Fwd: Buildbot failure in RTEMS on CHECK sparc/erc32 FreeBSD 10.1-STABLE GCC 7.3.0 POSIX
Wed Feb 5 06:42:31 UTC 2020
Hello,
this looks like Buildbot is using out of date tools. How are tool
updates (via RSB) triggered for the Buildbot machines?
-------- Forwarded Message --------
Subject: 	Buildbot failure in RTEMS on CHECK sparc/erc32 FreeBSD
Date: 	Tue, 04 Feb 2020 06:08:54 +0000
To: 	build at rtems.org
The Buildbot has detected a failed build on builder CHECK sparc/erc32
FreeBSD 10.1-STABLE GCC 7.3.0 POSIX while building rtems.
Full details are available at:
https://buildbot.rtems.org/#builders/20/builds/54
Buildbot URL: https://buildbot.rtems.org/
Worker for this Build: build-1
Build Reason: <unknown>
Blamelist: Martin Erik Werner <martinerikwerner at gmail.com>, Sebastian
Huber <sebastian.huber at embedded-brains.de>
BUILD FAILED: make (failure)
Sincerely,
-The Buildbot
build mailing list
build at rtems.org
http://lists.rtems.org/mailman/listinfo/build
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200205/68da63a5/attachment.html>
