[PATCH] c-user: Document CONFIGURE_DIRTY_MEMORY
Chris Johns
chrisj at rtems.org
Mon Feb 10 21:19:18 UTC 2020
On 10/2/20 8:32 pm, Sebastian Huber wrote:
> Close #3843.
> c-user/configuring_a_system.rst | 36 +++++++++++++++++++++++++++++++++++-
> 1 file changed, 35 insertions(+), 1 deletion(-)
> diff --git a/c-user/configuring_a_system.rst b/c-user/configuring_a_system.rst
> index 81bc9bb..00584c1 100644
> --- a/c-user/configuring_a_system.rst
> +++ b/c-user/configuring_a_system.rst
> @@ -425,6 +425,38 @@ General System Configuration
> This section defines the general system configuration options supported by
> ``<rtems/confdefs.h>``.
> +.. index:: CONFIGURE_DIRTY_MEMORY
> +.. _CONFIGURE_DIRTY_MEMORY:
> +CONFIGURE_DIRTY_MEMORY
> +CONSTANT:
> + ``CONFIGURE_DIRTY_MEMORY``
> +DATA TYPE:
> + Boolean feature macro.
> +RANGE:
> + Defined or undefined.
> +DEFAULT VALUE:
> + By default, the memory used by the RTEMS Workspace and the C Program Heap
> + is uninitialized memory.
> +DESCRIPTION:
> + This macro indicates whether RTEMS should dirty the memory used by the
> + RTEMS Workspace and the C Program Heap as part of its initialization. If
> + defined, the memory areas are dirtied with a ``0xCF`` byte pattern.
> + Otherwise, they are not.
> +NOTES:
> + Dirtying memory can add significantly to system boot time. It may assist
> + in finding code that assumes memory starts set to zero. In case
.. "assumes memory starts set to zero" does not look right to me?
> + :ref:`CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY` is also defined, then the
> + memory is first dirtied and then zeroed.
> .. index:: CONFIGURE_EXTRA_TASK_STACKS
> .. index:: memory for task tasks
> @@ -1006,7 +1038,9 @@ DESCRIPTION:
> NOTES:
> Zeroing memory can add significantly to system boot time. It is not
> - necessary for RTEMS but is often assumed by support libraries.
> + necessary for RTEMS but is often assumed by support libraries. In case
> + :ref:`CONFIGURE_DIRTY_MEMORY` is also defined, then the memory is first
> + dirtied and then zeroed.
> Classic API Configuration
