[PATCH] c-user: Document new linker set macros
Sebastian Huber
Wed Feb 5 08:05:56 UTC 2020
Close #3865.
c-user/linker_sets.rst | 66 +++++++++++++++++++++++++++++++++++++++-----------
1 file changed, 52 insertions(+), 14 deletions(-)
diff --git a/c-user/linker_sets.rst b/c-user/linker_sets.rst
index f22c7bc..b02e290 100644
--- a/c-user/linker_sets.rst
+++ b/c-user/linker_sets.rst
@@ -41,6 +41,8 @@ The following macros are provided to create, populate and use linker sets.
- RTEMS_LINKER_ROSET_ITEM_DECLARE_ - Declares a read-only linker set item
+- RTEMS_LINKER_ROSET_ITEM_ORDERED_DECLARE_ - Declares an ordered read-only linker set item
- RTEMS_LINKER_ROSET_ITEM_REFERENCE_ - References a read-only linker set item
- RTEMS_LINKER_ROSET_ITEM_ - Defines a read-only linker set item
@@ -55,6 +57,8 @@ The following macros are provided to create, populate and use linker sets.
- RTEMS_LINKER_RWSET_ITEM_DECLARE_ - Declares a read-write linker set item
+- RTEMS_LINKER_RWSET_ITEM_ORDERED_DECLARE_ - Declares an ordered read-write linker set item
- RTEMS_LINKER_RWSET_ITEM_REFERENCE_ - References a read-write linker set item
- RTEMS_LINKER_RWSET_ITEM_ - Defines a read-write linker set item
@@ -346,13 +350,30 @@ CALLING SEQUENCE:
DESCRIPTION:
This macro generates a declaration of an item contained in the read-only
- linker set identified by ``set``. The ``set`` parameter itself must be a
- valid C designator on which no macro expansion is performed. It uniquely
- identifies the linker set. The ``type`` parameter defines the type of the
- linker set items. The type must be the same for all macro invocations of a
- particular linker set. The ``item`` parameter itself must be a valid C
- designator on which no macro expansion is performed. It uniquely
- identifies an item in the linker set.
+ linker set identified by ``set``. For a description of the ``set``,
+ ``type``, and ``item`` parameters see :ref:`RTEMS_LINKER_ROSET_ITEM`.
+.. raw:: latex
+ \clearpage
+.. index:: RTEMS_LINKER_ROSET_ITEM_ORDERED_DECLARE
+.. _RTEMS_LINKER_ROSET_ITEM_ORDERED_DECLARE:
+RTEMS_LINKER_ROSET_ITEM_ORDERED_DECLARE - Declares an ordered read-only linker set item
+CALLING SEQUENCE:
+ .. code-block:: c
+ RTEMS_LINKER_ROSET_ITEM_ORDERED_DECLARE( set, type, item, order );
+DESCRIPTION:
+ This macro generates a declaration of an ordered item contained in the
+ read-only linker set identified by ``set``. For a description of the
+ ``set``, ``type``, ``item``, and ``order`` parameters see
+ :ref:`RTEMS_LINKER_ROSET_ITEM_ORDERED`.
.. raw:: latex
@@ -553,13 +574,30 @@ CALLING SEQUENCE:
DESCRIPTION:
This macro generates a declaration of an item contained in the read-write
+ ``type``, and ``item`` parameters see :ref:`RTEMS_LINKER_RWSET_ITEM`.
+.. raw:: latex
+ \clearpage
+.. index:: RTEMS_LINKER_RWSET_ITEM_ORDERED_DECLARE
+.. _RTEMS_LINKER_RWSET_ITEM_ORDERED_DECLARE:
+RTEMS_LINKER_RWSET_ITEM_ORDERED_DECLARE - Declares an ordered read-write linker set item
+CALLING SEQUENCE:
+ .. code-block:: c
+ RTEMS_LINKER_RWSET_ITEM_ORDERED_DECLARE( set, type, item, order );
+DESCRIPTION:
+ read-write linker set identified by ``set``. For a description of the
+ :ref:`RTEMS_LINKER_RWSET_ITEM_ORDERED`.
.. raw:: latex
2.16.4
