master build failed
Ярослав Лещинский midniwalker at gmail.com
Sun Feb 16 19:57:59 UTC 2020
Ok, thanks. Gonna check rsb.
On Sun 16. Feb 2020 at 20:54, Joel Sherrill <joel at rtems.org> wrote:
> On Sun, Feb 16, 2020, 1:44 PM Ярослав Лещинский <midniwalker at gmail.com>
> wrote:
>> Hello,
>> I decided to update master to the latest. During the build got such error:
>> ../../../../../rtems/c/src/../../cpukit/libcsupport/src/posix_devctl.c:
>> In function 'posix_devctl':
>> ../../../../../rtems/c/src/../../cpukit/libcsupport/src/posix_devctl.c:81:15:
>> error: 'SOCKCLOSE' undeclared (first use in this function)
>>    if (dcmd == SOCKCLOSE ) {
>> note: each undeclared identifier is reported only once for each function it
>> appears in
>> Was running as:
>>  ./bootstrap && cd ../ && rm -rf build && mkdir build && cd build &&
>> ../rtems/configure --target=arm-rtems5 --prefix $HOME/workspace/rtems/build
>> && make -j8 RTEMS_BSP=stm32f4 && make RTEMS_BSP=stm32f4 install
>> Did I miss some updates from sourcebuilder, for example or it's problem
>> with a build in general?
> You missed an RSB update to get at least a newer newlib.
> SOCKCLOSE is required by the FACE Technical Standard, Edition 3.0 and
> later.
> Fwiw RTEMS with Deos passed verification and is conformant with Edition
> 3.0. RTEMS provides POSIX services and Deos provides ARINC 653.
> --joel
>> Kind regards,
>> *Yaroslav Leshchinsky*
>> devel mailing list
>> devel at rtems.org
Kind regards,
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200216/0c977e3c/attachment.html>
