[PATCH] libmisc/shell: Fix the handling of joel scripts in telnet
Mon Feb 17 06:51:25 UTC 2020
On 17/02/2020 07:05, chrisj at rtems.org wrote:
> From: Chris Johns<chrisj at rtems.org>
> - Fix the passing of std[in/out] to child threads
> - Fix deleting of managed memory in the key destructor
> - Only set the key in the main loop thread
> - Only allocate a shell env outside of the main loop
> - Work around #3970
> - Fix memory leak if the task start fails
> - Remove error level from shell env, it cannot be returned this way. Add
>    exit_code but the API is broken so it cannot be returned.
> Closes #3859
Any changes required in existing Telnet application code after this patch?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
