[PATCH v2] eng: Rework file template section
Sebastian Huber
Wed Feb 19 08:23:36 UTC 2020
Update #3053.
v2:
Clarify COPYING update and placeholders.
eng/coding-file-hdr.rst | 169 +++++++++++++++++++++++++++++++++++++++---------
1 file changed, 139 insertions(+), 30 deletions(-)
diff --git a/eng/coding-file-hdr.rst b/eng/coding-file-hdr.rst
index c724c5d..e6ebaf1 100644
--- a/eng/coding-file-hdr.rst
+++ b/eng/coding-file-hdr.rst
@@ -1,45 +1,154 @@
.. SPDX-License-Identifier: CC-BY-SA-4.0
-.. Copyright (C) 2018.
-.. COMMENT: RTEMS Foundation, The RTEMS Documentation Project
+.. Copyright (C) 2018, 2020 embedded brains GmbH
+.. Copyright (C) 2018, 2020 Sebastian Huber
-.. COMMENT:TBD - Convert the following to Rest and insert into this file
-.. COMMENT:TBD - https://devel.rtems.org/wiki/Developer/Coding/Boilerplate_File_Header
+File Templates
+Every file shall have a copyright and license comment block. It should have a
+Doxygen file comment block.
-Boilerplate File Header
+The preferred licence for new source code is
+`BSD-2-Clause <https://spdx.org/licenses/BSD-2-Clause.html>`_:
-Every file should include two comment header blocks, one for the Doxygen
-output and a copyright notice. This is a typical example:
+.. code-block:: none
+ Copyright (C) <FIRST YEAR>, <LAST YEAR> <COPYRIGHT HOLDER>
+ Redistribution and use in source and binary forms, with or without
+ modification, are permitted provided that the following conditions
+ are met:
+ 1. Redistributions of source code must retain the above copyright
+ notice, this list of conditions and the following disclaimer.
+ 2. Redistributions in binary form must reproduce the above copyright
+ notice, this list of conditions and the following disclaimer in the
+ documentation and/or other materials provided with the distribution.
+ THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+ AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+ ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+ LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+ CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+ SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+ INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+ CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+ ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+ POSSIBILITY OF SUCH DAMAGE.
+.. _FileHeaderCopyright:
+Copyright and License Comment Block
+You are the copyright holder. Copy the comment below the top of the file in
+which you want to use this license for your contribution. Replace the
+<FIRST YEAR> placeholder with the year of your first substantial contribution to
+this file. Update the <LAST YEAR> with the year of your last substantial
+contribution to this file. If the first and last years are the same, then
+remove the <LAST YEAR> placeholder with the comma. Replace the
+<COPYRIGHT HOLDER> placeholder with your name.
+In case you are a real person, then use the following format for
+<COPYRIGHT HOLDER>: <FIRST NAME> <MIDDLE NAMES> <LAST NAME>. The <FIRST NAME>
+is your first name (also known as given name), the <MIDDLE NAMES> are your
+optional middle names, the <LAST NAME> is your last name (also known as family
+name).
+If more than one copyright holder exists for a file, then sort the copyright
+lines by the first year (earlier years are below later years) followed by the
+copyright holder in alphabetical order (A is above B in the file).
+Use the following template for a copyright and license comment block. Please
+note that there is no verbatim copy of the BSD-2-Clause license included. The
+license is specified by the SPDX Licence Identifier.
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) <FIRST YEAR>, <LAST YEAR> <COPYRIGHT HOLDER>
+Check the top-level :file:`COPYING` file of the repository. If you are a new
+copyright holder, then add yourself to the top of the list. If your last year
+of a substantial contribution changed, then please update your copyright line.
+Header File Template
+Use the following guidelines and template for header files (here
+:file:`<foo/bar/baz.h>`):
+* Place the copyright and license comment block to the top of the file.
+* For the <FIRST YEAR>, <LAST YEAR>, and <COPYRIGHT HOLDER> placeholders see
+ :ref:`FileHeaderCopyright`.
+* Use exactly one blank line between the copyright and licence comment block and
+ the Doxygen comment block.
+* Separate the Doxygen comment block from the copyright and license, so that
+ the copyright and license information is not included in the Doxygen output.
+* For C++ header files discard the extern "C".
.. code-block:: c
- * @file
- * @ingroup TheGroupForThisFile
- * @brief Short "Table of Contents" Description of File Contents
- * A short description of the purpose of this file.
+ * @file
+ * @ingroup TheGroupForThisFile
+ * @brief Short "Table of Contents" Description of File Contents
+ * A short description of the purpose of this file.
+ #ifndef _FOO_BAR_BAZ_H
+ #define _FOO_BAR_BAZ_H
- * Copyright (c) 20XX Your Name Or Your Company.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * https://www.rtems.org/license/LICENSE.
+ #include <foo/bar/xyz.h>
+ #ifdef __cplusplus
+ extern "C" {
+ #endif
+ /* Declarations, defines, macros, inline functions, etc. */
+ #endif
+ #endif /* _FOO_BAR_BAZ_H */
+Source File Template
+Use the following template for source files (here implementation of
+:file:`<foo/bar/baz.h>`). For the <FIRST YEAR>, <LAST YEAR>, and
+<COPYRIGHT HOLDER> placeholders see :ref:`FileHeaderCopyright`.
+.. code-block:: c
-* Use exactly one blank line between the Doxygen header and copyright notice.
- Leave the first line of the copyright notice blank.
-* Separate the Doxygen header and copyright notice so the copyright notice is
- not included in the Doxygen output.
+ #if HAVE_CONFIG_H
+ #include "config.h"
+ #endif
-* The copyright owner and specific license terms may vary.
+ #include <foo/bar/baz.h>
-.. COMMENT: TBD - TBD Add link to license requirements section and show variant licenses.
+ /* Definitions, etc. */
2.16.4
