[PATCH v2 28/44] config: Add <rtems/confdefs/scheduler.h>
Sebastian Huber
Fri Feb 21 10:52:40 UTC 2020
Remove all comments and copyrightable content from the moved content.
Use BSD-2-Clause license for new file.
Update #3053.
Update #3875.
cpukit/headers.am | 1 +
cpukit/include/rtems/confdefs.h | 453 +-----------------------------
cpukit/include/rtems/confdefs/scheduler.h | 370 ++++++++++++++++++++++++
3 files changed, 372 insertions(+), 452 deletions(-)
create mode 100644 cpukit/include/rtems/confdefs/scheduler.h
diff --git a/cpukit/headers.am b/cpukit/headers.am
index f64e9867ff..2cb59165bf 100644
--- a/cpukit/headers.am
+++ b/cpukit/headers.am
@@ -188,6 +188,7 @@ include_rtems_confdefs_HEADERS += include/rtems/confdefs/libio.h
include_rtems_confdefs_HEADERS += include/rtems/confdefs/libpci.h
include_rtems_confdefs_HEADERS += include/rtems/confdefs/obsolete.h
include_rtems_confdefs_HEADERS += include/rtems/confdefs/percpu.h
+include_rtems_confdefs_HEADERS += include/rtems/confdefs/scheduler.h
include_rtems_debugger_HEADERS += include/rtems/debugger/rtems-debugger-bsp.h
include_rtems_debugger_HEADERS += include/rtems/debugger/rtems-debugger-remote.h
include_rtems_debugger_HEADERS += include/rtems/debugger/rtems-debugger-server.h
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index a51693834b..ba37f0abe7 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -53,6 +53,7 @@
#include <rtems/confdefs/libio.h>
#include <rtems/confdefs/libpci.h>
#include <rtems/confdefs/percpu.h>
+#include <rtems/confdefs/scheduler.h>
#include <limits.h>
@@ -101,441 +102,6 @@ extern "C" {
#undef RTEMS_NEWLIB
#endif
- * @brief Maximum priority configuration.
- * This configures the maximum priority value that
- * a task may have.
- * The following applies to the data space requirements
- * of the Priority Scheduler.
- * By reducing the number of priorities in a system,
- * the amount of RAM required by RTEMS can be significantly
- * reduced. RTEMS allocates a Chain_Control structure per
- * priority and this structure contains 3 pointers. So
- * the default is (256 * 12) = 3K on 32-bit architectures.
- * This must be one less than a power of 2 between
- * 4 and 256. Valid values along with the application
- * priority levels and memory saved when pointers are
- * 32-bits in size are:
- * + 3, 2 application priorities, 3024 bytes saved
- * + 7, 5 application priorities, 2976 bytes saved
- * + 15, 13 application priorities, 2880 bytes saved
- * + 31, 29 application priorities, 2688 bytes saved
- * + 63, 61 application priorities, 2304 bytes saved
- * + 127, 125 application priorities, 1536 bytes saved
- * + 255, 253 application priorities, 0 bytes saved
- * It is specified in terms of Classic API priority values.
-#ifndef CONFIGURE_MAXIMUM_PRIORITY
- #define CONFIGURE_MAXIMUM_PRIORITY PRIORITY_DEFAULT_MAXIMUM
-#endif
- * @defgroup ConfigScheduler Scheduler configuration
- * @ingroup Configuration
- * The scheduler configuration allows an application to select the
- * scheduling policy to use. The supported configurations are:
- * - CONFIGURE_SCHEDULER_PRIORITY - Deterministic Priority Scheduler
- * - CONFIGURE_SCHEDULER_PRIORITY_SMP - Deterministic Priority SMP Scheduler
- * - CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP - Deterministic
- * Priority SMP Affinity Scheduler
- * - CONFIGURE_SCHEDULER_STRONG_APA - Strong APA Scheduler
- * - CONFIGURE_SCHEDULER_SIMPLE - Light-weight Priority Scheduler
- * - CONFIGURE_SCHEDULER_SIMPLE_SMP - Simple SMP Priority Scheduler
- * - CONFIGURE_SCHEDULER_EDF - EDF Scheduler
- * - CONFIGURE_SCHEDULER_EDF_SMP - EDF SMP Scheduler
- * - CONFIGURE_SCHEDULER_CBS - CBS Scheduler
- * - CONFIGURE_SCHEDULER_USER - user provided scheduler
- * If no configuration is specified by the application in a uniprocessor
- * configuration, then CONFIGURE_SCHEDULER_PRIORITY is the default.
