[PATCH v3 1/3] amd64: Add missing files from FreeBSD
Jan Sommer
jan.sommer at dlr.de
Tue Feb 11 12:06:50 UTC 2020
freebsd/sys/amd64/amd64/in_cksum.c | 245 ++++
freebsd/sys/amd64/include/machine/_bus.h | 48 +
freebsd/sys/amd64/include/machine/cpufunc.h | 1047 +++++++++++++++++
freebsd/sys/amd64/include/machine/efi.h | 78 ++
freebsd/sys/amd64/include/machine/in_cksum.h | 86 ++
freebsd/sys/amd64/include/machine/md_var.h | 90 ++
.../sys/amd64/include/machine/specialreg.h | 6 +
freebsd/sys/sys/efi.h | 198 ++++
8 files changed, 1798 insertions(+)
create mode 100644 freebsd/sys/amd64/amd64/in_cksum.c
create mode 100644 freebsd/sys/amd64/include/machine/_bus.h
create mode 100644 freebsd/sys/amd64/include/machine/cpufunc.h
create mode 100644 freebsd/sys/amd64/include/machine/efi.h
create mode 100644 freebsd/sys/amd64/include/machine/in_cksum.h
create mode 100644 freebsd/sys/amd64/include/machine/md_var.h
create mode 100644 freebsd/sys/amd64/include/machine/specialreg.h
create mode 100644 freebsd/sys/sys/efi.h
diff --git a/freebsd/sys/amd64/amd64/in_cksum.c b/freebsd/sys/amd64/amd64/in_cksum.c
new file mode 100644
index 00000000..b06f4425
--- /dev/null
+++ b/freebsd/sys/amd64/amd64/in_cksum.c
@@ -0,0 +1,245 @@
+#include <machine/rtems-bsd-kernel-space.h>
+/* $NetBSD: in_cksum.c,v 1.7 1997/09/02 13:18:15 thorpej Exp $ */
+ * SPDX-License-Identifier: BSD-4-Clause
+ * Copyright (c) 1988, 1992, 1993
+ * The Regents of the University of California. All rights reserved.
+ * Copyright (c) 1996
+ * Matt Thomas <matt at 3am-software.com>
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * 3. All advertising materials mentioning features or use of this software
+ * must display the following acknowledgement:
+ * This product includes software developed by the University of
+ * California, Berkeley and its contributors.
+ * 4. Neither the name of the University nor the names of its contributors
+ * may be used to endorse or promote products derived from this software
+ * without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * @(#)in_cksum.c 8.1 (Berkeley) 6/10/93
+#include <sys/cdefs.h> /* RCS ID & Copyright macro defns */
+__FBSDID("$FreeBSD$");
+#include <sys/param.h>
+#include <sys/mbuf.h>
+#include <sys/systm.h>
+#include <netinet/in_systm.h>
+#include <netinet/in.h>
+#include <netinet/ip.h>
+#include <machine/in_cksum.h>
+ * Checksum routine for Internet Protocol family headers
+ * (Portable Alpha version).
+ * This routine is very heavily used in the network
+ * code and should be modified for each CPU to be as fast as possible.
+#define ADDCARRY(x) (x > 65535 ? x -= 65535 : x)
+#define REDUCE32 \
+ q_util.q = sum; \
+ sum = q_util.s[0] + q_util.s[1] + q_util.s[2] + q_util.s[3]; \
+#define REDUCE16 \
+ q_util.q = sum; \
+ l_util.l = q_util.s[0] + q_util.s[1] + q_util.s[2] + q_util.s[3]; \
+ sum = l_util.s[0] + l_util.s[1]; \
+ ADDCARRY(sum); \
+static const u_int32_t in_masks[] = {
+ /*0 bytes*/ /*1 byte*/ /*2 bytes*/ /*3 bytes*/
+ 0x00000000, 0x000000FF, 0x0000FFFF, 0x00FFFFFF, /* offset 0 */
+ 0x00000000, 0x0000FF00, 0x00FFFF00, 0xFFFFFF00, /* offset 1 */
+ 0x00000000, 0x00FF0000, 0xFFFF0000, 0xFFFF0000, /* offset 2 */
+ 0x00000000, 0xFF000000, 0xFF000000, 0xFF000000, /* offset 3 */
+union l_util {
+ u_int16_t s[2];
+ u_int32_t l;
+union q_util {
+ u_int16_t s[4];
+ u_int32_t l[2];
+ u_int64_t q;
+static u_int64_t
+in_cksumdata(const void *buf, int len)
+ const u_int32_t *lw = (const u_int32_t *) buf;
+ u_int64_t sum = 0;
+ u_int64_t prefilled;
+ int offset;
+ union q_util q_util;
+ if ((3 & (long) lw) == 0 && len == 20) {
+ sum = (u_int64_t) lw[0] + lw[1] + lw[2] + lw[3] + lw[4];
+ REDUCE32;
+ return sum;
+ if ((offset = 3 & (long) lw) != 0) {
+ const u_int32_t *masks = in_masks + (offset << 2);
+ lw = (u_int32_t *) (((long) lw) - offset);
+ sum = *lw++ & masks[len >= 3 ? 3 : len];
+ len -= 4 - offset;
+ if (len <= 0) {
+ REDUCE32;
+ return sum;
+#if 0
+ * Force to cache line boundary.
+ offset = 32 - (0x1f & (long) lw);
+ if (offset < 32 && len > offset) {
+ len -= offset;
+ if (4 & offset) {
+ sum += (u_int64_t) lw[0];
+ lw += 1;
+ if (8 & offset) {
+ sum += (u_int64_t) lw[0] + lw[1];
+ lw += 2;
+ if (16 & offset) {
+ sum += (u_int64_t) lw[0] + lw[1] + lw[2] + lw[3];
+ lw += 4;
+#endif
+ * access prefilling to start load of next cache line.
+ * then add current cache line
+ * save result of prefilling for loop iteration.
