RSB build failed.
Chris Johns
chrisj at rtems.org
Sun Feb 9 23:36:04 UTC 2020
On 10/2/20 10:19 am, Joel Sherrill wrote:
> On Sun, Feb 9, 2020, 5:07 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
> On 10/2/20 9:40 am, Chris Johns wrote:
> > On 10/2/20 8:25 am, Chris Johns wrote:
> >> On 9/2/20 2:18 pm, jameszxj wrote:
> >>> Hi,
> >>> RSB failed when build gdb on MINGW64.
> >>> error messages:
> D:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/9.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe:
> >>> ada-tasks.o: in function `memcpy':
> >>> D:/msys64/mingw64/x86_64-w64-mingw32/include/string.h:202: undefined
> reference
> >>> to `__memcpy_chk'
> >>> arm-tdep.o: in function `memcpy':
> reference
> >>> to `__memcpy_chk'
> >>> breakpoint.o: in function `strcpy':
> >>> D:/msys64/mingw64/x86_64-w64-mingw32/include/string.h:228: undefined
> reference
> >>> to `__strcpy_chk'
> >> I see this as well. I do not know what the cause it. It is documented in
> the LSB
> >> code specification so am wondering if something has changed to trigger this.
> > Building gdb-9.1 works for ARM. I will post a patch to move RTEMS 5 to gdb-9.1
> > once I have built arm, powerpc and sparc tool sets.
> It looks like mingw is broken ....
> x lrwxrwxrwx 0 root root 0 Nov 08 20:34
> sourceware-mirror-newlib-cygwin-d14714c69/newlib/libm/machine/x86_64/feclearexcept.c
> -> ../../fenv/fenv_stub.c: Can't create
> '\\\\?\\D:\\opt\\rtems\\rsb.git\\rtems\\build\\arg7ndxwm1\\sourceware-mirror-newlib-cygwin-d14714c69\\newlib\\libm\\machine\\x86_64\\feclearexcept.c'
> This is due to this change from Joel in newlib around 4 months ago...
> https://github.com/RTEMS/sourceware-mirror-newlib-cygwin/blob/master/newlib/libm/machine/x86_64/fesetenv.c
> I though I added logic to the RSB to handle these cases but it looks like we
> have another case that needs handling.
> Weird that a link from a tar isn't working.
This is Windows and there is no such thing. It is emulated as a copy.
> The reason the failure happens is the destination directory for the link does
> not exist and so the file copy fails. On Unix system the link is a path attached
> to the node and so does not need to exist until you access it. The order in the
> tar file means the link appears before the destination directory.
> Are there contents in the directory besides links? It no, adding a readme may help.
There are generated files and I was wrong before the source does not exist, ie
nothing to be copied.
> Otherwise, these may need to be created at configure time.
> I honestly don't know the answer. We will have to discuss this on the newlib
> mailing list. There are multiple solutions and they have to buy one
I think clang or gcc has some links that fail but I thought I had a fix for this
where bsdtar is run a second time on windows. I cannot seem to find it.
