sysinit test failure to link psim
Amar Takhar
amar at rtems.org
Tue Feb 4 19:02:19 UTC 2020
Found by Buildbot here!
https://buildbot.rtems.org/#/builders/19/builds/47
FYI if anyone does want to make a quick check to see if the error is
reproducible Buildbot creates a snapshot with bootstrap already run on every
build for example for this build:
https://buildbot.rtems.org/#/builders/4/builds/814
It's always the 'snapshot-test' and if all the current builds work we get a
'snapshot-stable' which is stable for all builds that have been done.
Amar.