+ prefilled = lw[0];
+ while ((len -= 32) >= 4) {
+ u_int64_t prefilling = lw[8];
+ sum += prefilled + lw[1] + lw[2] + lw[3]
+ + lw[4] + lw[5] + lw[6] + lw[7];
+ lw += 8;
+ prefilled = prefilling;
+ if (len >= 0) {
+ lw += 8;
+ } else {
+ len += 32;
+ while ((len -= 16) >= 0) {
+ lw += 4;
+ len += 16;
+ while ((len -= 4) >= 0) {
+ sum += (u_int64_t) *lw++;
+ len += 4;
+ if (len > 0)
+ sum += (u_int64_t) (in_masks[len] & *lw);
+ REDUCE32;
+ return sum;
+u_short
+in_addword(u_short a, u_short b)
+ u_int64_t sum = a + b;
+ ADDCARRY(sum);
+ return (sum);
+u_short
+in_pseudo(u_int32_t a, u_int32_t b, u_int32_t c)
+ u_int64_t sum;
+ union l_util l_util;
+ sum = (u_int64_t) a + b + c;
+ REDUCE16;
+ return (sum);
+u_short
+in_cksum_skip(struct mbuf *m, int len, int skip)
+ int mlen = 0;
+ int clen = 0;
+ caddr_t addr;
+ len -= skip;
+ for (; skip && m; m = m->m_next) {
+ if (m->m_len > skip) {
+ mlen = m->m_len - skip;
+ addr = mtod(m, caddr_t) + skip;
+ goto skip_start;
+ } else {
+ skip -= m->m_len;
+ for (; m && len; m = m->m_next) {
+ if (m->m_len == 0)
+ continue;
+ mlen = m->m_len;
+ addr = mtod(m, caddr_t);
+skip_start:
+ if (len < mlen)
+ mlen = len;
+ if ((clen ^ (long) addr) & 1)
+ sum += in_cksumdata(addr, mlen) << 8;
+ else
+ sum += in_cksumdata(addr, mlen);
+ clen += mlen;
+ len -= mlen;
+ REDUCE16;
+ return (~sum & 0xffff);
+u_int in_cksum_hdr(const struct ip *ip)
+ u_int64_t sum = in_cksumdata(ip, sizeof(struct ip));
+ REDUCE16;
diff --git a/freebsd/sys/amd64/include/machine/_bus.h b/freebsd/sys/amd64/include/machine/_bus.h
index 00000000..73482b45
--- /dev/null
+++ b/freebsd/sys/amd64/include/machine/_bus.h
@@ -0,0 +1,48 @@
+ * SPDX-License-Identifier: BSD-2-Clause-FreeBSD
+ * Copyright (c) 2005 M. Warner Losh.
+ * All rights reserved.
+ * are met:
+ * notice, this list of conditions, and the following disclaimer,
+ * without modification, immediately at the beginning of the file.
+ * the documentation and/or other materials provided with the
+ * distribution.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE FOR
+ * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef AMD64_INCLUDE__BUS_H
+#define AMD64_INCLUDE__BUS_H
+ * Bus address and size types
+typedef uint64_t bus_addr_t;
+typedef uint64_t bus_size_t;
+ * Access methods for bus resources and address space.
+typedef uint64_t bus_space_tag_t;
+typedef uint64_t bus_space_handle_t;
+#endif /* AMD64_INCLUDE__BUS_H */
diff --git a/freebsd/sys/amd64/include/machine/cpufunc.h b/freebsd/sys/amd64/include/machine/cpufunc.h
index 00000000..cf514cb6
--- /dev/null
+++ b/freebsd/sys/amd64/include/machine/cpufunc.h
@@ -0,0 +1,1047 @@
+ * SPDX-License-Identifier: BSD-3-Clause
+ * Copyright (c) 2003 Peter Wemm.
+ * Copyright (c) 1993 The Regents of the University of California.
+ * are met:
+ * 3. Neither the name of the University nor the names of its contributors
+ * SUCH DAMAGE.
+ * $FreeBSD$
+ * Functions to provide access to special i386 instructions.
+ * This in included in sys/systm.h, and that file should be
+ * used in preference to this.
+#ifndef _MACHINE_CPUFUNC_H_
+#define _MACHINE_CPUFUNC_H_
+#ifndef _SYS_CDEFS_H_
+#error this file needs sys/cdefs.h as a prerequisite
+#endif
+struct region_descriptor;
+#define readb(va) (*(volatile uint8_t *) (va))
+#define readw(va) (*(volatile uint16_t *) (va))
+#define readl(va) (*(volatile uint32_t *) (va))
+#define readq(va) (*(volatile uint64_t *) (va))
+#define writeb(va, d) (*(volatile uint8_t *) (va) = (d))
+#define writew(va, d) (*(volatile uint16_t *) (va) = (d))
+#define writel(va, d) (*(volatile uint32_t *) (va) = (d))
+#define writeq(va, d) (*(volatile uint64_t *) (va) = (d))
+#if defined(__GNUCLIKE_ASM) && defined(__CC_SUPPORTS___INLINE)
+static __inline void
+breakpoint(void)
+ __asm __volatile("int $3");
+static __inline __pure2 u_int
+bsfl(u_int mask)
+ u_int result;
+ __asm __volatile("bsfl %1,%0" : "=r" (result) : "rm" (mask));
+ return (result);
+static __inline __pure2 u_long
+bsfq(u_long mask)
+ u_long result;
+ __asm __volatile("bsfq %1,%0" : "=r" (result) : "rm" (mask));
+ return (result);
+bsrl(u_int mask)
+ u_int result;
+ __asm __volatile("bsrl %1,%0" : "=r" (result) : "rm" (mask));
+ return (result);
+bsrq(u_long mask)
+ u_long result;
+ __asm __volatile("bsrq %1,%0" : "=r" (result) : "rm" (mask));
+ return (result);
+clflush(u_long addr)
+ __asm __volatile("clflush %0" : : "m" (*(char *)addr));
+clflushopt(u_long addr)
+ __asm __volatile(".byte 0x66;clflush %0" : : "m" (*(char *)addr));
+clwb(u_long addr)
+ __asm __volatile("clwb %0" : : "m" (*(char *)addr));
+clts(void)
+ __asm __volatile("clts");
+disable_intr(void)
+ __asm __volatile("cli" : : : "memory");
+do_cpuid(u_int ax, u_int *p)
+ __asm __volatile("cpuid"
+ : "=a" (p[0]), "=b" (p[1]), "=c" (p[2]), "=d" (p[3])
+ : "0" (ax));
+cpuid_count(u_int ax, u_int cx, u_int *p)
+ : "0" (ax), "c" (cx));
