[4.11 PATCH] libcsupport/newlib: Call newlib's __sinit to force reent initialisation
Sebastian Huber
Tue Feb 18 08:33:37 UTC 2020
On 18/02/2020 01:25, chrisj at rtems.org wrote:
> From: Chris Johns <chrisj at rtems.org>
> - Newlib overtites any FILE pointers set in stdin, stdout or stderr.
> Closes #3870
> cpukit/libcsupport/src/newlibc_reent.c | 5 ++++-
> 1 file changed, 4 insertions(+), 1 deletion(-)
> diff --git a/cpukit/libcsupport/src/newlibc_reent.c b/cpukit/libcsupport/src/newlibc_reent.c
> index 430157cf0f..6dc0b1eeaa 100644
> --- a/cpukit/libcsupport/src/newlibc_reent.c
> +++ b/cpukit/libcsupport/src/newlibc_reent.c
> @@ -44,7 +44,10 @@ bool newlib_create_hook(
> #endif
> - _REENT_INIT_PTR((creating_task->libc_reent)); /* GCC extension: structure constants */
> + extern void __sinit (struct _reent *s);
> + struct _reent *reent = (struct _reent *) creating_task->libc_reent;
> + _REENT_INIT_PTR((reent)); /* GCC extension: structure constants */
> + __sinit( reent );
> return true;
It would be good to test if this has the side-effect that now every
thread delete closes the file descriptors 0, 1, and 2.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
