Enabling Buildbot 'responsible user' emails.
Amar Takhar
amar at rtems.org
Thu Feb 6 06:35:34 UTC 2020
On 2020-02-06 07:19 +0100, Christian Mauderer wrote:
<snip>
> Someone applied a FreeBSD patch directly to libbsd (which works well).
> In that case git noted that the original author is in the "from" header
> and send him an email that his patch has been applied. He was a bit
> astonished to receive that mail.
Yes, that was due to trac I wrote a plugin that will strictly only email members
of our trac instance. It was due to the git ticket updater putting his name
directly as a 'commenter' on the ticket via the database. Then when the ticket
was updated he was getting emails.
> Most likely it's a lot harder to construct a similar situation for the
> RTEMS core repository. But I wouldn't entirely rule it out. Is there
> some possibility to avoid such mails or do we just accept that in the
> worst case someone unrelated receives mails?
I'll look into it to make sure nothing has changed in regards to this but it's
possible that Buildbot could email anyone in the Author list if the patches were
pulled out directly from a repository.
Amar.
