[PATCH v3 2/2] bsp/raspberrypi: Mini UART driver
G. S. Niteesh
gsnb.gn at gmail.com
Sun Feb 16 17:30:15 UTC 2020
Hii Alan,
I tested it on my Raspberry Pi 3 model b v1.2 and it works.
U-Boot is not required anymore :)
Thanks,
Niteesh.
On Sun, Feb 16, 2020 at 10:51 PM Alan Cudmore <alan.cudmore at gmail.com>
wrote:
> I'm definitely using the kernel_address, but letting the firmware
> decide what image to boot. For me kernel.img is the single core ARM
> images. kernel7.img is used for the raspberry pi 2 and 3. With these
> names, I can have both images on the same SD card to test in all of my
> Pis.
> my config.txt:
> enable_uart=1
> kernel_address=0x200000
> On Sun, Feb 16, 2020 at 11:44 AM Christian Mauderer <list at c-mauderer.de>
> wrote:
> > On 16/02/2020 17:31, G. S. Niteesh wrote:
> > > Can you please share your config.txt for Pi3.
> > +1
> > It's interesting that it seems to work without an adapted config.txt. It
> > should be at least necessary to define the start address.
> > > Thanks,
> > > Niteesh
> > > On Sun, Feb 16, 2020 at 9:58 PM Alan Cudmore <alan.cudmore at gmail.com
> > > <mailto:alan.cudmore at gmail.com>> wrote:
> > > I tried running my raspberrypi BSP image that worked on the Pi Zero
> > > and W, but it did not work on the Pi 3.
> > > I built the raspberrypi2 BSP, used objcopy to copy the binary to
> my sd
> > > card as kernel7.img, and it works on my Pi 3 and Pi3 A+ ( without
> > > ethernet) . Note that my config.txt file does not specify the
> kernel
> > > image, so the firmware defaults to kernel.img for the single core
> > > models and kernel7.img for the 2 and 3.
> > > I probably wont get a chance to try u-boot until later today or
> > > tomorrow.
> > > But these patches are great for enabling the Pi Zero W and Pi 3
> models!
> > > Thanks,
> > > Alan
> > > On Sun, Feb 16, 2020 at 10:58 AM G. S. Niteesh <gsnb.gn at gmail.com
> > > <mailto:gsnb.gn at gmail.com>> wrote:
> > > > On Sun, Feb 16, 2020 at 8:37 PM Alan Cudmore
> > > <alan.cudmore at gmail.com <mailto:alan.cudmore at gmail.com>> wrote:
> > > >> Hi Niteesh,
> > > >> I can try this patch on my Pi 3. Which BSP should I use? Is
> there any
> > > >> special setup or BSP configuration needed?
> > > >> Thanks,
> > > >> Alan
> > > > Hi Alan,
> > > > First of all, thank you for taking this initiative.
> > > > I have tried using the default bootloader in Pi3 to load RTEMS
> but
> > > it doesn't work,
> > > > Can you try it?
> > > > The currently use U-Boot in 32bit mode as the bootloader.
> > > > You can use the below instructions to build U-Boot in 32bit mode
> > > > git clone https://github.com/u-boot/u-boot.git u-boot
> > > > cd u-boot
> > > > git revert 995eab8b5b580b67394312b1621c60a71042cd18
> > > > make CROSS_COMPILE=arm-linux-gnueabi- rpi_3_32b_defconfig
> > > > This one uses an old version of U-Boot and I don't know if there
> is
> > > > a new way to build in 32bit mode.
> > > > To build the U-Boot image of RTEMS you can use the below
> instructions
> > > > arm-rtems5-objcopy -Obinary hello.exe kernel.img
> > > > mkimage -A arm -O linux -T kernel -a 0x200000 -e 0x200080 -d
> > > kernel.img -C none rtems.img
> > > > To load and run in U-Boot
> > > > fatload mmc 0 0x200000 rtems.img
> > > > fatload mmc 0 0x1000 bcm2710-rpi-3-b.dtb
> > > > bootm 0x200000 - 0x1000
> > > > And to make your U-Boot build process simpler I have uploaded my
> > > u-boot.bin
> > > > to my github, please use it :)
> > > > https://github.com/gs-niteesh/rpi3_RTEMS
> > > > And sorry for the delay, I tested all these instructions again
> > > before sending them.
> > > > Thanks
> > > > Niteesh.
> > > > On Sun, Feb 16, 2020 at 2:35 AM G. S. Niteesh <
> > > >> > Hii,
> > > >> > This is a reminder message since this patch has been unnoticed
> > > for a while.
> > > >> > I have tested it on Raspberry Pi 3 and it works fine. There is
> > > also another patch
> > > https://lists.rtems.org/pipermail/devel/2020-February/057194.html,
> > > please
> > > >> > do have a look at these.
> > > >> > Thank you.
