[PATCH 3/6] config: CONFIGURE_INIT_TASK_INITIAL_MODES
Sat Feb 15 12:36:20 UTC 2020
Determine the default for CONFIGURE_INIT_TASK_INITIAL_MODES depeding on
whether RTEMS_SMP is defined or not.
In the tests, use CONFIGURE_INIT_TASK_INITIAL_MODES to explicitly
request RTEMS_NO_PREEMPT mode if necessary.
Update #3876.
 cpukit/include/rtems/confdefs.h           | 2 +-
 testsuites/sptests/sp66/init.c            | 1 +
 testsuites/sptests/spsimplesched02/init.c | 2 ++
 3 files changed, 4 insertions(+), 1 deletion(-)
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index bbbaa9d6d1..eb837fd389 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -1304,7 +1304,7 @@ const Thread_Idle_body _Thread_Idle_body = CONFIGURE_IDLE_TASK_BODY;
  * used to specify the initial execution mode of the single Classic API task.
 #ifndef CONFIGURE_INIT_TASK_INITIAL_MODES
-  #ifdef _CONFIGURE_SMP_APPLICATION
+  #ifdef RTEMS_SMP
     #define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_DEFAULT_MODES
   #else
     #define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_NO_PREEMPT
diff --git a/testsuites/sptests/sp66/init.c b/testsuites/sptests/sp66/init.c
index f2bf46d049..3dd8e75a32 100644
--- a/testsuites/sptests/sp66/init.c
+++ b/testsuites/sptests/sp66/init.c
@@ -1,2 +1,3 @@
 #define INHERIT_CEILING
+#define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_NO_PREEMPT
 #include "../sp65/sp65impl.h"
diff --git a/testsuites/sptests/spsimplesched02/init.c b/testsuites/sptests/spsimplesched02/init.c
index b7b1a21919..4a08a6c8ac 100644
--- a/testsuites/sptests/spsimplesched02/init.c
+++ b/testsuites/sptests/spsimplesched02/init.c
@@ -154,6 +154,8 @@ rtems_task Init(
 #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
 #define CONFIGURE_EXTRA_TASK_STACKS         (3 * RTEMS_MINIMUM_STACK_SIZE)
 #define CONFIGURE_INIT_TASK_PRIORITY        4
 #define CONFIGURE_DISABLE_SMP_CONFIGURATION
2.16.4
