[PATCH 18/18] config: Add <rtems/confdefs/obsolete.h>
Gedare Bloom
gedare at rtems.org
Sat Feb 15 16:23:48 UTC 2020
On Sat, Feb 15, 2020 at 7:16 AM Joel Sherrill <joel at rtems.org> wrote:
> On Sat, Feb 15, 2020, 2:38 AM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> On 15/02/2020 05:22, Gedare Bloom wrote:
>> > This makes sense. Is there any reason for the ordering?
>> It should be alphabetically sorted.
>> > If possible, I think grouping by obsoleted version or alphabetical
>> > ordering would be a good idea.
>> Maybe I should add a comment like this to the top of the list:
>> * Please keep the list of obsolete configuration options
>> * Use #warning for renamed options and define the new option
>> accordingly.
>> * Use #warning for obsolete options which are now superfluous, e.g.
>> because
>> * the objects are now self-contained.
>> * Use #error for options which require now a different configuration
>> approach,
>> * e.g. options for an own configuration table.
> And note when perhaps with a version when an option was deemed obsolete.
> You might be able to get that from git blame in the future but for now we
> just destroyed all that info for blame by creating a new file.
+1 the internal documentation should explicitly say that. It looks like the
existing warnings do spit out the version of obsolescence.
Some of the macros are out-of-order.
I noticed that there is N -> M -> L that are backwards.
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200215/c90b93cc/attachment.html>
