[PATCH v2 17/44] config: CONFIGURE_INIT_TASK_INITIAL_MODES
Sebastian Huber
Fri Feb 21 10:52:29 UTC 2020
Determine the default for CONFIGURE_INIT_TASK_INITIAL_MODES depeding on
whether RTEMS_SMP is defined or not.
In the tests, use CONFIGURE_INIT_TASK_INITIAL_MODES to explicitly
request RTEMS_NO_PREEMPT mode if necessary.
Update #3876.
cpukit/include/rtems/confdefs.h | 2 +-
testsuites/sptests/sp66/init.c | 1 +
testsuites/sptests/spsimplesched02/init.c | 2 ++
3 files changed, 4 insertions(+), 1 deletion(-)
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index 0191392cfc..0fc2d0e5a6 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -1343,7 +1343,7 @@ const Thread_Idle_body _Thread_Idle_body = CONFIGURE_IDLE_TASK_BODY;
* used to specify the initial execution mode of the single Classic API task.
#ifndef CONFIGURE_INIT_TASK_INITIAL_MODES
- #ifdef _CONFIGURE_SMP_APPLICATION
+ #ifdef RTEMS_SMP
#define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_DEFAULT_MODES
#else
#define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_NO_PREEMPT
diff --git a/testsuites/sptests/sp66/init.c b/testsuites/sptests/sp66/init.c
index f2bf46d049..3dd8e75a32 100644
--- a/testsuites/sptests/sp66/init.c
+++ b/testsuites/sptests/sp66/init.c
@@ -1,2 +1,3 @@
#define INHERIT_CEILING
+#define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_NO_PREEMPT
#include "../sp65/sp65impl.h"
diff --git a/testsuites/sptests/spsimplesched02/init.c b/testsuites/sptests/spsimplesched02/init.c
index b7b1a21919..4a08a6c8ac 100644
--- a/testsuites/sptests/spsimplesched02/init.c
+++ b/testsuites/sptests/spsimplesched02/init.c
@@ -154,6 +154,8 @@ rtems_task Init(
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define CONFIGURE_EXTRA_TASK_STACKS (3 * RTEMS_MINIMUM_STACK_SIZE)
#define CONFIGURE_INIT_TASK_PRIORITY 4
#define CONFIGURE_DISABLE_SMP_CONFIGURATION
2.16.4
