[PATCH 07/18] config: Bring back RTEMS 4.11 configuration table
Sebastian Huber
Sun Feb 16 07:19:23 UTC 2020
On 16/02/2020 00:30, Chris Johns wrote:
> On 2020-02-15 03:02, Sebastian Huber wrote:
>> This improves API backward compatibility of RTEMS 5.1 to previous
>> versions.
> What is the purpose of this change? How does a user wanting backward
> compatibility use this change?
There may be applications which used
rtems_configuration_get_rtems_api_configuration() for diagnostic purposes.
> How long do we maintain this interface?
As long as we have a Classic API.
> We clearly document users should not create configuration tables and
> you are working to provide solid interfaces yet we have an interface
> for backwards compatibility.
We have two interfaces, one that creates the configuration, the
documented interface for this is <rtems/confdefs.h> and the configure
option. The second interface is there to query the configuration. This
is done through the rtems_configuration_*() macros/functions. This patch
restores backward compatibility for the configuration query API.
> Why in this specific case do we have to do this? Is there an app or
> user in mind that needs this?
No, I just thought it is a good idea to keep the configuration query API
intact.