> > > >> > Niteesh
> > > >> > On Mon, Feb 10, 2020 at 12:52 AM G S Niteesh <
> > > >> >> This patch adds driver for Mini UART present in Raspberry Pi
> 3
> > > >> >> and above, this UART is currently used as the primary UART in
> > > >> >> these models.
> > > >> >> The Mini UART is similar to ns16550, this driver is built
> > > >> >> upon libchip/ns16550.
> > > >> >> bsps/arm/raspberrypi/console/console-config.c | 118
> > > >> >> bsps/arm/raspberrypi/include/bsp/usart.h | 1 +
> > > >> >> 2 files changed, 110 insertions(+), 9 deletions(-)
> > > >> >> diff --git a/bsps/arm/raspberrypi/console/console-config.c
> > > b/bsps/arm/raspberrypi/console/console-config.c
> > > >> >> index 48c4c6a3ec..62196786dd 100644
> > > >> >> --- a/bsps/arm/raspberrypi/console/console-config.c
> > > >> >> +++ b/bsps/arm/raspberrypi/console/console-config.c
> > > >> >> @@ -24,6 +24,7 @@
> > > >> >> #include <libchip/serial.h>
> > > >> >> #include <libfdt.h>
> > > >> >> +#include <libchip/ns16550.h>
> > > >> >> #include <bspopts.h>
> > > >> >> #include <bsp/usart.h>
> > > >> >> @@ -34,35 +35,103 @@
> > > >> >> #include <bsp/console-termios.h>
> > > >> >> #include <bsp/fdt.h>
> > > >> >> #include <bsp/fatal.h>
> > > >> >> +#include <bsp/gpio.h>
> > > >> >> +#include <bsp/rpi-gpio.h>
> > > >> >> -#define UART0 "/dev/ttyS0"
> > > >> >> + * UART0 - PL011
> > > >> >> + * UART1 - Mini UART
> > > >> >> +#define PL011 "/dev/ttyAMA0"
> > > >> >> +#define MINIUART "/dev/ttyS0"
> > > >> >> #define FBCONS "/dev/fbcons"
> > > >> >> arm_pl011_context pl011_context;
> > > >> >> +ns16550_context mini_uart_context;
> > > >> >> rpi_fb_context fb_context;
> > > >> >> -static void output_char_serial(char c)
> > > >> >> +static void output_char_pl011(char c)
> > > >> >> arm_pl011_write_polled(&pl011_context.base, c);
> > > >> >> +static void output_char_mini_uart(char c)
> > > >> >> + ns16550_polled_putchar(&mini_uart_context.base, c);
> > > >> >> void output_char_fb(char c)
> > > >> >> fbcons_write_polled(&fb_context.base, c);
> > > >> >> +static uint8_t mini_uart_get_reg(uintptr_t port, uint8_t
> index)
> > > >> >> + volatile uint32_t *val = (volatile uint32_t *)port +
> index;
> > > >> >> + return (uint8_t) *val;
> > > >> >> +static void mini_uart_set_reg(uintptr_t port, uint8_t index,
> > > uint8_t val)
> > > >> >> + volatile uint32_t *reg = (volatile uint32_t *)port +
> index;
> > > >> >> + *reg = val;
> > > >> >> static void init_ctx_arm_pl011(
> > > >> >> const void *fdt,
> > > >> >> int node
> > > >> >> arm_pl011_context *ctx = &pl011_context;
> > > >> >> - rtems_termios_device_context_initialize(&ctx->base,
> "UART");
> > > >> >> + rtems_termios_device_context_initialize(&ctx->base,
> > > "PL011UART");
> > > >> >> ctx->regs = raspberrypi_get_reg_of_node(fdt, node);
> > > >> >> +static uint32_t calculate_baud_divisor(
> > > >> >> + ns16550_context *ctx,
> > > >> >> + uint32_t baud
> > > >> >> + uint32_t baudDivisor = (ctx->clock / (8 * baud)) - 1;
> > > >> >> + return baudDivisor;
> > > >> >> +static void init_ctx_mini_uart(
> > > >> >> + const void *fdt,
> > > >> >> + int node
> > > >> >> + const char *status;
> > > >> >> + int len;
> > > >> >> + ns16550_context *ctx;
> > > >> >> + memset(&mini_uart_context, 0, sizeof(mini_uart_context));
> > > >> >> + ctx = &mini_uart_context;
> > > "MiniUART");
> > > >> >> + status = fdt_getprop(fdt, node, "status", &len);
> > > >> >> + if ( status == NULL || strcmp(status, "disabled" ) == 0){
> > > >> >> + return ;
> > > >> >> + ctx->port = (uintptr_t) raspberrypi_get_reg_of_node(fdt,
> node);
> > > >> >> + ctx->initial_baud = MINI_UART_DEFAULT_BAUD;
> > > >> >> + ctx->clock = BCM2835_CLOCK_FREQ;
> > > >> >> + ctx->calculate_baud_divisor = calculate_baud_divisor;
