About Beaglebone Black device tree
Christian Mauderer list at c-mauderer.de
Sun Feb 9 10:33:29 UTC 2020
On 07/02/2020 18:23, Vijay Kumar Banerjee wrote:
> On Mon, Feb 3, 2020 at 7:21 PM Christian Mauderer
> <christian.mauderer at embedded-brains.de
> <mailto:christian.mauderer at embedded-brains.de>> wrote:
>     On 02/02/2020 18:34, Vijay Kumar Banerjee wrote:
>     > On Sun, Feb 2, 2020 at 9:49 PM Christian Mauderer
>     <list at c-mauderer.de <mailto:list at c-mauderer.de>
>     > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
>     >     On 31/01/2020 17:43, Vijay Kumar Banerjee wrote:
>     >     > On Fri, Jan 31, 2020 at 9:59 PM Christian Mauderer
>     >     > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>> wrote:
>     >     >     On 31/01/2020 17:25, Christian Mauderer wrote:
>     >     >     > On 31/01/2020 16:04, Vijay Kumar Banerjee wrote:
>     >     >     >> Hi,
>     >     >     >> While trying to run an rtems-littlevgl app on BBB, I
>     found that
>     >     >     the device
>     >     >     >> tree generated from the freebsd source matching the
>     freebsd-org
>     >     >     >> HEAD commit doesn't work with the app and framebuffer
>     >     device fails
>     >     >     >> to open. This is most likely due to the changes in the
>     >     freebsd dts
>     >     >     >> sources because of which the overlay isn't working as
>     expected.
>     >     >     > If I remember correctly, SD card doesn't work either
>     with a FDT
>     >     >     that is
>     >     >     > too new.
>     >     >     >> I haven't had a detailed look at what's missing and the
>     >     u-boot isn't
>     >     >     >> reporting any error in applying the overlay either. I
>     checked
>     >     >     that the
>     >     >     >> device tree built from freebsd tree matching the
>     >     following commit
>     >     >     >> works:
>     >     >     >> 19a6ceb89dbacf74697d493e48c388767126d418
>     >     >     > At the moment that's the right one. But that can change if
>     >     someone
>     >     >     > updates libbsd again.
>     >     >     And I have to correct myself: That is not the right one. The
>     >     current
>     >     >     libbsd HEAD should work with
>     >     6b0307a0a5184339393f555d5d424190d8a8277a.
>     >     > I meant to say that the framebuffer doesn't work with the
>     current HEAD
>     >     > (6b0307).
>     >     > I checked with a previous commit, which is 19a6ce and found it
>     >     working.
>     >     > I should have been clear in the problem statement, sorry
>     about that.
>     >     Thats not good. But the correct way would be to find out
>     what's wrong
>     >     and fix it. Did they add a fix in a future FreeBSD version?
>     > Most likely the overlay isn't working as expected. I'll have to have a
>     > detailed
>     > look to figure out what's going on there.
> Hi!
> I looked into it in more detail, the issue isn't with the overlay, I
> verified it
> using u-boot fdt tool as well. Looks like the base dts file is producing
> a lot
> of "target-module" and during startup, the driver probes are looping over
> these target modules for the device tree values instead of looking at the
> device node under the target module.
> For example, in case of i2c the device tree looks like this:
>                 target-module at b000 {
>                     status = "okay";
>                     compatible = "ti,sysc-omap2\0ti,sysc";
>                     i2c at 0 {
>                         rtems-pinctrl-0 = < 0x2e >;
>                         rtems,i2c-path = "/dev/i2c-0";
>                         compatible = "rtems,bsp-i2c\0ti,omap4-i2c";
> In the above snippet, the probe function expects the compat value to be
> "rtems,bsp-i2c" but is getting "ti,sysc-omap2" from the target-module
> and returning ENXIO. This is true for all the values, not just compat.
