[PATCH] bsp/raspberrypi: Fix linker command file
Christian Mauderer
list at c-mauderer.de
Tue Feb 11 20:13:01 UTC 2020
Hello Sebastian,
yes, discard that patch.
Best regards
Christian
On 11/02/2020 16:22, Alan Cudmore wrote:
> I believe we can discard this. I am running all of my recent tests
> with the 0x200000 RAM origin.
> Thanks,
> Alan
> On Tue, Feb 11, 2020 at 2:06 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> Hello,
>> I guess that after all the Raspberry Pi changes this patch can be discarded?
>> On 20/12/2019 07:32, Sebastian Huber wrote:
>>> The RTEMS entry point must be at 0x8000.
>>> Update #3774.
>>> bsps/arm/raspberrypi/start/linkcmds.in | 13 ++++++-------
>>> 1 file changed, 6 insertions(+), 7 deletions(-)
>>> diff --git a/bsps/arm/raspberrypi/start/linkcmds.in b/bsps/arm/raspberrypi/start/linkcmds.in
>>> index d99b4fe23e..fde75877e7 100644
>>> --- a/bsps/arm/raspberrypi/start/linkcmds.in
>>> +++ b/bsps/arm/raspberrypi/start/linkcmds.in
>>> @@ -15,11 +15,12 @@
>>> MEMORY {
>>> - RAM_MMU (AIW) : ORIGIN = 0x00100000, LENGTH = @RPI_RAM_MMU_LENGTH@
>>> - RAM (AIW) : ORIGIN = 0x00200000, LENGTH = @RPI_RAM_LENGTH_AVAILABLE@ - @RPI_RAM_NOCACHE_LENGTH@
>>> + START (AIW) : ORIGIN = 0x00008000, LENGTH = 0xf8000
>>> + MMU (AIW) : ORIGIN = 0x00100000, LENGTH = @RPI_RAM_MMU_LENGTH@
>>> + RAM (AIW) : ORIGIN = 0x00200000, LENGTH = @RPI_RAM_LENGTH_AVAILABLE@ - @RPI_RAM_NOCACHE_LENGTH@
>>> -REGION_ALIAS ("REGION_START", RAM);
>>> +REGION_ALIAS ("REGION_START", START);
>>> REGION_ALIAS ("REGION_VECTOR", RAM);
>>> REGION_ALIAS ("REGION_TEXT", RAM);
>>> REGION_ALIAS ("REGION_TEXT_LOAD", RAM);
>>> @@ -41,9 +42,7 @@ bsp_stack_abt_size = DEFINED (bsp_stack_abt_size) ? bsp_stack_abt_size : 1024;
>>> bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align) ? bsp_section_rwbarrier_align : 1M;
>>> -bsp_vector_table_in_start_section = 1;
>>> -bsp_translation_table_base = ORIGIN (RAM_MMU);
>>> -bsp_translation_table_end = ORIGIN (RAM_MMU) + LENGTH (RAM_MMU);
>>> +bsp_translation_table_base = ORIGIN (MMU);
>>> +bsp_translation_table_end = ORIGIN (MMU) + LENGTH (MMU);
>>> INCLUDE linkcmds.armv4
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
