[PATCH v2 06/44] config: Add _Watchdog_Microseconds_per_tick
Sebastian Huber
Fri Feb 21 10:52:18 UTC 2020
Move the microseconds per tick configuration constant out of the
configuration table.
Add WATCHDOG_MICROSECONDS_PER_TICK_DEFAULT and use it to provide a
default definition of the watchdog ticks constants.
Update #3875.
cpukit/include/rtems/confdefs.h | 17 ++++++++++-------
cpukit/include/rtems/config.h | 10 ++--------
cpukit/include/rtems/score/watchdogticks.h | 8 ++++++++
3 files changed, 20 insertions(+), 15 deletions(-)
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index 6a8b9ecb7e..1254e3d209 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -1955,7 +1955,16 @@ extern "C" {
#error "The CONFIGURE_MICROSECONDS_PER_TICK must be positive"
#endif
-#define _CONFIGURE_TICKS_PER_SECOND (1000000 / CONFIGURE_MICROSECONDS_PER_TICK)
+#ifdef CONFIGURE_INIT
+ const uint32_t _Watchdog_Microseconds_per_tick =
+ CONFIGURE_MICROSECONDS_PER_TICK;
+ const uint32_t _Watchdog_Nanoseconds_per_tick =
+ (uint32_t) 1000 * CONFIGURE_MICROSECONDS_PER_TICK;
+ const uint32_t _Watchdog_Ticks_per_second =
+ 1000000 / CONFIGURE_MICROSECONDS_PER_TICK;
+#endif
/** The configures the number of clock ticks per timeslice. */
#ifndef CONFIGURE_TICKS_PER_TIMESLICE
@@ -2452,11 +2461,6 @@ struct _reent *__getreent(void)
sizeof( Thread_queue_Configured_heads );
#endif
- const uint32_t _Watchdog_Nanoseconds_per_tick =
- (uint32_t) 1000 * CONFIGURE_MICROSECONDS_PER_TICK;
- const uint32_t _Watchdog_Ticks_per_second = _CONFIGURE_TICKS_PER_SECOND;
const size_t _Thread_Initial_thread_count =
rtems_resource_maximum_per_allocation( _CONFIGURE_TASKS ) +
rtems_resource_maximum_per_allocation( CONFIGURE_MAXIMUM_POSIX_THREADS );
@@ -2622,7 +2626,6 @@ struct _reent *__getreent(void)
const rtems_configuration_table Configuration = {
CONFIGURE_EXECUTIVE_RAM_SIZE, /* required RTEMS workspace */
- CONFIGURE_MICROSECONDS_PER_TICK, /* microseconds per clock tick */
CONFIGURE_TICKS_PER_TIMESLICE, /* ticks per timeslice quantum */
CONFIGURE_IDLE_TASK_BODY, /* user's IDLE task */
CONFIGURE_IDLE_TASK_STACK_SIZE, /* IDLE task stack size */
diff --git a/cpukit/include/rtems/config.h b/cpukit/include/rtems/config.h
index d9f91db741..84917366f3 100644
--- a/cpukit/include/rtems/config.h
+++ b/cpukit/include/rtems/config.h
@@ -86,12 +86,6 @@ typedef struct {
uintptr_t work_space_size;
- * This field specifies the number of microseconds which elapse
- * between clock ticks. This is the basis for RTEMS timing.
- uint32_t microseconds_per_tick;
* This field specifies the number of ticks in each task's timeslice.
@@ -162,9 +156,9 @@ uintptr_t rtems_configuration_get_stack_space_size( void );
uint32_t rtems_configuration_get_maximum_extensions( void );
#define rtems_configuration_get_microseconds_per_tick() \
- (Configuration.microseconds_per_tick)
+ (_Watchdog_Microseconds_per_tick)
#define rtems_configuration_get_milliseconds_per_tick() \
- (Configuration.microseconds_per_tick / 1000)
+ (_Watchdog_Microseconds_per_tick / 1000)
#define rtems_configuration_get_nanoseconds_per_tick() \
(_Watchdog_Nanoseconds_per_tick)
diff --git a/cpukit/include/rtems/score/watchdogticks.h b/cpukit/include/rtems/score/watchdogticks.h
index e7cf3f3ea3..226de39c24 100644
--- a/cpukit/include/rtems/score/watchdogticks.h
+++ b/cpukit/include/rtems/score/watchdogticks.h
@@ -49,6 +49,14 @@ typedef uint32_t Watchdog_Interval;
extern volatile Watchdog_Interval _Watchdog_Ticks_since_boot;
+ * @brief The watchdog microseconds per tick.
+ * This constant is defined by the application configuration via
+ * <rtems/confdefs.h>.
+extern const uint32_t _Watchdog_Microseconds_per_tick;
* @brief The watchdog nanoseconds per tick.
2.16.4
