RTEMS Manuals: Single Page HTML version doesn't work
Christian Mauderer christian.mauderer at embedded-brains.de
Thu Feb 13 06:28:20 UTC 2020
Hello Chris,
On 13/02/2020 05:16, Chris Johns wrote:
> On 12/2/20 7:25 pm, Christian Mauderer wrote:
>> On 12/02/2020 00:11, Chris Johns wrote:
>>> On 12/2/20 12:41 am, Christian Mauderer wrote:
>>>> on docs.rtems.org we have a table with the manuals. There are three
>>>> views: Online, PDF and Single Page. It seems that Online and PDF work
>>>> fine. But Single Page doesn't work at all. Only a blank page is displayed.
>>>> Should we fix it or remove it?
>>> If it is fixable I think we should. Amar added single page support when the
>>> original shift from texinfo was done. I have kept it ever since.
>> OK. I wasn't sure whether it is a remnant from an old or intermediate
>> system or if it belongs to the current one. If it belongs to the current
>> one we should definitively fix it.
> It is useful if a user is deploying our documentation. I am not sure is
> something people building the docs normally do.
>>>> I think I know where I could remove it.
>>> Are you referring to rtems-docs or rtems-admin (my personal repo)?
>> I would have expected that the stuff on the table is generated with the
>> common/coverpage/static/rtems/js/catalogue.js in rtems-docs. At least
>> the table headers are there.
> The version in the docs repo lets you have a suitable cover page for the HTML
> generated docs. If you install a build of the docs you get a nice cover page
> which is similar to the online site. The online site's RTEMS JS is ..
> https://git.rtems.org/chrisj/rtems-admin.git/tree/docs/docs.rtems.org/static/rtems/js
> The tables are generated out the XML catalog files.
Ah OK. I wasn't aware that there are two cover pages.
>>> Does rtems-docs build with --singlehtml for you?
>> I had some troubles getting node.js inliner but now it builds.
> I have found node.js problematic on Ubuntu 18.something. An openssl ABI change
> in dot version broke the packaging. I do not remember any issues on FreeBSD.
Like said toward Amar: It wasn't a big problem. The package just isn't
available as a rpm for OpenSUSE.
>> The
>> single page HTML is created and installed just like expected.
> Great.
>>>> But I have no idea where it should have been generated
>>> It is generated via a con job under my account on sync.rtems.org and copied to a
>>> spot on the ftp server where it is picked up by the docs.rtems.org jail and
>>> installed.
>>> The build or generate line is ...
>>> https://git.rtems.org/chrisj/rtems-admin.git/tree/docs/builder/rtems-docs-build-branches#n135
>> Looks OK. There are some logs. Are they kept somewhere accessible?
> No but this is a good idea. I should push the logs to the handover location on
> ftp.rtems.org so anyone wanting to help can see if a build has broken. It
> happens from time to time. The handover path is ..
> https://git.rtems.org/chrisj/rtems-admin.git/tree/docs/builder/rtems-docs-upload#n21
> I am not sure when I will have time to add this feature.
No problem. The other forms of the manual work fine so it's no time
critical problem.
Best regards
Christian
> Chris
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
