[PATCH] testsuite/newlib: Check newlib does not touch an assigned std FILE pointer
chrisj at rtems.org chrisj at rtems.org
Fri Feb 14 03:41:40 UTC 2020
Update #3870
 testsuites/libtests/newlib01/init.c | 16 +++++++++++++++-
 1 file changed, 15 insertions(+), 1 deletion(-)
diff --git a/testsuites/libtests/newlib01/init.c b/testsuites/libtests/newlib01/init.c
index 74e648799e..1bff052363 100644
--- a/testsuites/libtests/newlib01/init.c
+++ b/testsuites/libtests/newlib01/init.c
@@ -23,6 +23,8 @@
 #include <rtems/imfs.h>
 #include <rtems/libcsupport.h>
+#include <rtems/bspIo.h>
 #include "tmacros.h"
 const char rtems_test_name[] = "NEWLIB 1";
@@ -63,12 +65,24 @@ static void wait(void)
 static void worker_task(rtems_task_argument arg)
   test_context *ctx = &test_instance;
+  struct _reent *reent = __getreent();
+  FILE *output;
   char buf[1] = { 'x' };
   size_t n;
-  stdout = fopen(&file_path[0], "r+");
+  rtems_test_assert(reent->__sdidinit == 0);
+  output = stdout = fopen(&file_path[0], "r+");
   rtems_test_assert(stdout != NULL);
+   * Check newlib's __sinit does not touch our assigned file pointer.
+  fflush(stdout);
+  rtems_test_assert(reent->__sdidinit != 0);
+  rtems_test_assert(stdout == output);
   n = fwrite(&buf[0], sizeof(buf), 1, stdout);
   rtems_test_assert(n == 1);
2.23.0
