[PATCH 11/18] config: Add _Watchdog_Ticks_per_timeslice
Sebastian Huber
Fri Feb 14 16:02:36 UTC 2020
Move the ticks per timeslice configuration constant out of the
configuration table.
Add WATCHDOG_TICKS_PER_TIMESLICE_DEFAULT and use it to provide a default
definition of the watchdog ticks per timeslice constant.
Update #3875.
cpukit/Makefile.am | 1 +
cpukit/include/rtems/confdefs.h | 11 ++++++---
cpukit/include/rtems/config.h | 7 +-----
cpukit/include/rtems/score/watchdogticks.h | 13 +++++++++++
cpukit/score/src/watchdogtimeslicedefault.c | 35 +++++++++++++++++++++++++++++
5 files changed, 58 insertions(+), 9 deletions(-)
create mode 100644 cpukit/score/src/watchdogtimeslicedefault.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index c3bdd284cd..4a793bf1f9 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -1003,6 +1003,7 @@ librtemscpu_a_SOURCES += score/src/watchdogremove.c
librtemscpu_a_SOURCES += score/src/watchdogtick.c
librtemscpu_a_SOURCES += score/src/watchdogticksdefault.c
librtemscpu_a_SOURCES += score/src/watchdogtickssinceboot.c
+librtemscpu_a_SOURCES += score/src/watchdogtimeslicedefault.c
librtemscpu_a_SOURCES += score/src/userextaddset.c
librtemscpu_a_SOURCES += score/src/userext.c
librtemscpu_a_SOURCES += score/src/userextremoveset.c
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index 4c2c80b2a9..6542c2a26d 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -1989,10 +1989,16 @@ extern "C" {
#endif /* CONFIGURE_MICROSECONDS_PER_TICK */
/** The configures the number of clock ticks per timeslice. */
-#ifndef CONFIGURE_TICKS_PER_TIMESLICE
- #define CONFIGURE_TICKS_PER_TIMESLICE 50
+#if defined(CONFIGURE_TICKS_PER_TIMESLICE) && \
+ CONFIGURE_TICKS_PER_TIMESLICE != WATCHDOG_TICKS_PER_TIMESLICE_DEFAULT
+#ifdef CONFIGURE_INIT
+ const uint32_t _Watchdog_Ticks_per_timeslice =
+ CONFIGURE_TICKS_PER_TIMESLICE;
#endif
+#endif /* CONFIGURE_TICKS_PER_TIMESLICE */
/**@}*/ /* end of General Configuration */
@@ -2648,7 +2654,6 @@ struct _reent *__getreent(void)
const rtems_configuration_table Configuration = {
CONFIGURE_EXECUTIVE_RAM_SIZE, /* required RTEMS workspace */
- CONFIGURE_TICKS_PER_TIMESLICE, /* ticks per timeslice quantum */
CONFIGURE_IDLE_TASK_BODY, /* user's IDLE task */
CONFIGURE_IDLE_TASK_STACK_SIZE, /* IDLE task stack size */
#ifdef CONFIGURE_UNIFIED_WORK_AREAS /* true for unified work areas */
diff --git a/cpukit/include/rtems/config.h b/cpukit/include/rtems/config.h
index 84917366f3..31a667a1d6 100644
--- a/cpukit/include/rtems/config.h
+++ b/cpukit/include/rtems/config.h
@@ -86,11 +86,6 @@ typedef struct {
uintptr_t work_space_size;
- * This field specifies the number of ticks in each task's timeslice.
- uint32_t ticks_per_timeslice;
* This element points to the BSP's optional idle task which may override
* the default one provided with RTEMS.
@@ -163,7 +158,7 @@ uint32_t rtems_configuration_get_maximum_extensions( void );
(_Watchdog_Nanoseconds_per_tick)
#define rtems_configuration_get_ticks_per_timeslice() \
- (Configuration.ticks_per_timeslice)
+ (_Watchdog_Ticks_per_timeslice)
#define rtems_configuration_get_idle_task() \
(Configuration.idle_task)
diff --git a/cpukit/include/rtems/score/watchdogticks.h b/cpukit/include/rtems/score/watchdogticks.h
index eaeddb5e6b..11007c9310 100644
--- a/cpukit/include/rtems/score/watchdogticks.h
+++ b/cpukit/include/rtems/score/watchdogticks.h
@@ -47,6 +47,11 @@ typedef uint32_t Watchdog_Interval;
#define WATCHDOG_MICROSECONDS_PER_TICK_DEFAULT 10000
+ * @brief Default value for the watchdog ticks per timeslice.
+#define WATCHDOG_TICKS_PER_TIMESLICE_DEFAULT 50
* @brief The watchdog ticks counter.
@@ -78,6 +83,14 @@ extern const uint32_t _Watchdog_Nanoseconds_per_tick;
extern const uint32_t _Watchdog_Ticks_per_second;
+ * @brief The watchdog ticks per timeslice.
+ * This constant is defined by the application configuration via
+ * <rtems/confdefs.h>.
+extern const uint32_t _Watchdog_Ticks_per_timeslice;
#ifdef __cplusplus
diff --git a/cpukit/score/src/watchdogtimeslicedefault.c b/cpukit/score/src/watchdogtimeslicedefault.c
new file mode 100644
index 0000000000..369cf5b0ae
--- /dev/null
+++ b/cpukit/score/src/watchdogtimeslicedefault.c
@@ -0,0 +1,35 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 embedded brains GmbH
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/watchdogticks.h>
+const uint32_t _Watchdog_Ticks_per_timeslice =
+ WATCHDOG_TICKS_PER_TIMESLICE_DEFAULT;
2.16.4
