[PATCH] tester: Add qemu_opts_serial
Fri Feb 14 06:03:32 UTC 2020
On 14/02/2020 04:00, Chris Johns wrote:
> I must be must be mising what has changed. I cannot see the "wrong
> options that have changed?
I removed the serial/monitor settings from qemu_opts_base and moved them
to the new qemu_opts_serial. The realview_pbx_a9_qemu doesn't work with
the serial settings.
>> -%define qemu_opts_no_net -net none
> Why move?
The definitions are now ordered from general to specific, e.g.
qemu_opts_base is the first.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200214/5a39dd85/attachment.html>