+enable_intr(void)
+ __asm __volatile("sti");
+#ifdef _KERNEL
+#define HAVE_INLINE_FFS
+#define ffs(x) __builtin_ffs(x)
+#define HAVE_INLINE_FFSL
+static __inline __pure2 int
+ffsl(long mask)
+ return (mask == 0 ? mask : (int)bsfq((u_long)mask) + 1);
+#define HAVE_INLINE_FFSLL
+ffsll(long long mask)
+ return (ffsl((long)mask));
+#define HAVE_INLINE_FLS
+fls(int mask)
+ return (mask == 0 ? mask : (int)bsrl((u_int)mask) + 1);
+#define HAVE_INLINE_FLSL
+flsl(long mask)
+ return (mask == 0 ? mask : (int)bsrq((u_long)mask) + 1);
+#define HAVE_INLINE_FLSLL
+flsll(long long mask)
+ return (flsl((long)mask));
+#endif /* _KERNEL */
+halt(void)
+ __asm __volatile("hlt");
+static __inline u_char
+inb(u_int port)
+ u_char data;
+ __asm __volatile("inb %w1, %0" : "=a" (data) : "Nd" (port));
+ return (data);
+static __inline u_int
+inl(u_int port)
+ u_int data;
+ __asm __volatile("inl %w1, %0" : "=a" (data) : "Nd" (port));
+ return (data);
+insb(u_int port, void *addr, size_t count)
+ __asm __volatile("cld; rep; insb"
+ : "+D" (addr), "+c" (count)
+ : "d" (port)
+ : "memory");
+insw(u_int port, void *addr, size_t count)
+ __asm __volatile("cld; rep; insw"
+ : "d" (port)
+ : "memory");
+insl(u_int port, void *addr, size_t count)
+ __asm __volatile("cld; rep; insl"
+ : "d" (port)
+ : "memory");
+invd(void)
+ __asm __volatile("invd");
+static __inline u_short
+inw(u_int port)
+ u_short data;
+ __asm __volatile("inw %w1, %0" : "=a" (data) : "Nd" (port));
+ return (data);
+outb(u_int port, u_char data)
+ __asm __volatile("outb %0, %w1" : : "a" (data), "Nd" (port));
+outl(u_int port, u_int data)
+ __asm __volatile("outl %0, %w1" : : "a" (data), "Nd" (port));
+outsb(u_int port, const void *addr, size_t count)
+ __asm __volatile("cld; rep; outsb"
+ : "+S" (addr), "+c" (count)
+ : "d" (port));
+outsw(u_int port, const void *addr, size_t count)
+ __asm __volatile("cld; rep; outsw"
+ : "d" (port));
+outsl(u_int port, const void *addr, size_t count)
+ __asm __volatile("cld; rep; outsl"
+ : "d" (port));
+outw(u_int port, u_short data)
+ __asm __volatile("outw %0, %w1" : : "a" (data), "Nd" (port));
+static __inline u_long
+popcntq(u_long mask)
+ u_long result;
+ __asm __volatile("popcntq %1,%0" : "=r" (result) : "rm" (mask));
+ return (result);
+lfence(void)
+ __asm __volatile("lfence" : : : "memory");
+mfence(void)
+ __asm __volatile("mfence" : : : "memory");
+sfence(void)
+ __asm __volatile("sfence" : : : "memory");
+ia32_pause(void)
+ __asm __volatile("pause");
+read_rflags(void)
+ u_long rf;
+ __asm __volatile("pushfq; popq %0" : "=r" (rf));
+ return (rf);
+static __inline uint64_t
+rdmsr(u_int msr)
+ uint32_t low, high;
+ __asm __volatile("rdmsr" : "=a" (low), "=d" (high) : "c" (msr));
+ return (low | ((uint64_t)high << 32));
+static __inline uint32_t
+rdmsr32(u_int msr)
+ uint32_t low;
+ __asm __volatile("rdmsr" : "=a" (low) : "c" (msr) : "rdx");
+ return (low);
+rdpmc(u_int pmc)
+ __asm __volatile("rdpmc" : "=a" (low), "=d" (high) : "c" (pmc));
+rdtsc(void)
+ __asm __volatile("rdtsc" : "=a" (low), "=d" (high));
+rdtscp(void)
+ __asm __volatile("rdtscp" : "=a" (low), "=d" (high) : : "ecx");
+rdtsc32(void)
+ uint32_t rv;
+ __asm __volatile("rdtsc" : "=a" (rv) : : "edx");
+ return (rv);
+wbinvd(void)
+ __asm __volatile("wbinvd");
+write_rflags(u_long rf)
+ __asm __volatile("pushq %0; popfq" : : "r" (rf));
+wrmsr(u_int msr, uint64_t newval)
+ low = newval;
+ high = newval >> 32;
+ __asm __volatile("wrmsr" : : "a" (low), "d" (high), "c" (msr));
+load_cr0(u_long data)
+ __asm __volatile("movq %0,%%cr0" : : "r" (data));
+rcr0(void)
+ u_long data;
+ __asm __volatile("movq %%cr0,%0" : "=r" (data));
+ return (data);
+rcr2(void)
+ u_long data;
+ __asm __volatile("movq %%cr2,%0" : "=r" (data));
+ return (data);
+load_cr3(u_long data)
+ __asm __volatile("movq %0,%%cr3" : : "r" (data) : "memory");
+rcr3(void)
+ u_long data;
+ __asm __volatile("movq %%cr3,%0" : "=r" (data));
+ return (data);
+load_cr4(u_long data)
+ __asm __volatile("movq %0,%%cr4" : : "r" (data));
+rcr4(void)
+ u_long data;
+ __asm __volatile("movq %%cr4,%0" : "=r" (data));
+ return (data);
+rxcr(u_int reg)
+ u_int low, high;
+ __asm __volatile("xgetbv" : "=a" (low), "=d" (high) : "c" (reg));
+load_xcr(u_int reg, u_long val)
+ u_int low, high;
+ low = val;
+ high = val >> 32;
+ __asm __volatile("xsetbv" : : "c" (reg), "a" (low), "d" (high));
+ * Global TLB flush (except for thise for pages marked PG_G)
+invltlb(void)
+ load_cr3(rcr3());
+#ifndef CR4_PGE
+#define CR4_PGE 0x00000080 /* Page global enable */
+#endif
+ * Perform the guaranteed invalidation of all TLB entries. This
+ * includes the global entries, and entries in all PCIDs, not only the
+ * current context. The function works both on non-PCID CPUs and CPUs
+ * with the PCID turned off or on. See IA-32 SDM Vol. 3a 4.10.4.1
+ * Operations that Invalidate TLBs and Paging-Structure Caches.
