[PATCH v4] doc/raspberrypi: Added instructions for raspberrypi
Christian Mauderer
list at c-mauderer.de
Sat Feb 15 19:08:46 UTC 2020
Hello Niteesh,
thanks. I pushed it:
https://git.rtems.org/rtems-docs/commit/?id=5763454b307afae6f5feb7e6d3d3d780f05f83ab
Best regards
Christian
On 15/02/2020 15:20, G. S. Niteesh wrote:
> Another remainder.
> Can someone please push this?
> Thanks,
> Niteesh
> On Thu, Feb 13, 2020 at 11:19 PM G. S. Niteesh <gsnb.gn at gmail.com
> <mailto:gsnb.gn at gmail.com>> wrote:
> On Thu, Feb 13, 2020 at 11:16 PM Alan Cudmore
> <alan.cudmore at gmail.com <mailto:alan.cudmore at gmail.com>> wrote:
> "set scheduler-locking on" in GDB works! I was able to run RPI2
> hello.exe
> So I consider your instructions ready to go in the repo.
> More Pi 2 SMP debugging when I get the time..
> Thanks!
> Alan
> Great. But just a caution, QEMU support raspberry pi is very
> much incomplete
> so any exception or problem may be from QEMU side and not RTEMS. So
> if any
> test goes wrong, try running it on a real board.
> Thanks,
> Niteesh
> On Thu, Feb 13, 2020 at 12:30 PM G. S. Niteesh
> <gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>> wrote:
> > On Thu, Feb 13, 2020 at 10:57 PM Alan Cudmore
> >> I get exceptions when trying to run hello.exe.
> >> I'm using qemu-system-arm v 2.11.1 from ubuntu. Should I try
> using the
> >> one built by RSB?
> > No this should be fine. Can you post a screenshot of the output?
> >> I was trying to get this setup to try RPI 2 SMP in QEMU. I
> may want to
> >> get the latest repo and do a clean build to try this again.
> > SMP doesn't work well with QEMU. Did you try set
> scheduler-locking on in GDB?
> > Running the executables directly in QEMU doesn't work.
> >> Thanks,
> >> Alan
> >> On Thu, Feb 13, 2020 at 12:12 PM G. S. Niteesh
> >> > On Thu, Feb 13, 2020 at 10:40 PM Alan Cudmore
> >> >> Hi Niteesh,
> >> >> I have followed your instructions for getting RTEMS
> running on the Pi
> >> >> 1 and 2. SMP currently is not working on the 2 for me, but
> that is not
> >> >> a problem with these instructions.
> >> >> I started to try running on QEMU following your
> instructions but have
> >> >> not been able to get time to complete my tests.
> >> > What problem are you exactly facing?
> >> >> But this is a vast improvement over "TODO", so I recommend
> accepting
> >> >> this change.
> >> >> Thanks for creating this,
> >> >> Alan
> >> >> On Thu, Feb 13, 2020 at 1:49 AM G. S. Niteesh
> >> >> > Can someone take a look at this, It has been unnoticed
> for quite a while.
> >> >> > Thank you,
> >> >> > Niteesh
> >> >> > On Sat, Jan 25, 2020 at 10:49 PM G S Niteesh
> >> >> >> Added instructions to run examples on raspberrypi.
> >> >> >> user/bsps/arm/raspberrypi.rst | 111
> >> >> >> 1 file changed, 110 insertions(+), 1 deletion(-)
> >> >> >> diff --git a/user/bsps/arm/raspberrypi.rst
> b/user/bsps/arm/raspberrypi.rst
> >> >> >> index 4ef75bd..72889a5 100644
> >> >> >> --- a/user/bsps/arm/raspberrypi.rst
> >> >> >> +++ b/user/bsps/arm/raspberrypi.rst
> >> >> >> @@ -5,4 +5,113 @@
> >> >> >> raspberrypi
> >> >> >> -TODO.
> >> >> >> +This BSP supports `Raspberry Pi 1` and `Raspberry Pi
> 2` currently.
> >> >> >> +The support for `Raspberry Pi 3` is work under progress.
> >> >> >> +The default bootloader on the Raspberry Pi which is
> used to boot Raspbian
> >> >> >> +or other OS can be also used to boot RTEMS. U-boot can
> also be used.
> >> >> >> +Setup SD card
> >> >> >> +The Raspberry Pis have an unconventional booting
> mechanism. The GPU
> >> >> >> +boots first, initializes itself, runs the bootloader
> and starts the CPU.