> When I added all the required values of i2c into the target-module through
> overlay, the iicbus worked. As you said in the thread, looks like i2c
> isn't the
> only device that's affected looks like a lot of devices are failing
> because of
> this dts issue. Here's a dump
> <https://paste.ofcode.org/iDKusQxibBXCLMVJb6KG6q> of start messages
> after applying the overlay
> hack for i2c and lcd probe. (Note that this is an issue with the
> tda19988 as well,
> because of which framebuffer isn't working)
Did something in the FreeBSD device tree sources change to cause that issue?
>     >     >     >> This brings up two questions:
>     >     >     >> 1. Should we add the commit hash in the user manual
>     so that the
>     >     >     user can
>     >     >     >> build
>     >     >     >>     from source matching that commits instead of
>     HEAD. This
>     >     can be a
>     >     >     >> problem
>     >     >     >>     as other codes ported from freebsd might break if the
>     >     device tree
>     >     >     >> doesn't
>     >     >     >>     match the HEAD commit of freebsd-org
>     >     >     > Adding a fixed commit id isn't really a good idea
>     either. It
>     >     is nearly
>     >     >     > guaranteed that no one updates it if libbsd is updated. It
>     >     would be
>     >     >     > better to add instructions how to find out which commit
>     >     should be
>     >     >     used.
>     >     >     The command would be:
>     >     >         git ls-files -s freebsd-org
>     >     >     It works regardless whether the sub-module is
>     initialized or not.
>     >     >     >> 2. How do we manage the device tree overlays required by
>     >     RTEMS or
>     >     >     libbsd?
>     >     >     >>     I guess only BBB uses an overlay currently. Can
>     we add
>     >     a BSD
>     >     >     license to
>     >     >     >>     the overlay and add it somewhere in rtems or
>     rtems-libbsd
>     >     >     repository and
>     >     >     >>     maintain it?
>     >     >     > I think you wrote the overlay so you can add any
>     license you
>     >     want. But
>     >     >     > I'm really not sure where to put it. We currently
>     don't have a
>     >     >     location
>     >     >     > for that. Do you have a good suggestion?
>     >     > How about rtemsbsd/sys/dts/arm/overlays ?
>     >     > Following the freebsd tree freebsd/sys/dts/arm/overlays/
>     >     Following the FreeBSD tree is a good point. But would they be
>     visible
>     >     there? Beneath that: We currently don't have support for
>     building the
>     >     overlays. Do you have an idea how that could look like?
>     > keeping it visible will be a problem. For building the overlay, we can
>     > use dtc
>     > and add a script to build the overlay. I see that rsb has a build
>     > package for
>     > devel/dtc.bset as well.
>     Hm. Optimal would be an integration into waf. Something like "waf
>     fdt-overlay". Even better would be if we could build the original fdt
>     too. But I'm sure that both would be quite a bit tricky to integrate
>     (the waf scripts in libbsd are not really easy to understand). So I'm
>     not insisting on that.
> Sounds like it can become a good small project. Do we want a ticket
> for this?
I think it's a bit too small for a GSoC project but it could be a
starting point for someone who wants to get knowledge about the libbsd
build system. So: Yes, a ticket sounds good.
>     >     Best regards
>     >     Christian
>     >     >     > Best regards
>     >     >     > Christian
>     >     >     >> Best regards,
>     >     >     >> Vijay>
>     >     >     >> _______________________________________________
>     >     >     >> devel mailing list
>     >     >     >> devel at rtems.org <mailto:devel at rtems.org>
>     <mailto:devel at rtems.org <mailto:devel at rtems.org>>
>     <mailto:devel at rtems.org <mailto:devel at rtems.org>>>
>     >     >     >> http://lists.rtems.org/mailman/listinfo/devel
>     > devel mailing list
>     embedded brains GmbH
>     Herr Christian Mauderer
>     Dornierstr. 4
>     D-82178 Puchheim
>     Germany
>     email: christian.mauderer at embedded-brains.de
>     Phone: +49-89-18 94 741 - 18
>     Fax:   +49-89-18 94 741 - 08
>     PGP: Public key available on request.
>     Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
