[PATCH] c-user: Document CONFIGURE_DIRTY_MEMORY
Sebastian Huber
Mon Feb 10 09:32:24 UTC 2020
Close #3843.
c-user/configuring_a_system.rst | 36 +++++++++++++++++++++++++++++++++++-
1 file changed, 35 insertions(+), 1 deletion(-)
diff --git a/c-user/configuring_a_system.rst b/c-user/configuring_a_system.rst
index 81bc9bb..00584c1 100644
--- a/c-user/configuring_a_system.rst
+++ b/c-user/configuring_a_system.rst
@@ -425,6 +425,38 @@ General System Configuration
This section defines the general system configuration options supported by
``<rtems/confdefs.h>``.
+.. index:: CONFIGURE_DIRTY_MEMORY
+.. _CONFIGURE_DIRTY_MEMORY:
+CONFIGURE_DIRTY_MEMORY
+CONSTANT:
+ ``CONFIGURE_DIRTY_MEMORY``
+DATA TYPE:
+ Boolean feature macro.
+RANGE:
+ Defined or undefined.
+DEFAULT VALUE:
+ By default, the memory used by the RTEMS Workspace and the C Program Heap
+ is uninitialized memory.
+DESCRIPTION:
+ This macro indicates whether RTEMS should dirty the memory used by the
+ RTEMS Workspace and the C Program Heap as part of its initialization. If
+ defined, the memory areas are dirtied with a ``0xCF`` byte pattern.
+ Otherwise, they are not.
+NOTES:
+ Dirtying memory can add significantly to system boot time. It may assist
+ in finding code that assumes memory starts set to zero. In case
+ :ref:`CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY` is also defined, then the
+ memory is first dirtied and then zeroed.
.. index:: CONFIGURE_EXTRA_TASK_STACKS
.. index:: memory for task tasks
@@ -1006,7 +1038,9 @@ DESCRIPTION:
NOTES:
Zeroing memory can add significantly to system boot time. It is not
- necessary for RTEMS but is often assumed by support libraries.
+ necessary for RTEMS but is often assumed by support libraries. In case
+ :ref:`CONFIGURE_DIRTY_MEMORY` is also defined, then the memory is first
+ dirtied and then zeroed.
Classic API Configuration
2.16.4
