[PATCH] posix: Remove <rtems/posix/ptimer.h>
Fri Feb 14 10:56:24 UTC 2020
This file contained duplicate prototypes for standard POSIX functions
declared in <time.h>.
 cpukit/headers.am                   |  1 -
 cpukit/include/rtems/posix/ptimer.h | 88 -------------------------------------
 cpukit/posix/src/timersettime.c     |  1 -
 3 files changed, 90 deletions(-)
 delete mode 100644 cpukit/include/rtems/posix/ptimer.h
diff --git a/cpukit/headers.am b/cpukit/headers.am
index aa2db5771a..6f44b833e1 100644
--- a/cpukit/headers.am
+++ b/cpukit/headers.am
@@ -203,7 +203,6 @@ include_rtems_posix_HEADERS += include/rtems/posix/psignalimpl.h
 include_rtems_posix_HEADERS += include/rtems/posix/pthread.h
 include_rtems_posix_HEADERS += include/rtems/posix/pthreadattrimpl.h
 include_rtems_posix_HEADERS += include/rtems/posix/pthreadimpl.h
-include_rtems_posix_HEADERS += include/rtems/posix/ptimer.h
 include_rtems_posix_HEADERS += include/rtems/posix/rwlockimpl.h
 include_rtems_posix_HEADERS += include/rtems/posix/semaphore.h
 include_rtems_posix_HEADERS += include/rtems/posix/semaphoreimpl.h
diff --git a/cpukit/include/rtems/posix/ptimer.h b/cpukit/include/rtems/posix/ptimer.h
deleted file mode 100644
index f6de4ccb57..0000000000
--- a/cpukit/include/rtems/posix/ptimer.h
+++ /dev/null
@@ -1,88 +0,0 @@
- * @file
- * @brief POSIX Timers Private Support
- * This include file contains all the private support information for
- * POSIX timers.
- *  Initial Implementation:
- *    COPYRIGHT (c) 1998.  Alfonso Escalera Piña
- *    Largely rewritten by Joel Sherrill (1999).
- *  COPYRIGHT (c) 1999-2013.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#ifndef _RTEMS_POSIX_PTIMER_H
-#define _RTEMS_POSIX_PTIMER_H
- * @defgroup POSIX_PRIV_TIMERS POSIX Timers
- * @ingroup POSIXAPI
-#ifdef __cplusplus
-extern "C" {
-#endif
-#include <rtems/posix/config.h>
- *  @brief Create a Per-Process Timer
-int timer_create(
-  clockid_t        clock_id,
-  struct sigevent *evp,
-  timer_t         *timerid
- *  @brief Delete a Per-Process Timer
-int timer_delete(
-  timer_t timerid
- *  @brief Set a Per-Process Timer
-int timer_settime(
-  timer_t                  timerid,
-  int                      flags,
-  const struct itimerspec *value,
-  struct itimerspec       *ovalue
-int timer_gettime(
-  timer_t            timerid,
-  struct itimerspec *value
- * @brief Get overrun count for a Per-Process Timer
- * The expiration of a timer must increase by one a counter.
- * After the signal handler associated to the timer finishes
- * its execution, _POSIX_Timer_TSR will have to set this counter to 0.
-int timer_getoverrun(
-  timer_t   timerid
-#ifdef __cplusplus
-#endif
-#endif /* _RTEMS_POSIX_PTIMER_H */
diff --git a/cpukit/posix/src/timersettime.c b/cpukit/posix/src/timersettime.c
index 9212e49740..eb89029e29 100644
--- a/cpukit/posix/src/timersettime.c
+++ b/cpukit/posix/src/timersettime.c
@@ -23,7 +23,6 @@
 #include <time.h>
-#include <rtems/posix/ptimer.h>
 #include <rtems/posix/timerimpl.h>
2.16.4
