[PATCH v3 2/2] bsp/raspberrypi: Mini UART driver
G S Niteesh gsnb.gn at gmail.com
Sun Feb 9 19:21:44 UTC 2020
This patch adds driver for Mini UART present in Raspberry Pi 3
and above, this UART is currently used as the primary UART in
these models.
The Mini UART is similar to ns16550, this driver is built
upon libchip/ns16550.
 bsps/arm/raspberrypi/console/console-config.c | 118 ++++++++++++++++--
 bsps/arm/raspberrypi/include/bsp/usart.h      |   1 +
 2 files changed, 110 insertions(+), 9 deletions(-)
diff --git a/bsps/arm/raspberrypi/console/console-config.c b/bsps/arm/raspberrypi/console/console-config.c
index 48c4c6a3ec..62196786dd 100644
--- a/bsps/arm/raspberrypi/console/console-config.c
+++ b/bsps/arm/raspberrypi/console/console-config.c
@@ -24,6 +24,7 @@
 #include <libchip/serial.h>
 #include <libfdt.h>
+#include <libchip/ns16550.h>
 #include <bspopts.h>
 #include <bsp/usart.h>
@@ -34,35 +35,103 @@
 #include <bsp/console-termios.h>
 #include <bsp/fdt.h>
 #include <bsp/fatal.h>
+#include <bsp/gpio.h>
+#include <bsp/rpi-gpio.h>
-#define UART0     "/dev/ttyS0"
+ * UART0 - PL011
+ * UART1 - Mini UART
+#define PL011     "/dev/ttyAMA0"
+#define MINIUART  "/dev/ttyS0"
 #define FBCONS    "/dev/fbcons"
 arm_pl011_context pl011_context;
+ns16550_context mini_uart_context;
 rpi_fb_context fb_context;
-static void output_char_serial(char c)
+static void output_char_pl011(char c)
   arm_pl011_write_polled(&pl011_context.base, c);
+static void output_char_mini_uart(char c)
+  ns16550_polled_putchar(&mini_uart_context.base, c);
 void output_char_fb(char c)
   fbcons_write_polled(&fb_context.base, c);
+static uint8_t mini_uart_get_reg(uintptr_t port, uint8_t index)
+  volatile uint32_t *val = (volatile uint32_t *)port + index;
+  return (uint8_t) *val;
+static void mini_uart_set_reg(uintptr_t port, uint8_t index, uint8_t val)
+  volatile uint32_t *reg = (volatile uint32_t *)port + index;
+  *reg = val;
 static void init_ctx_arm_pl011(
   const void *fdt,
   int node
   arm_pl011_context *ctx = &pl011_context;
-  rtems_termios_device_context_initialize(&ctx->base, "UART");
+  rtems_termios_device_context_initialize(&ctx->base, "PL011UART");
   ctx->regs = raspberrypi_get_reg_of_node(fdt, node);
+static uint32_t calculate_baud_divisor(
+  ns16550_context *ctx,
+  uint32_t baud
+  uint32_t baudDivisor = (ctx->clock / (8 * baud)) - 1;
+  return baudDivisor;
+static void init_ctx_mini_uart(
+  const void *fdt,
+  int node
+  const char *status;
+  int len;
+  ns16550_context *ctx;
+  memset(&mini_uart_context, 0, sizeof(mini_uart_context));
+  ctx = &mini_uart_context;
+  rtems_termios_device_context_initialize(&ctx->base, "MiniUART");
+  status = fdt_getprop(fdt, node, "status", &len);
+  if ( status == NULL || strcmp(status, "disabled" ) == 0){
+    return ;
+  ctx->port = (uintptr_t) raspberrypi_get_reg_of_node(fdt, node);
+  ctx->initial_baud = MINI_UART_DEFAULT_BAUD;
+  ctx->clock = BCM2835_CLOCK_FREQ;
+  ctx->calculate_baud_divisor = calculate_baud_divisor;
+  ctx->get_reg = mini_uart_get_reg;
+  ctx->set_reg = mini_uart_set_reg;
+  rtems_gpio_bsp_select_specific_io(0, 14, RPI_ALT_FUNC_5, NULL);
+  rtems_gpio_bsp_select_specific_io(0, 15, RPI_ALT_FUNC_5, NULL);
+  rtems_gpio_bsp_set_resistor_mode(0, 14, NO_PULL_RESISTOR);
+  rtems_gpio_bsp_set_resistor_mode(0, 15, NO_PULL_RESISTOR);
+  BCM2835_REG(AUX_ENABLES) |= 0x1;
+  ns16550_probe(&ctx->base);
 static void register_fb( void )
   if (fbcons_probe(&fb_context.base) == true) {
@@ -87,16 +156,28 @@ static void console_select( void )
         link(FBCONS, CONSOLE_DEVICE_NAME);
         return ;
+    } else if ( strncmp( opt, MINIUART, sizeof(MINIUART) - 1 ) == 0) {
+      BSP_output_char = output_char_mini_uart;
+      link(MINIUART, CONSOLE_DEVICE_NAME);
+    } else if ( strncmp( opt, PL011, sizeof(PL011) - 1 ) == 0) {
+      BSP_output_char = output_char_pl011;
+      link(PL011, CONSOLE_DEVICE_NAME);
+  }else {
+     * If no command line option was given, default to PL011.
-  BSP_output_char = output_char_serial;
-  link(UART0, CONSOLE_DEVICE_NAME);
 static void uart_probe(void)
   static bool initialized = false;
   const void *fdt;
+  const char *console;
+  int len;
   int node;
   if ( initialized ) {
@@ -104,17 +185,29 @@ static void uart_probe(void)
   fdt = bsp_fdt_get();
-  node = fdt_node_offset_by_compatible(fdt, -1, "brcm,bcm2835-pl011");
+  node = fdt_node_offset_by_compatible(fdt, -1, "brcm,bcm2835-pl011");
   init_ctx_arm_pl011(fdt, node);
+  node = fdt_node_offset_by_compatible(fdt, -1, "brcm,bcm2835-aux-uart");
+  init_ctx_mini_uart(fdt, node);
+  node = fdt_path_offset(fdt, "/aliases");
+  console = fdt_getprop(fdt, node, "serial0", &len);
+  if ( strcmp(console, "/soc/serial at 7e215040" ) == 0) {
+  }else {
   initialized = true;
 static void output_char(char c)
   uart_probe();
-  output_char_serial(c);
+  (*BSP_output_char)(c);
 rtems_status_code console_initialize(
@@ -127,12 +220,19 @@ rtems_status_code console_initialize(
   uart_probe();
   rtems_termios_device_install(
-    UART0,
+    PL011,
     &arm_pl011_fns,
     NULL,
     &pl011_context.base
+  rtems_termios_device_install(
+    MINIUART,
+    &ns16550_handler_polled,
+    NULL,
+    &mini_uart_context.base
   register_fb();
   console_select();
diff --git a/bsps/arm/raspberrypi/include/bsp/usart.h b/bsps/arm/raspberrypi/include/bsp/usart.h
index abbf53626c..6af1844b3c 100644
--- a/bsps/arm/raspberrypi/include/bsp/usart.h
+++ b/bsps/arm/raspberrypi/include/bsp/usart.h
@@ -33,6 +33,7 @@ extern "C" {
 #endif /* __cplusplus */
 #define PL011_DEFAULT_BAUD 115000
+#define MINI_UART_DEFAULT_BAUD   115200
 #define BCM2835_PL011_BASE (RPI_PERIPHERAL_BASE + 0x201000)
 #ifdef __cplusplus
2.17.1