- * If no configuration is specified by the application in SMP
- * configuration, then CONFIGURE_SCHEDULER_PRIORITY_SMP is the default.
- * An application can define its own scheduling policy by defining
- * CONFIGURE_SCHEDULER_USER and the following:
- * - CONFIGURE_SCHEDULER_TABLE_ENTRIES
- * - CONFIGURE_SCHEDULER_USER_PER_THREAD
-#if !defined(CONFIGURE_SCHEDULER_USER) && \
- !defined(CONFIGURE_SCHEDULER_PRIORITY) && \
- !defined(CONFIGURE_SCHEDULER_PRIORITY_SMP) && \
- !defined(CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP) && \
- !defined(CONFIGURE_SCHEDULER_STRONG_APA) && \
- !defined(CONFIGURE_SCHEDULER_SIMPLE) && \
- !defined(CONFIGURE_SCHEDULER_SIMPLE_SMP) && \
- !defined(CONFIGURE_SCHEDULER_EDF) && \
- !defined(CONFIGURE_SCHEDULER_EDF_SMP) && \
- !defined(CONFIGURE_SCHEDULER_CBS)
- #if defined(RTEMS_SMP) && _CONFIGURE_MAXIMUM_PROCESSORS > 1
- * If no scheduler is specified in an SMP configuration, the
- * EDF scheduler is default.
- #define CONFIGURE_SCHEDULER_EDF_SMP
- #else
- * If no scheduler is specified in a uniprocessor configuration, the
- * priority scheduler is default.
- #define CONFIGURE_SCHEDULER_PRIORITY
- #endif
-#endif
-#include <rtems/scheduler.h>
- * If the Priority Scheduler is selected, then configure for it.
-#if defined(CONFIGURE_SCHEDULER_PRIORITY)
- #if !defined(CONFIGURE_SCHEDULER_NAME)
- /** Configure the name of the scheduler instance */
- #define CONFIGURE_SCHEDULER_NAME rtems_build_name('U', 'P', 'D', ' ')
- #endif
- #if !defined(CONFIGURE_SCHEDULER_TABLE_ENTRIES)
- /** Configure the context needed by the scheduler instance */
- #define CONFIGURE_SCHEDULER \
- RTEMS_SCHEDULER_PRIORITY( \
- dflt, \
- CONFIGURE_MAXIMUM_PRIORITY + 1 \
- /** Configure the controls for this scheduler instance */
- #define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
- RTEMS_SCHEDULER_TABLE_PRIORITY(dflt, CONFIGURE_SCHEDULER_NAME)
- #endif
-#endif
- * If the Deterministic Priority SMP Scheduler is selected, then configure for
- * it.
-#if defined(CONFIGURE_SCHEDULER_PRIORITY_SMP)
- #define CONFIGURE_SCHEDULER_NAME rtems_build_name('M', 'P', 'D', ' ')
- #endif
- RTEMS_SCHEDULER_PRIORITY_SMP( \
- dflt, \
- RTEMS_SCHEDULER_TABLE_PRIORITY_SMP(dflt, CONFIGURE_SCHEDULER_NAME)
- #endif
-#endif
- * If the Deterministic Priority Affinity SMP Scheduler is selected, then configure for
- * it.