> > > >> >> + ctx->get_reg = mini_uart_get_reg;
> > > >> >> + ctx->set_reg = mini_uart_set_reg;
> > > >> >> + rtems_gpio_bsp_select_specific_io(0, 14, RPI_ALT_FUNC_5,
> NULL);
> > > >> >> + rtems_gpio_bsp_select_specific_io(0, 15, RPI_ALT_FUNC_5,
> NULL);
> > > >> >> + rtems_gpio_bsp_set_resistor_mode(0, 14, NO_PULL_RESISTOR);
> > > >> >> + rtems_gpio_bsp_set_resistor_mode(0, 15, NO_PULL_RESISTOR);
> > > >> >> + BCM2835_REG(AUX_ENABLES) |= 0x1;
> > > >> >> + ns16550_probe(&ctx->base);
> > > >> >> static void register_fb( void )
> > > >> >> if (fbcons_probe(&fb_context.base) == true) {
> > > >> >> @@ -87,16 +156,28 @@ static void console_select( void )
> > > >> >> link(FBCONS, CONSOLE_DEVICE_NAME);
> > > >> >> return ;
> > > >> >> + } else if ( strncmp( opt, MINIUART, sizeof(MINIUART) - 1
> > > ) == 0) {
> > > >> >> + BSP_output_char = output_char_mini_uart;
> > > >> >> + link(MINIUART, CONSOLE_DEVICE_NAME);
> > > >> >> + } else if ( strncmp( opt, PL011, sizeof(PL011) - 1 ) ==
> 0) {
> > > >> >> + BSP_output_char = output_char_pl011;
> > > >> >> + link(PL011, CONSOLE_DEVICE_NAME);
> > > >> >> + }else {
> > > >> >> + * If no command line option was given, default to
> PL011.
> > > >> >> - BSP_output_char = output_char_serial;
> > > >> >> - link(UART0, CONSOLE_DEVICE_NAME);
> > > >> >> static void uart_probe(void)
> > > >> >> static bool initialized = false;
> > > >> >> const void *fdt;
> > > >> >> + const char *console;
> > > >> >> + int len;
> > > >> >> int node;
> > > >> >> if ( initialized ) {
> > > >> >> @@ -104,17 +185,29 @@ static void uart_probe(void)
> > > >> >> fdt = bsp_fdt_get();
> > > >> >> - node = fdt_node_offset_by_compatible(fdt, -1,
> > > "brcm,bcm2835-pl011");
> > > >> >> + node = fdt_node_offset_by_compatible(fdt, -1,
> > > >> >> init_ctx_arm_pl011(fdt, node);
> > > "brcm,bcm2835-aux-uart");
> > > >> >> + init_ctx_mini_uart(fdt, node);
> > > >> >> + node = fdt_path_offset(fdt, "/aliases");
> > > >> >> + console = fdt_getprop(fdt, node, "serial0", &len);
> > > >> >> + if ( strcmp(console, "/soc/serial at 7e215040" ) == 0) {
> > > >> >> + }else {
> > > >> >> initialized = true;
> > > >> >> static void output_char(char c)
> > > >> >> uart_probe();
> > > >> >> - output_char_serial(c);
> > > >> >> + (*BSP_output_char)(c);
> > > >> >> rtems_status_code console_initialize(
> > > >> >> @@ -127,12 +220,19 @@ rtems_status_code console_initialize(
> > > >> >> uart_probe();
> > > >> >> rtems_termios_device_install(
> > > >> >> - UART0,
> > > >> >> + PL011,
> > > >> >> &arm_pl011_fns,
> > > >> >> NULL,
> > > >> >> &pl011_context.base
> > > >> >> + rtems_termios_device_install(
> > > >> >> + MINIUART,
> > > >> >> + &ns16550_handler_polled,
> > > >> >> + NULL,
> > > >> >> + &mini_uart_context.base
> > > >> >> register_fb();
> > > >> >> console_select();
> > > >> >> diff --git a/bsps/arm/raspberrypi/include/bsp/usart.h
> > > b/bsps/arm/raspberrypi/include/bsp/usart.h
> > > >> >> index abbf53626c..6af1844b3c 100644
> > > >> >> --- a/bsps/arm/raspberrypi/include/bsp/usart.h
> > > >> >> +++ b/bsps/arm/raspberrypi/include/bsp/usart.h
> > > >> >> @@ -33,6 +33,7 @@ extern "C" {
> > > >> >> #endif /* __cplusplus */
> > > >> >> #define PL011_DEFAULT_BAUD 115000
> > > >> >> +#define MINI_UART_DEFAULT_BAUD 115200
> > > >> >> #define BCM2835_PL011_BASE (RPI_PERIPHERAL_BASE + 0x201000)
> > > >> >> #ifdef __cplusplus
> > > >> >> 2.17.1
> > > >> > _______________________________________________
> > > >> > devel mailing list
> > > >> > devel at rtems.org <mailto:devel at rtems.org>
> > > >> > http://lists.rtems.org/mailman/listinfo/devel
> > > devel mailing list
> > > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200216/8f8bc1af/attachment-0001.html>
