[PATCH v5] Add new COPYING file
Wed Feb 19 06:04:28 UTC 2020
On 06/12/2019 07:16, Sebastian Huber wrote:
> Ping.
> On 19/12/2018 13:37, Sebastian Huber wrote:
>> Update #3053.
>> v2:
>> Add Hesham Almatary:
>> https://devel.rtems.org/ticket/3053#comment:6
>> v3:
>> Add Jiri Gaisler:
>> https://devel.rtems.org/ticket/3053#comment:7
>> I am not sure about the first contribution year.
>> v4:
>> Add GCI contributors:
>> Abhimanyu Raghuvanshi
>> Himanshu Sekhar Nayak
>> Jacob Shin
>> Marçal Comajoan Cara
>> Pritish Jain
>> Shashvat Jain
>> v5:
>> Add GCI contributor:
>> Zenon Hans Taneka
>> I need names for:
>> kaidoho kho237115 at gmail.com
>> kuaLeYi kualeyidxa at gmail.com
>>   COPYING | 47 +++++++++++++++++++++++++++++++++++++++++++++++
>>   1 file changed, 47 insertions(+)
>>   create mode 100644 COPYING
>> diff --git a/COPYING b/COPYING
>> new file mode 100644
>> index 0000000000..2e1339c90e
>> --- /dev/null
>> +++ b/COPYING
>> @@ -0,0 +1,47 @@
>> +RTEMS is a collection of software from several sources.
>> +Each file may have its own copyright/license that is embedded in the
>> source
>> +file.  Unless otherwise noted in the body of the source file(s), the
>> following
>> +copyright notices will apply to the contents of RTEMS.  Copyright
>> lines should
>> +be sorted by the first year followed by the copyright holder.
>> +(1) BSD-2-Clause
>> +Copyright (C) 2018 Abhimanyu Raghuvanshi
>> +Copyright (C) 2018 Himanshu Sekhar Nayak
>> +Copyright (C) 2018 Jacob Shin
>> +Copyright (C) 2018 Marçal Comajoan Cara
>> +Copyright (C) 2018 Pritish Jain
>> +Copyright (C) 2018 Shashvat Jain
>> +Copyright (C) 2015, 2016 Alexander Krutwig
>> +Copyright (C) 2013, 2018 Hesham Almatary
>> +Copyright (C) 2012, 2014 Ralf Kirchner
>> +Copyright (C) 2012, 2018 Christian Mauderer
>> +Copyright (C) 2010, 2018 Gedare Bloom
>> +Copyright (C) 2008, 2018 Sebastian Huber
>> +Copyright (C) 2005, 2018 Thomas Dörfler
>> +Copyright (C) 2005, 2018 embedded brains GmbH
>> +Copyright (C) 1996, 2018 Chris Johns
>> +Copyright (C) 1996, 2016 Jiri Gaisler
>> +Copyright (C) 1989, 2018 On-Line Applications Research Corporation (OAR)
>> +Redistribution and use in source and binary forms, with or without
>> +modification, are permitted provided that the following conditions
>> +are met:
>> +1. Redistributions of source code must retain the above copyright
>> +   notice, this list of conditions and the following disclaimer.
>> +2. Redistributions in binary form must reproduce the above copyright
>> +   notice, this list of conditions and the following disclaimer in the
>> +   documentation and/or other materials provided with the distribution.
>> +THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
>> "AS IS"
>> +AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
>> THE
>> +IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>> PURPOSE
>> +ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
>> +LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> +CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>> +SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
>> +INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
>> +CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
>> +ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
>> OF THE
>> +POSSIBILITY OF SUCH DAMAGE.
What about this COPYING file?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