+invltlb_glob(void)
+ uint64_t cr4;
+ cr4 = rcr4();
+ load_cr4(cr4 & ~CR4_PGE);
+ * Although preemption at this point could be detrimental to
+ * performance, it would not lead to an error. PG_G is simply
+ * ignored if CR4.PGE is clear. Moreover, in case this block
+ * is re-entered, the load_cr4() either above or below will
+ * modify CR4.PGE flushing the TLB.
+ load_cr4(cr4 | CR4_PGE);
+ * TLB flush for an individual page (even if it has PG_G).
+ * Only works on 486+ CPUs (i386 does not have PG_G).
+invlpg(u_long addr)
+ __asm __volatile("invlpg %0" : : "m" (*(char *)addr) : "memory");
+#define INVPCID_ADDR 0
+#define INVPCID_CTX 1
+#define INVPCID_CTXGLOB 2
+#define INVPCID_ALLCTX 3
+struct invpcid_descr {
+ uint64_t pcid:12 __packed;
+ uint64_t pad:52 __packed;
+ uint64_t addr;
+} __packed;
+invpcid(struct invpcid_descr *d, int type)
+ __asm __volatile("invpcid (%0),%1"
+ : : "r" (d), "r" ((u_long)type) : "memory");
+rfs(void)
+ u_short sel;
+ __asm __volatile("movw %%fs,%0" : "=rm" (sel));
+ return (sel);
+rgs(void)
+ u_short sel;
+ __asm __volatile("movw %%gs,%0" : "=rm" (sel));
+ return (sel);
+rss(void)
+ u_short sel;
+ __asm __volatile("movw %%ss,%0" : "=rm" (sel));
+ return (sel);
+load_ds(u_short sel)
+ __asm __volatile("movw %0,%%ds" : : "rm" (sel));
+load_es(u_short sel)
+ __asm __volatile("movw %0,%%es" : : "rm" (sel));
+cpu_monitor(const void *addr, u_long extensions, u_int hints)
+ __asm __volatile("monitor"
+ : : "a" (addr), "c" (extensions), "d" (hints));
+cpu_mwait(u_long extensions, u_int hints)
+ __asm __volatile("mwait" : : "a" (hints), "c" (extensions));
+rdpkru(void)
+ uint32_t res;
+ __asm __volatile("rdpkru" : "=a" (res) : "c" (0) : "edx");
+ return (res);
+wrpkru(uint32_t mask)
+ __asm __volatile("wrpkru" : : "a" (mask), "c" (0), "d" (0));
+#ifdef _KERNEL
+/* This is defined in <machine/specialreg.h> but is too painful to get to */
+#ifndef MSR_FSBASE
+#define MSR_FSBASE 0xc0000100
+#endif
+load_fs(u_short sel)
+ /* Preserve the fsbase value across the selector load */
+ __asm __volatile("rdmsr; movw %0,%%fs; wrmsr"
+ : : "rm" (sel), "c" (MSR_FSBASE) : "eax", "edx");
+#ifndef MSR_GSBASE
+#define MSR_GSBASE 0xc0000101
+#endif
+load_gs(u_short sel)
+ * Preserve the gsbase value across the selector load.
+ * Note that we have to disable interrupts because the gsbase
+ * being trashed happens to be the kernel gsbase at the time.
