master build failed
Ярослав Лещинский
midniwalker at gmail.com
Sun Feb 16 19:44:33 UTC 2020
Hello,
I decided to update master to the latest. During the build got such error:
../../../../../rtems/c/src/../../cpukit/libcsupport/src/posix_devctl.c: In
function 'posix_devctl':
../../../../../rtems/c/src/../../cpukit/libcsupport/src/posix_devctl.c:81:15:
error: 'SOCKCLOSE' undeclared (first use in this function)
if (dcmd == SOCKCLOSE ) {
note: each undeclared identifier is reported only once for each function it
appears in
Was running as:
./bootstrap && cd ../ && rm -rf build && mkdir build && cd build &&
../rtems/configure --target=arm-rtems5 --prefix $HOME/workspace/rtems/build
&& make -j8 RTEMS_BSP=stm32f4 && make RTEMS_BSP=stm32f4 install
Did I miss some updates from sourcebuilder, for example or it's problem
with a build in general?
Kind regards,
*Yaroslav Leshchinsky*
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200216/cae61825/attachment-0001.html>
