[PATCH 1/2] eng: Document test framework formatted output
Sebastian Huber
Sun Feb 9 10:20:28 UTC 2020
Update #3199.
eng/test-framework.rst | 30 +++++++++++++++++++++++-------
1 file changed, 23 insertions(+), 7 deletions(-)
diff --git a/eng/test-framework.rst b/eng/test-framework.rst
index 50745df..6380f7e 100644
--- a/eng/test-framework.rst
+++ b/eng/test-framework.rst
@@ -982,10 +982,10 @@ fails.
P:0:0:UI1:test-psx.c:13
E:stat:N:1:F:0
-Custom Log Messages
+Log Messages and Formatted Output
-You can print custom log messages with the `T_log()` function:
+You can print log messages with the `T_log()` function:
.. code-block:: c
@@ -994,24 +994,40 @@ You can print custom log messages with the `T_log()` function:
A newline is automatically added to terminate the log message line.
.. code-block:: c
- :caption: Custom Log Message Example
+ :caption: Log Message Example
#include <t.h>
T_TEST_CASE(log)
- T_log(T_NORMAL, "a custom message %i, %i, %i", 1, 2, 3);
+ T_log(T_NORMAL, "a log message %i, %i, %i", 1, 2, 3);
T_set_verbosity(T_QUIET);
T_log(T_NORMAL, "not verbose enough");
.. code-block:: none
- :caption: Custom Log Message Report
+ :caption: Log Message Report
B:log
- L:a custom message 1, 2, 3
+ L:a log message 1, 2, 3
E:log:N:0:F:0
+You can use the following functions to print formatted output:
+.. code-block:: c
+ int T_printf(char const *, ...);
+ int T_vprintf(char const *, va_list);
+ int T_snprintf(char *, size_t, const char *, ...);
+In contrast to the corresponding standard C library functions, floating-point
+and exotic formats may be not supported. On some architectures supported by
+RTEMS, floating-point operations are only supported in special tasks and may be
+forbidden in interrupt context. These formatted output functions work in every
+context.
Time Services
2.16.4