+ __asm __volatile("pushfq; cli; rdmsr; movw %0,%%gs; wrmsr; popfq"
+ : : "rm" (sel), "c" (MSR_GSBASE) : "eax", "edx");
+#else
+/* Usable by userland */
+ __asm __volatile("movw %0,%%fs" : : "rm" (sel));
+ __asm __volatile("movw %0,%%gs" : : "rm" (sel));
+#endif
+rdfsbase(void)
+ uint64_t x;
+ __asm __volatile("rdfsbase %0" : "=r" (x));
+ return (x);
+wrfsbase(uint64_t x)
+ __asm __volatile("wrfsbase %0" : : "r" (x));
+rdgsbase(void)
+ uint64_t x;
+ __asm __volatile("rdgsbase %0" : "=r" (x));
+ return (x);
+wrgsbase(uint64_t x)
+ __asm __volatile("wrgsbase %0" : : "r" (x));
+bare_lgdt(struct region_descriptor *addr)
+ __asm __volatile("lgdt (%0)" : : "r" (addr));
+sgdt(struct region_descriptor *addr)
+ char *loc;
+ loc = (char *)addr;
+ __asm __volatile("sgdt %0" : "=m" (*loc) : : "memory");
+lidt(struct region_descriptor *addr)
+ __asm __volatile("lidt (%0)" : : "r" (addr));
+sidt(struct region_descriptor *addr)
+ char *loc;
+ __asm __volatile("sidt %0" : "=m" (*loc) : : "memory");
+lldt(u_short sel)
+ __asm __volatile("lldt %0" : : "r" (sel));
+sldt(void)
+ u_short sel;
+ __asm __volatile("sldt %0" : "=r" (sel));
+ return (sel);
+ltr(u_short sel)
+ __asm __volatile("ltr %0" : : "r" (sel));
+read_tr(void)
+ u_short sel;
+ __asm __volatile("str %0" : "=r" (sel));
+ return (sel);
+rdr0(void)
+ uint64_t data;
+ __asm __volatile("movq %%dr0,%0" : "=r" (data));
+ return (data);
+load_dr0(uint64_t dr0)
+ __asm __volatile("movq %0,%%dr0" : : "r" (dr0));
+rdr1(void)
+ uint64_t data;
+ __asm __volatile("movq %%dr1,%0" : "=r" (data));
+ return (data);
+load_dr1(uint64_t dr1)
+ __asm __volatile("movq %0,%%dr1" : : "r" (dr1));
+rdr2(void)
+ uint64_t data;
+ __asm __volatile("movq %%dr2,%0" : "=r" (data));
+ return (data);
+load_dr2(uint64_t dr2)
+ __asm __volatile("movq %0,%%dr2" : : "r" (dr2));
+rdr3(void)
+ uint64_t data;
+ __asm __volatile("movq %%dr3,%0" : "=r" (data));
+ return (data);
+load_dr3(uint64_t dr3)
+ __asm __volatile("movq %0,%%dr3" : : "r" (dr3));
+rdr6(void)
+ uint64_t data;
+ __asm __volatile("movq %%dr6,%0" : "=r" (data));
+ return (data);
+load_dr6(uint64_t dr6)
+ __asm __volatile("movq %0,%%dr6" : : "r" (dr6));
+rdr7(void)
+ uint64_t data;
+ __asm __volatile("movq %%dr7,%0" : "=r" (data));
+ return (data);
+load_dr7(uint64_t dr7)
+ __asm __volatile("movq %0,%%dr7" : : "r" (dr7));
+static __inline register_t
+intr_disable(void)
+ register_t rflags;
+ rflags = read_rflags();
+ disable_intr();
+ return (rflags);
+intr_restore(register_t rflags)
+ write_rflags(rflags);
+stac(void)
+ __asm __volatile("stac" : : : "cc");
+clac(void)
+ __asm __volatile("clac" : : : "cc");
+enum {
+ SGX_ECREATE = 0x0,
+ SGX_EADD = 0x1,
+ SGX_EINIT = 0x2,
+ SGX_EREMOVE = 0x3,
+ SGX_EDGBRD = 0x4,
+ SGX_EDGBWR = 0x5,
+ SGX_EEXTEND = 0x6,
+ SGX_ELDU = 0x8,
+ SGX_EBLOCK = 0x9,
+ SGX_EPA = 0xA,
+ SGX_EWB = 0xB,
+ SGX_ETRACK = 0xC,
+enum {
+ SGX_PT_SECS = 0x00,
+ SGX_PT_TCS = 0x01,
+ SGX_PT_REG = 0x02,
+ SGX_PT_VA = 0x03,
+ SGX_PT_TRIM = 0x04,
+int sgx_encls(uint32_t eax, uint64_t rbx, uint64_t rcx, uint64_t rdx);
+static __inline int
+sgx_ecreate(void *pginfo, void *secs)
+ return (sgx_encls(SGX_ECREATE, (uint64_t)pginfo,
+ (uint64_t)secs, 0));
+sgx_eadd(void *pginfo, void *epc)
+ return (sgx_encls(SGX_EADD, (uint64_t)pginfo,
+ (uint64_t)epc, 0));
+sgx_einit(void *sigstruct, void *secs, void *einittoken)
+ return (sgx_encls(SGX_EINIT, (uint64_t)sigstruct,
+ (uint64_t)secs, (uint64_t)einittoken));
+sgx_eextend(void *secs, void *epc)
+ return (sgx_encls(SGX_EEXTEND, (uint64_t)secs,
+sgx_epa(void *epc)
+ return (sgx_encls(SGX_EPA, SGX_PT_VA, (uint64_t)epc, 0));
+sgx_eldu(uint64_t rbx, uint64_t rcx,
+ uint64_t rdx)
+ return (sgx_encls(SGX_ELDU, rbx, rcx, rdx));
+sgx_eremove(void *epc)
+ return (sgx_encls(SGX_EREMOVE, 0, (uint64_t)epc, 0));
+#else /* !(__GNUCLIKE_ASM && __CC_SUPPORTS___INLINE) */
+int breakpoint(void);
+u_int bsfl(u_int mask);
+u_int bsrl(u_int mask);
+void clflush(u_long addr);
+void clts(void);
+void cpuid_count(u_int ax, u_int cx, u_int *p);
+void disable_intr(void);
+void do_cpuid(u_int ax, u_int *p);
+void enable_intr(void);
+void halt(void);
+void ia32_pause(void);
+u_char inb(u_int port);
+u_int inl(u_int port);
+void insb(u_int port, void *addr, size_t count);
+void insl(u_int port, void *addr, size_t count);
+void insw(u_int port, void *addr, size_t count);
+register_t intr_disable(void);
+void intr_restore(register_t rf);
+void invd(void);
+void invlpg(u_int addr);
+void invltlb(void);
+u_short inw(u_int port);
+void lidt(struct region_descriptor *addr);
+void lldt(u_short sel);
+void load_cr0(u_long cr0);
+void load_cr3(u_long cr3);
+void load_cr4(u_long cr4);
