[PATCH] objectdata.h, objectimpl.h: Change structure member from free to deallocate
Fri Feb 14 06:31:56 UTC 2020
Hello Joel,
On 13/02/2020 07:31, Sebastian Huber wrote:
> On 13/02/2020 01:17, Joel Sherrill wrote:
>> Without this change, rtems-libbsd does not compile. A macro turns
>> free into bsd_free.
>> Also the use of a standard library element as a program identifier
>> is a violation of a MISRA rule. Turns out that was a good rule.:)
> Thanks, looks good.
I pushed the change for you, since I also want to build libbsd
occasionally ;-)
