[PATCH v2 10/44] config: Add _Workspace_Size
Sebastian Huber
Fri Feb 21 10:52:22 UTC 2020
Move the workspace size configuration constant out of the configuration
table.
Update #3875.
cpukit/headers.am | 1 +
cpukit/include/rtems/confdefs.h | 3 +-
cpukit/include/rtems/config.h | 8 +---
cpukit/include/rtems/score/wkspacedata.h | 66 ++++++++++++++++++++++++++++++++
4 files changed, 71 insertions(+), 7 deletions(-)
create mode 100644 cpukit/include/rtems/score/wkspacedata.h
diff --git a/cpukit/headers.am b/cpukit/headers.am
index 351e942cea..6e1ab4ccd0 100644
--- a/cpukit/headers.am
+++ b/cpukit/headers.am
@@ -408,6 +408,7 @@ include_rtems_score_HEADERS += include/rtems/score/watchdog.h
include_rtems_score_HEADERS += include/rtems/score/watchdogimpl.h
include_rtems_score_HEADERS += include/rtems/score/watchdogticks.h
include_rtems_score_HEADERS += include/rtems/score/wkspace.h
+include_rtems_score_HEADERS += include/rtems/score/wkspacedata.h
include_rtems_trace_HEADERS += include/rtems/trace/rtems-trace-buffer-vars.h
include_sys_HEADERS += include/sys/_ffcounter.h
include_sys_HEADERS += include/sys/cdefs_elf.h
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index ae1dca11e0..6057bf4ac5 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -2637,7 +2637,6 @@ struct _reent *__getreent(void)
* This is the primary Configuration Table for this application.
const rtems_configuration_table Configuration = {
- CONFIGURE_EXECUTIVE_RAM_SIZE, /* required RTEMS workspace */
#ifdef CONFIGURE_UNIFIED_WORK_AREAS /* true for unified work areas */
true,
#else
@@ -2655,6 +2654,8 @@ struct _reent *__getreent(void)
#endif
+ const uintptr_t _Workspace_Size = CONFIGURE_EXECUTIVE_RAM_SIZE;
#ifdef CONFIGURE_DIRTY_MEMORY
RTEMS_SYSINIT_ITEM(
_Memory_Dirty_free_areas,
diff --git a/cpukit/include/rtems/config.h b/cpukit/include/rtems/config.h
index 017b4ed476..0b5527c76d 100644
--- a/cpukit/include/rtems/config.h
+++ b/cpukit/include/rtems/config.h
@@ -34,6 +34,7 @@
#include <rtems/score/userextdata.h>
#include <rtems/score/threadidledata.h>
#include <rtems/score/watchdogticks.h>
+#include <rtems/score/wkspacedata.h>
#include <rtems/rtems/config.h>
#include <rtems/extension.h>
#if defined(RTEMS_MULTIPROCESSING)
@@ -82,11 +83,6 @@ typedef Stack_Allocator_free rtems_stack_free_hook;
* + required number of each object type for each API configured
typedef struct {
- * This field specifies the size in bytes of the RTEMS Workspace.
- uintptr_t work_space_size;
* @brief Specifies if a unified work area is used or not.
@@ -132,7 +128,7 @@ extern const rtems_configuration_table Configuration;
uintptr_t rtems_configuration_get_stack_space_size( void );
#define rtems_configuration_get_work_space_size() \
- (Configuration.work_space_size + \
+ (_Workspace_Size + \
(rtems_configuration_get_stack_allocator_avoids_work_space() ? \
0 : rtems_configuration_get_stack_space_size()))
diff --git a/cpukit/include/rtems/score/wkspacedata.h b/cpukit/include/rtems/score/wkspacedata.h
new file mode 100644
index 0000000000..b913c07f8e
--- /dev/null
+++ b/cpukit/include/rtems/score/wkspacedata.h
@@ -0,0 +1,66 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * @file
+ * @ingroup RTEMSScoreWorkspace
+ * @brief Constants defined by the application configuration for the idle
+ * threads.
+#ifndef _RTEMS_SCORE_WKSPACEDATA_H
+#define _RTEMS_SCORE_WKSPACEDATA_H
+#include <rtems/score/basedefs.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @addtogroup RTEMSScoreWorkspace
+ * @brief The workspace size in bytes.
+ * This constant is defined by the application configuration via
+ * <rtems/confdefs.h>.
+extern const uintptr_t _Workspace_Size;
+#ifdef __cplusplus
+#endif
+#endif /* _RTEMS_SCORE_WKSPACEDATA_H */
2.16.4