+void load_dr0(uint64_t dr0);
+void load_dr1(uint64_t dr1);
+void load_dr2(uint64_t dr2);
+void load_dr3(uint64_t dr3);
+void load_dr6(uint64_t dr6);
+void load_dr7(uint64_t dr7);
+void load_fs(u_short sel);
+void load_gs(u_short sel);
+void ltr(u_short sel);
+void outb(u_int port, u_char data);
+void outl(u_int port, u_int data);
+void outsb(u_int port, const void *addr, size_t count);
+void outsl(u_int port, const void *addr, size_t count);
+void outsw(u_int port, const void *addr, size_t count);
+void outw(u_int port, u_short data);
+u_long rcr0(void);
+u_long rcr2(void);
+u_long rcr3(void);
+u_long rcr4(void);
+uint64_t rdmsr(u_int msr);
+uint32_t rdmsr32(u_int msr);
+uint64_t rdpmc(u_int pmc);
+uint64_t rdr0(void);
+uint64_t rdr1(void);
+uint64_t rdr2(void);
+uint64_t rdr3(void);
+uint64_t rdr6(void);
+uint64_t rdr7(void);
+uint64_t rdtsc(void);
+u_long read_rflags(void);
+u_int rfs(void);
+u_int rgs(void);
+void wbinvd(void);
+void write_rflags(u_int rf);
+void wrmsr(u_int msr, uint64_t newval);
+#endif /* __GNUCLIKE_ASM && __CC_SUPPORTS___INLINE */
+void reset_dbregs(void);
+#ifdef _KERNEL
+int rdmsr_safe(u_int msr, uint64_t *val);
+int wrmsr_safe(u_int msr, uint64_t newval);
+#endif
+#endif /* !_MACHINE_CPUFUNC_H_ */
diff --git a/freebsd/sys/amd64/include/machine/efi.h b/freebsd/sys/amd64/include/machine/efi.h
index 00000000..e630a338
--- /dev/null
+++ b/freebsd/sys/amd64/include/machine/efi.h
@@ -0,0 +1,78 @@
+ * Copyright (c) 2016 The FreeBSD Foundation
+ * This software was developed by Konstantin Belousov <kib at FreeBSD.org>
+ * under sponsorship from the FreeBSD Foundation.
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef __AMD64_INCLUDE_EFI_H_
+#define __AMD64_INCLUDE_EFI_H_
+ * XXX: from gcc 6.2 manual:
+ * Note, the ms_abi attribute for Microsoft Windows 64-bit targets
+ * currently requires the -maccumulate-outgoing-args option.
+ * Avoid EFIABI_ATTR declarations for compilers that don't support it.
+ * GCC support began in version 4.4.
+#if defined(__clang__) || defined(__GNUC__) && \
+ (__GNUC__ > 4 || __GNUC__ == 4 && __GNUC_MINOR__ >= 4)
+#define EFIABI_ATTR __attribute__((ms_abi))
+#endif
+#ifdef _KERNEL
+#include <isa/rtc.h>
+#define EFI_TIME_LOCK() mtx_lock(&atrtc_time_lock)
+#define EFI_TIME_UNLOCK() mtx_unlock(&atrtc_time_lock)
+#define EFI_TIME_OWNED() mtx_assert(&atrtc_time_lock, MA_OWNED)
+#define EFI_RT_HANDLE_FAULTS_DEFAULT 1
+#endif
+struct efirt_callinfo {
+ const char *ec_name;
+ register_t ec_efi_status;
+ register_t ec_fptr;
+ register_t ec_argcnt;
+ register_t ec_arg1;
+ register_t ec_arg2;
+ register_t ec_arg3;
+ register_t ec_arg4;
+ register_t ec_arg5;
+ register_t ec_rbx;
+ register_t ec_rsp;
+ register_t ec_rbp;
+ register_t ec_r12;
+ register_t ec_r13;
+ register_t ec_r14;
+ register_t ec_r15;
+ register_t ec_rflags;
+#endif /* __AMD64_INCLUDE_EFI_H_ */
diff --git a/freebsd/sys/amd64/include/machine/in_cksum.h b/freebsd/sys/amd64/include/machine/in_cksum.h
index 00000000..79d30caf
--- /dev/null
+++ b/freebsd/sys/amd64/include/machine/in_cksum.h
@@ -0,0 +1,86 @@
+ * Copyright (c) 1990 The Regents of the University of California.
+ * are met:
+ * SUCH DAMAGE.
+ * from tahoe: in_cksum.c 1.2 86/01/05
+ * from: @(#)in_cksum.c 1.3 (Berkeley) 1/19/91
+ * from: Id: in_cksum.c,v 1.8 1995/12/03 18:35:19 bde Exp
+ * $FreeBSD$
+#ifndef _MACHINE_IN_CKSUM_H_
+#define _MACHINE_IN_CKSUM_H_ 1
+#endif
+#define in_cksum(m, len) in_cksum_skip(m, len, 0)
+#if defined(IPVERSION) && (IPVERSION == 4)
+ * It it useful to have an Internet checksum routine which is inlineable
+ * and optimized specifically for the task of computing IP header checksums
+ * in the normal case (where there are no options and the header length is
+ * therefore always exactly five 32-bit words.
+#ifdef __CC_SUPPORTS___INLINE
+in_cksum_update(struct ip *ip)
+ int __tmpsum;
+ __tmpsum = (int)ntohs(ip->ip_sum) + 256;
+ ip->ip_sum = htons(__tmpsum + (__tmpsum >> 16));
+#else
+#define in_cksum_update(ip) \
+ do { \
+ int __tmpsum; \
+ __tmpsum = (int)ntohs(ip->ip_sum) + 256; \
+ ip->ip_sum = htons(__tmpsum + (__tmpsum >> 16)); \
+ } while(0)
+#endif
+#endif
+#ifdef _KERNEL
+u_int in_cksum_hdr(const struct ip *ip);
+#endif
+u_short in_addword(u_short sum, u_short b);
+u_short in_pseudo(u_int sum, u_int b, u_int c);
+u_short in_cksum_skip(struct mbuf *m, int len, int skip);
+#endif
+#endif /* _MACHINE_IN_CKSUM_H_ */
diff --git a/freebsd/sys/amd64/include/machine/md_var.h b/freebsd/sys/amd64/include/machine/md_var.h
index 00000000..237a75cf
--- /dev/null
+++ b/freebsd/sys/amd64/include/machine/md_var.h
@@ -0,0 +1,90 @@
+ * Copyright (c) 1995 Bruce D. Evans.