> >> >> >> +The bootloader looks for a kernel image, by default
> the kernel images must
> >> >> >> +have a name of the form ``kernel*.img`` but this can
> be changed by adding
> >> >> >> +`kernel=<img_name>` to ``config.txt``.
> >> >> >> +You must provide the required files for the GPU to
> proceed. These files
> >> >> >> +can be downloaded from
> >> >> >> +`the Raspberry Pi Firmware Repository
> <https://github.com/raspberrypi/firmware/tree/master/boot>`_.
> >> >> >> +You can remove the ``kernel*.img`` files if you want
> too, but don't touch
> >> >> >> +the other files.
> >> >> >> +Copy these files in to a SD card with FAT filesystem.
> >> >> >> +Kernel image
> >> >> >> +The following steps show how to run ``hello.exe`` on a
> Raspberry Pi 2.
> >> >> >> +The same instructions can be applied to Raspberry Pi 1
> also.
> >> >> >> +Other executables can be processed in a similar way.
> >> >> >> +To create the kernel image:
> >> >> >> +.. code-block:: none
> >> >> >> + $ arm-rtems5-objcopy -Obinary hello.exe kernel.img
> >> >> >> +Copy the kernel image to the SD card.
> >> >> >> +Make sure you have these lines below, in your
> ``config.txt``.
> >> >> >> + enable-uart=1
> >> >> >> + kernel_address=0x200000
> >> >> >> + kernel=kernel.img
> >> >> >> +Testing using QEMU
> >> >> >> +QEMU can be built using RSB. Navigate to
> ``<SOURCE_BUILDER_DIR>/rtems``
> >> >> >> +and run this command.
> >> >> >> + $ ../source-builder/sb-set-builder
> --prefix=<TOOLCHAIN_DIR> devel/qemu4.bset
> >> >> >> +**Note**: Replace ``<SOURCE_BUILDER_DIR>`` and
> ``<TOOLCHAIN_DIR>`` with the
> >> >> >> +correct path of the directories. For example, if you
> used quick-start section
> >> >> >> +as your reference, these two will be
> ``$HOME/quick-start/src/rsb`` and
> >> >> >> +``$HOME/quick-start/rtems/5`` respectively,
> >> >> >> +QEMU along with GDB can be used for debugging, but it
> only supports
> >> >> >> +Raspberry Pi 2 and the emulation is also incomplete.
> So some of the
> >> >> >> +features might not work as expected.
> >> >> >> +Make sure your version of QEMU is newer than v2.6,
> because older ones don't
> >> >> >> +support Raspberry Pis.
> >> >> >> + $ qemu-system-arm -M raspi2 -m 1G -kernel
> hello.exe -serial mon:stdio -nographic -S -s
> >> >> >> +This starts QEMU and creates a socket at port
> ``localhost:1234`` for GDB to
> >> >> >> +connect.
> >> >> >> +The Device Tree Blob (DTB) is needed to load the
> device tree while starting up
> >> >> >> +the kernel. The BSP uses information from this file to
> initialize the drivers.
> >> >> >> +Make sure you pass in the correct DTB file. There are
> currently two version of
> >> >> >> +DTB for the Raspberry Pi 2 ``bcm2709-rpi-2-b.dtb`` and
> ``bcm2710-rpi-2-b.dtb``.
> >> >> >> +The ``bcm2709-rpi-2-b.dtb`` is for Raspberry Pi 2
> Model B and
> >> >> >> +``bcm2710-rpi-2-b.dtb`` is for Raspberry Pi 2 Model B v1.2
> >> >> >> +We need to pass in the DTB file to GDB before running
> the example.
> >> >> >> +In a new terminal, run GDB using
> >> >> >> + $ arm-rtems5-gdb hello.exe
> >> >> >> +This will open GDB and will load the symbol table from
> hello.exe. Issue the
> >> >> >> +following commands in the GDB prompt.
> >> >> >> + (gdb) tar remote:1234
> >> >> >> + (gdb) load
> >> >> >> + (gdb) restore bcm2709-rpi-2-b.dtb binary 0x2ef00000
> >> >> >> + (gdb) set $r2 = 0x2ef00000
> >> >> >> +This will connect GDB to QEMU and will load the DTB
> file and the application.
> >> >> >> + (gdb) continue
> >> >> >> +The ``continue`` command will run the executable.
> >> >> >> +**Note**: Add ``set scheduler-locking on`` in GDB if
> you have any issues
> >> >> >> +running the examples.
> >> >> >> 2.17.1
> >> >> > _______________________________________________
> >> >> > devel mailing list
> >> >> > devel at rtems.org <mailto:devel at rtems.org>
> >> >> > http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
