void );
 #ifdef __cplusplus
diff --git a/cpukit/include/rtems/sysinit.h b/cpukit/include/rtems/sysinit.h
index 58f35542b7..d181c42780 100644
--- a/cpukit/include/rtems/sysinit.h
+++ b/cpukit/include/rtems/sysinit.h
@@ -1,5 +1,5 @@
- * Copyright (c) 2015, 2018 embedded brains GmbH.  All rights reserved.
+ * Copyright (c) 2015, 2020 embedded brains GmbH.  All rights reserved.
  *  embedded brains GmbH
  *  Dornierstr. 4
@@ -30,6 +30,7 @@ extern "C" {
 #define RTEMS_SYSINIT_BSP_EARLY                  000140
 #define RTEMS_SYSINIT_MEMORY                     000180
 #define RTEMS_SYSINIT_DIRTY_MEMORY               0001c0
+#define RTEMS_SYSINIT_ZERO_MEMORY                0001e0
 #define RTEMS_SYSINIT_ISR_STACK                  000200
 #define RTEMS_SYSINIT_PER_CPU_DATA               000220
 #define RTEMS_SYSINIT_SBRK                       000240
diff --git a/cpukit/sapi/src/sysinitverbose.c b/cpukit/sapi/src/sysinitverbose.c
index 4fe936766b..7c8db2e5eb 100644
--- a/cpukit/sapi/src/sysinitverbose.c
+++ b/cpukit/sapi/src/sysinitverbose.c
@@ -48,6 +48,7 @@ RTEMS_LINKER_RWSET_ITEM_DECLARE(
 SYSINIT_VERBOSE( BSP_EARLY );
 SYSINIT_VERBOSE( MEMORY );
 SYSINIT_VERBOSE( DIRTY_MEMORY );
+SYSINIT_VERBOSE( ZERO_MEMORY );
 SYSINIT_VERBOSE( ISR_STACK );
 SYSINIT_VERBOSE( PER_CPU_DATA );
 SYSINIT_VERBOSE( SBRK );
@@ -192,9 +193,16 @@ static void _Sysinit_Verbose_DIRTY_MEMORY( void )
+static void _Sysinit_Verbose_ZERO_MEMORY( void )
+  if ( !SYSINIT_IS_ADJACENT( DIRTY_MEMORY, ZERO_MEMORY ) ) {
+    printk( "sysinit: ZERO_MEMORY: done\n" );
 static void _Sysinit_Verbose_ISR_STACK( void )
-  if ( !SYSINIT_IS_ADJACENT( DIRTY_MEMORY, ISR_STACK ) ) {
+  if ( !SYSINIT_IS_ADJACENT( ZERO_MEMORY, ISR_STACK ) ) {
     printk( "sysinit: ISR_STACK: done\n" );
diff --git a/cpukit/score/src/memoryzerobeforeuse.c b/cpukit/score/src/memoryzerobeforeuse.c
new file mode 100644
index 0000000000..dd08199223
--- /dev/null
+++ b/cpukit/score/src/memoryzerobeforeuse.c
@@ -0,0 +1,34 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 embedded brains GmbH
+ * are met:
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+const bool _Memory_Zero_before_use;
diff --git a/cpukit/score/src/memoryzerofreeareas.c b/cpukit/score/src/memoryzerofreeareas.c
index 0000000000..28ea84970c
--- /dev/null
+++ b/cpukit/score/src/memoryzerofreeareas.c
@@ -0,0 +1,37 @@
+ * are met:
+#if HAVE_CONFIG_H
+#endif
+  _Memory_Fill( _Memory_Get(), 0 );
diff --git a/cpukit/score/src/wkspace.c b/cpukit/score/src/wkspace.c
index 41c6cd3059..5a87ee4b83 100644
--- a/cpukit/score/src/wkspace.c
+++ b/cpukit/score/src/wkspace.c
@@ -90,7 +90,6 @@ void _Workspace_Handler_initialization(
   Heap_Initialization_or_extend_handler init_or_extend;
   uintptr_t                             remaining;
-  bool                                  do_zero;
   bool                                  unified;
   uintptr_t                             page_size;
   uintptr_t                             overhead;
@@ -101,7 +100,6 @@ void _Workspace_Handler_initialization(
   remaining += _Workspace_Space_for_TLS( page_size );
   init_or_extend = _Heap_Initialize;
-  do_zero = rtems_configuration_get_do_zero_of_workspace();
   unified = rtems_configuration_get_unified_work_area();
   overhead = _Heap_Area_overhead( page_size );
@@ -112,10 +110,6 @@ void _Workspace_Handler_initialization(
     area = _Memory_Get_area( mem, i );
     free_size = _Memory_Get_free_size( area );
-    if ( do_zero ) {
-      memset( _Memory_Get_free_begin( area ), 0, free_size );
     if ( free_size > overhead ) {
       uintptr_t space_available;
       uintptr_t size;
diff --git a/testsuites/sptests/sp54/init.c b/testsuites/sptests/sp54/init.c
index 7bedb46497..c9c8d6fe30 100644
--- a/testsuites/sptests/sp54/init.c
+++ b/testsuites/sptests/sp54/init.c
@@ -50,6 +50,8 @@ static void *Init( uintptr_t ignored )
   fatal_directive_status( status, RTEMS_INVALID_NAME, "rtems_task_ident" );
+  rtems_test_assert( rtems_configuration_get_do_zero_of_workspace() );
   TEST_END();
   rtems_test_exit(0);
2.16.4