+ * are met:
+ * 3. Neither the name of the author nor the names of contributors
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _MACHINE_MD_VAR_H_
+#define _MACHINE_MD_VAR_H_
+#include <x86/x86_var.h>
+extern uint64_t *vm_page_dump;
+extern int hw_lower_amd64_sharedpage;
+extern int hw_ibrs_disable;
+extern int hw_ssb_disable;
+extern int nmi_flush_l1d_sw;
+extern int syscall_ret_l1d_flush_mode;
+extern vm_paddr_t intel_graphics_stolen_base;
+extern vm_paddr_t intel_graphics_stolen_size;
+ * The file "conf/ldscript.amd64" defines the symbol "kernphys". Its
+ * value is the physical address at which the kernel is loaded.
+extern char kernphys[];
+struct savefpu;
+struct sysentvec;
+void amd64_conf_fast_syscall(void);
+void amd64_db_resume_dbreg(void);
+void amd64_lower_shared_page(struct sysentvec *);
+void amd64_bsp_pcpu_init1(struct pcpu *pc);
+void amd64_bsp_pcpu_init2(uint64_t rsp0);
+void amd64_bsp_ist_init(struct pcpu *pc);
+void amd64_syscall(struct thread *td, int traced);
+void amd64_syscall_ret_flush_l1d(int error);
+void amd64_syscall_ret_flush_l1d_recalc(void);
+void doreti_iret(void) __asm(__STRING(doreti_iret));
+void doreti_iret_fault(void) __asm(__STRING(doreti_iret_fault));
+void flush_l1d_sw_abi(void);
+void ld_ds(void) __asm(__STRING(ld_ds));
+void ld_es(void) __asm(__STRING(ld_es));
+void ld_fs(void) __asm(__STRING(ld_fs));
+void ld_gs(void) __asm(__STRING(ld_gs));
+void ld_fsbase(void) __asm(__STRING(ld_fsbase));
+void ld_gsbase(void) __asm(__STRING(ld_gsbase));
+void ds_load_fault(void) __asm(__STRING(ds_load_fault));
+void es_load_fault(void) __asm(__STRING(es_load_fault));
+void fs_load_fault(void) __asm(__STRING(fs_load_fault));
+void gs_load_fault(void) __asm(__STRING(gs_load_fault));
+void fsbase_load_fault(void) __asm(__STRING(fsbase_load_fault));
+void gsbase_load_fault(void) __asm(__STRING(gsbase_load_fault));
+void fpstate_drop(struct thread *td);
+void pagezero(void *addr);
+void setidt(int idx, alias_for_inthand_t *func, int typ, int dpl, int ist);
+void sse2_pagezero(void *addr);
+struct savefpu *get_pcb_user_save_td(struct thread *td);
+struct savefpu *get_pcb_user_save_pcb(struct pcb *pcb);
+void pci_early_quirks(void);
+#endif /* !_MACHINE_MD_VAR_H_ */
diff --git a/freebsd/sys/amd64/include/machine/specialreg.h b/freebsd/sys/amd64/include/machine/specialreg.h
index 00000000..aace4bfd
--- /dev/null
+++ b/freebsd/sys/amd64/include/machine/specialreg.h
@@ -0,0 +1,6 @@
+ * This file is in the public domain.
+/* $FreeBSD$ */
+#include <x86/specialreg.h>
diff --git a/freebsd/sys/sys/efi.h b/freebsd/sys/sys/efi.h
index 00000000..b9f31454
--- /dev/null
+++ b/freebsd/sys/sys/efi.h
@@ -0,0 +1,198 @@
+ * Copyright (c) 2004 Marcel Moolenaar
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
+ * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
+ * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
+ * IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
+ * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
+ * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
+ * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+ * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
+ * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _SYS_EFI_H_
+#define _SYS_EFI_H_
+#include <sys/uuid.h>
+#include <machine/efi.h>
+#define EFI_PAGE_SHIFT 12
+#define EFI_PAGE_SIZE (1 << EFI_PAGE_SHIFT)
+#define EFI_PAGE_MASK (EFI_PAGE_SIZE - 1)
+#define EFI_TABLE_ACPI20 \
+ {0x8868e871,0xe4f1,0x11d3,0xbc,0x22,{0x00,0x80,0xc7,0x3c,0x88,0x81}}
+#define EFI_TABLE_SAL \
+ {0xeb9d2d32,0x2d88,0x11d3,0x9a,0x16,{0x00,0x90,0x27,0x3f,0xc1,0x4d}}
+enum efi_reset {
+ EFI_RESET_COLD = 0,
+ EFI_RESET_WARM = 1,
+ EFI_RESET_SHUTDOWN = 2,
+typedef uint16_t efi_char;
+typedef unsigned long efi_status;
+struct efi_cfgtbl {
+ struct uuid ct_uuid;
+ uint64_t ct_data;
+struct efi_md {
+ uint32_t md_type;
+#define EFI_MD_TYPE_NULL 0
+#define EFI_MD_TYPE_CODE 1 /* Loader text. */
+#define EFI_MD_TYPE_DATA 2 /* Loader data. */
+#define EFI_MD_TYPE_BS_CODE 3 /* Boot services text. */
+#define EFI_MD_TYPE_BS_DATA 4 /* Boot services data. */
