[PATCH v4 2/3] amd64: Add to build
Chris Johns
chrisj at rtems.org
Tue Feb 18 23:16:20 UTC 2020
Looks good.
Thanks
On 18/2/20 9:21 pm, Jan Sommer wrote:
> libbsd.py | 25 +++++++++++++++++++++++++
> waf_libbsd.py | 13 +++++++++++--
> 2 files changed, 36 insertions(+), 2 deletions(-)
> diff --git a/libbsd.py b/libbsd.py
> index 3823c03f..db4b4c63 100644
> --- a/libbsd.py
> +++ b/libbsd.py
> @@ -90,6 +90,17 @@ _defaults = {
> 'cpu-include-paths': ['rtemsbsd/@CPU@/include',
> 'freebsd/sys/@CPU@/include'],
> + # Map paths based on RTEMS naming to FreeBSD naming.
> + 'path-mappings': [ # (source, targets)
> + # i386
> + ('freebsd/sys/i386/include', ['freebsd/sys/x86/include', 'freebsd/sys/i386/include']),
> + # amd64
> + ('freebsd/sys/x86_64/include', ['freebsd/sys/x86/include', 'freebsd/sys/amd64/include']),
> + ('rtemsbsd/x86_64/include', 'rtemsbsd/amd64/include')
> # The path where headers will be copied during build.
> 'build-include-path': ['build-include'],
> @@ -1548,6 +1559,7 @@ class dev_nic(builder.Module):
> 'sys/sys/buf.h',
> 'sys/sys/mqueue.h',
> 'sys/sys/user.h',
> + 'sys/sys/efi.h',
> self.addCPUDependentFreeBSDHeaderFiles(
> @@ -1559,6 +1571,11 @@ class dev_nic(builder.Module):
> 'sys/x86/include/intr_machdep.h',
> 'sys/x86/include/metadata.h',
> 'sys/i386/include/cpufunc.h',
> + 'sys/amd64/include/specialreg.h',
> + 'sys/amd64/include/md_var.h',
> + 'sys/amd64/include/efi.h',
> + 'sys/amd64/include/_bus.h',
> + 'sys/amd64/include/cpufunc.h',
> 'sys/mips/include/cpufunc.h',
> 'sys/mips/include/cpuregs.h',
> 'sys/powerpc/include/cpufunc.h',
> @@ -4993,6 +5010,7 @@ class in_cksum(builder.Module):
> 'sys/i386/include/in_cksum.h',
> + 'sys/amd64/include/in_cksum.h',
> 'sys/mips/include/in_cksum.h',
> 'sys/powerpc/include/in_cksum.h',
> 'sys/sparc64/include/in_cksum.h',
> @@ -5013,6 +5031,13 @@ class in_cksum(builder.Module):
> mm.generator['source']()
> + self.addCPUDependentFreeBSDSourceFiles(
> + [ 'x86_64' ],
> + 'sys/amd64/amd64/in_cksum.c',
> + mm.generator['source']()
> [ 'powerpc' ],
> diff --git a/waf_libbsd.py b/waf_libbsd.py
> index 84f22b76..9038119f 100644
> --- a/waf_libbsd.py
> +++ b/waf_libbsd.py
> @@ -196,8 +196,6 @@ class Builder(builder.ModuleManager):
> buildinclude = 'build-include'
> if 'cpu-include-paths' in config:
> cpu = bld.get_env()['RTEMS_ARCH']
> - if cpu == "i386":
> - includes += ['freebsd/sys/x86/include']
> for i in config['cpu-include-paths']:
> includes += [i.replace('@CPU@', cpu)]
> if 'include-paths' in config:
> @@ -208,6 +206,17 @@ class Builder(builder.ModuleManager):
> buildinclude = buildinclude[0]
> includes += [buildinclude]
> + # Path mappings
> + if 'path-mappings' in config:
> + for source, target in config['path-mappings']:
> + if source in includes:
> + target = [target] if isinstance(target, str) else target
> + i = includes.index(source)
> + includes.remove(source)
> + includes[i:i] = target
> # Collect the libbsd uses
