Remove support for RTEMS_SCHEDSIM?
Fri Feb 14 14:31:16 UTC 2020
Hello,
there is a RTEMS_SCHEDSIM define which is used in a couple of files:
./cpukit/include/rtems/confdefs.h:#ifdef RTEMS_SCHEDSIM
./cpukit/include/rtems/confdefs.h:#ifndef RTEMS_SCHEDSIM
./cpukit/include/rtems/confdefs.h:    #if !defined(RTEMS_SCHEDSIM) \
./cpukit/include/rtems/confdefs.h:#if !defined(RTEMS_SCHEDSIM)
./cpukit/include/rtems/confdefs.h:#endif   /* !defined(RTEMS_SCHEDSIM) */
./cpukit/include/rtems/score/basedefs.h:#if defined(RTEMS_SCHEDSIM)
./cpukit/include/rtems/score/basedefs.h:#if defined(RTEMS_DEBUG) &&
./cpukit/include/rtems/score/basedefs.h:#if defined(__GNUC__) &&
./cpukit/include/rtems/score/assert.h:  #if !defined( RTEMS_SCHEDSIM )
This define is related to the scheduler simulator:
https://git.rtems.org/rtems-schedsim/tree/schedsim
The last update was five years ago. I made a quick review and it is
probably horribly out of synchronization. If someone is interested in
the scheduler simulator, I think it should be resurrected via the new
build system. The <rtems/score/basedefs.h> and <rtems/score/assert.h>
should be provided by the scheduler simulator. With the split up of
confdefs.h I think the RTEMS_SCHEDSIM handling in this file will be
obsolete.
The problem with this define is that it cannot within RTEMS.
