About Beaglebone Black device tree
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Mon Feb 10 16:13:39 UTC 2020
On Mon, Feb 10, 2020 at 5:21 PM Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> On 10/02/2020 10:58, Vijay Kumar Banerjee wrote:
> > On Sun, Feb 9, 2020 at 4:03 PM Christian Mauderer <list at c-mauderer.de
> > <mailto:list at c-mauderer.de>> wrote:
> > > Hi!
> > > I looked into it in more detail, the issue isn't with the overlay,
> I
> > > verified it
> > > using u-boot fdt tool as well. Looks like the base dts file is
> > producing
> > > a lot
> > > of "target-module" and during startup, the driver probes are
> > looping over
> > > these target modules for the device tree values instead of looking
> > at the
> > > device node under the target module.
> > > For example, in case of i2c the device tree looks like this:
> > > target-module at b000 {
> > > status = "okay";
> > > compatible = "ti,sysc-omap2\0ti,sysc";
> > > i2c at 0 {
> > > rtems-pinctrl-0 = < 0x2e >;
> > > rtems,i2c-path = "/dev/i2c-0";
> > > compatible = "rtems,bsp-i2c\0ti,omap4-i2c";
> > > In the above snippet, the probe function expects the compat value
> > to be
> > > "rtems,bsp-i2c" but is getting "ti,sysc-omap2" from the
> target-module
> > > and returning ENXIO. This is true for all the values, not just
> compat.
> > > When I added all the required values of i2c into the target-module
> > through
> > > overlay, the iicbus worked. As you said in the thread, looks like
> i2c
> > > isn't the
> > > only device that's affected looks like a lot of devices are failing
> > > because of
> > > this dts issue. Here's a dump
> > > <https://paste.ofcode.org/iDKusQxibBXCLMVJb6KG6q> of start
> messages
> > > after applying the overlay
> > > hack for i2c and lcd probe. (Note that this is an issue with the
> > > tda19988 as well,
> > > because of which framebuffer isn't working)
> > Did something in the FreeBSD device tree sources change to cause
> > that issue?
> > The FreeBSD device tree was updated with the DTS from Linux 5.0 in
> > this commit: 1b4c7d421757 . This changed the structure of the device tree
> > and the issue is coming up since this commit.
> Sorry: I asked the wrong question. It's quite clear that the DTS
> changed. But it sounds like FreeBSD should have the same problems,
> shouldn't they? So I'm a bit astonished that the drivers haven't been
> adapted. Is there something that we missed during an update or would you
> expect that FreeBSD in that version don't work either?
> Best regards
> Christian
> embedded brains GmbH
> Herr Christian Mauderer
> Dornierstr. 4
> D-82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> Phone: +49-89-18 94 741 - 18
> Fax: +49-89-18 94 741 - 08
> PGP: Public key available on request.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200210/32c6701d/attachment-0001.html>