+#define EFI_MD_TYPE_RT_CODE 5 /* Runtime services text. */
+#define EFI_MD_TYPE_RT_DATA 6 /* Runtime services data. */
+#define EFI_MD_TYPE_FREE 7 /* Unused/free memory. */
+#define EFI_MD_TYPE_BAD 8 /* Bad memory */
+#define EFI_MD_TYPE_RECLAIM 9 /* ACPI reclaimable memory. */
+#define EFI_MD_TYPE_FIRMWARE 10 /* ACPI NV memory */
+#define EFI_MD_TYPE_IOMEM 11 /* Memory-mapped I/O. */
+#define EFI_MD_TYPE_IOPORT 12 /* I/O port space. */
+#define EFI_MD_TYPE_PALCODE 13 /* PAL */
+#define EFI_MD_TYPE_PERSISTENT 14 /* Persistent memory. */
+ uint32_t __pad;
+ uint64_t md_phys;
+ void *md_virt;
+ uint64_t md_pages;
+ uint64_t md_attr;
+#define EFI_MD_ATTR_UC 0x0000000000000001UL
+#define EFI_MD_ATTR_WC 0x0000000000000002UL
+#define EFI_MD_ATTR_WT 0x0000000000000004UL
+#define EFI_MD_ATTR_WB 0x0000000000000008UL
+#define EFI_MD_ATTR_UCE 0x0000000000000010UL
+#define EFI_MD_ATTR_WP 0x0000000000001000UL
+#define EFI_MD_ATTR_RP 0x0000000000002000UL
+#define EFI_MD_ATTR_XP 0x0000000000004000UL
+#define EFI_MD_ATTR_NV 0x0000000000008000UL
+#define EFI_MD_ATTR_MORE_RELIABLE \
+ 0x0000000000010000UL
+#define EFI_MD_ATTR_RO 0x0000000000020000UL
+#define EFI_MD_ATTR_RT 0x8000000000000000UL
+#define efi_next_descriptor(ptr, size) \
+ ((struct efi_md *)(((uint8_t *)(ptr)) + (size)))
+struct efi_tm {
+ uint16_t tm_year; /* 1998 - 20XX */
+ uint8_t tm_mon; /* 1 - 12 */
+ uint8_t tm_mday; /* 1 - 31 */
+ uint8_t tm_hour; /* 0 - 23 */
+ uint8_t tm_min; /* 0 - 59 */
+ uint8_t tm_sec; /* 0 - 59 */
+ uint8_t __pad1;
+ uint32_t tm_nsec; /* 0 - 999,999,999 */
+ int16_t tm_tz; /* -1440 to 1440 or 2047 */
+ uint8_t tm_dst;
+ uint8_t __pad2;
+struct efi_tmcap {
+ uint32_t tc_res; /* 1e-6 parts per million */
+ uint32_t tc_prec; /* hertz */
+ uint8_t tc_stz; /* Set clears sub-second time */
+struct efi_tblhdr {
+ uint64_t th_sig;
+ uint32_t th_rev;
+ uint32_t th_hdrsz;
+ uint32_t th_crc32;
+ uint32_t __res;
+#ifdef _KERNEL
+#ifdef EFIABI_ATTR
+struct efi_rt {
+ struct efi_tblhdr rt_hdr;
+ efi_status (*rt_gettime)(struct efi_tm *, struct efi_tmcap *)
+ EFIABI_ATTR;
+ efi_status (*rt_settime)(struct efi_tm *) EFIABI_ATTR;
+ efi_status (*rt_getwaketime)(uint8_t *, uint8_t *,
+ struct efi_tm *) EFIABI_ATTR;
+ efi_status (*rt_setwaketime)(uint8_t, struct efi_tm *)
+ EFIABI_ATTR;
+ efi_status (*rt_setvirtual)(u_long, u_long, uint32_t,
+ struct efi_md *) EFIABI_ATTR;
+ efi_status (*rt_cvtptr)(u_long, void **) EFIABI_ATTR;
+ efi_status (*rt_getvar)(efi_char *, struct uuid *, uint32_t *,
+ u_long *, void *) EFIABI_ATTR;
+ efi_status (*rt_scanvar)(u_long *, efi_char *, struct uuid *)
+ EFIABI_ATTR;
+ efi_status (*rt_setvar)(efi_char *, struct uuid *, uint32_t,
+ u_long, void *) EFIABI_ATTR;
+ efi_status (*rt_gethicnt)(uint32_t *) EFIABI_ATTR;
+ efi_status (*rt_reset)(enum efi_reset, efi_status, u_long,
+ efi_char *) EFIABI_ATTR;
+#endif
+struct efi_systbl {
+ struct efi_tblhdr st_hdr;
+#define EFI_SYSTBL_SIG 0x5453595320494249UL
+ efi_char *st_fwvendor;
+ uint32_t st_fwrev;
+ uint32_t __pad;
+ void *st_cin;
+ void *st_cinif;
+ void *st_cout;
+ void *st_coutif;
+ void *st_cerr;
+ void *st_cerrif;
+ uint64_t st_rt;
+ void *st_bs;
+ u_long st_entries;
+ uint64_t st_cfgtbl;
+extern vm_paddr_t efi_systbl_phys;
+struct efirt_callinfo;
+/* Internal MD EFI functions */
+int efi_arch_enter(void);
+void efi_arch_leave(void);
+vm_offset_t efi_phys_to_kva(vm_paddr_t);
+int efi_rt_arch_call(struct efirt_callinfo *);
+bool efi_create_1t1_map(struct efi_md *, int, int);
+void efi_destroy_1t1_map(void);
+/* Public MI EFI functions */
+int efi_rt_ok(void);
+int efi_get_table(struct uuid *uuid, void **ptr);
+int efi_get_time(struct efi_tm *tm);
+int efi_get_time_capabilities(struct efi_tmcap *tmcap);
+int efi_reset_system(enum efi_reset type);
+int efi_set_time(struct efi_tm *tm);
+int efi_var_get(uint16_t *name, struct uuid *vendor, uint32_t *attrib,
+ size_t *datasize, void *data);
+int efi_var_nextname(size_t *namesize, uint16_t *name, struct uuid *vendor);
+int efi_var_set(uint16_t *name, struct uuid *vendor, uint32_t attrib,
+ size_t datasize, void *data);
+#endif /* _SYS_EFI_H_ */
2.17.1