-#if defined(CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP)
- #define CONFIGURE_SCHEDULER_NAME rtems_build_name('M', 'P', 'A', ' ')
- #endif
- RTEMS_SCHEDULER_PRIORITY_AFFINITY_SMP( \
- dflt, \
- RTEMS_SCHEDULER_TABLE_PRIORITY_AFFINITY_SMP( \
- dflt, \
- CONFIGURE_SCHEDULER_NAME \
- #endif
-#endif
- * If the Strong APA Scheduler is selected, then configure for
- * it.
-#if defined(CONFIGURE_SCHEDULER_STRONG_APA)
- #define CONFIGURE_SCHEDULER_NAME rtems_build_name('M', 'A', 'P', 'A')
- #endif
- RTEMS_SCHEDULER_STRONG_APA( \
- dflt, \
- RTEMS_SCHEDULER_TABLE_STRONG_APA(dflt, CONFIGURE_SCHEDULER_NAME)
- #endif
-#endif
- * If the Simple Priority Scheduler is selected, then configure for it.
-#if defined(CONFIGURE_SCHEDULER_SIMPLE)
- #define CONFIGURE_SCHEDULER_NAME rtems_build_name('U', 'P', 'S', ' ')
- #endif
- #define CONFIGURE_SCHEDULER RTEMS_SCHEDULER_SIMPLE(dflt)
- RTEMS_SCHEDULER_TABLE_SIMPLE(dflt, CONFIGURE_SCHEDULER_NAME)
- #endif
-#endif
- * If the Simple SMP Priority Scheduler is selected, then configure for it.
-#if defined(CONFIGURE_SCHEDULER_SIMPLE_SMP)
- #define CONFIGURE_SCHEDULER_NAME rtems_build_name('M', 'P', 'S', ' ')
- #endif
- RTEMS_SCHEDULER_SIMPLE_SMP(dflt)
- RTEMS_SCHEDULER_TABLE_SIMPLE_SMP(dflt, CONFIGURE_SCHEDULER_NAME)
- #endif
-#endif
- * If the EDF Scheduler is selected, then configure for it.
-#if defined(CONFIGURE_SCHEDULER_EDF)
- #define CONFIGURE_SCHEDULER_NAME rtems_build_name('U', 'E', 'D', 'F')
- #endif
- #define CONFIGURE_SCHEDULER RTEMS_SCHEDULER_EDF(dflt)
- RTEMS_SCHEDULER_TABLE_EDF(dflt, CONFIGURE_SCHEDULER_NAME)
- #endif
-#endif
- * If the EDF SMP Scheduler is selected, then configure for it.
-#if defined(CONFIGURE_SCHEDULER_EDF_SMP)
- #define CONFIGURE_SCHEDULER_NAME rtems_build_name('M', 'E', 'D', 'F')
- #endif
- #define CONFIGURE_SCHEDULER RTEMS_SCHEDULER_EDF_SMP(dflt)
- RTEMS_SCHEDULER_TABLE_EDF_SMP(dflt, CONFIGURE_SCHEDULER_NAME)
- #endif
-#endif
- * If the CBS Scheduler is selected, then configure for it.
-#if defined(CONFIGURE_SCHEDULER_CBS)
- #define CONFIGURE_SCHEDULER_NAME rtems_build_name('U', 'C', 'B', 'S')
- #endif
- #define CONFIGURE_SCHEDULER RTEMS_SCHEDULER_CBS(dflt)
- RTEMS_SCHEDULER_TABLE_CBS(dflt, CONFIGURE_SCHEDULER_NAME)
- #endif
- #ifndef CONFIGURE_CBS_MAXIMUM_SERVERS
- #define CONFIGURE_CBS_MAXIMUM_SERVERS CONFIGURE_MAXIMUM_TASKS
- #endif
- #ifdef CONFIGURE_INIT
- const uint32_t _Scheduler_CBS_Maximum_servers =
- CONFIGURE_CBS_MAXIMUM_SERVERS;
- Scheduler_CBS_Server
- _Scheduler_CBS_Server_list[ CONFIGURE_CBS_MAXIMUM_SERVERS ];
- #endif
-#endif
- * Set up the scheduler entry points table. The scheduling code uses
- * this code to know which scheduler is configured by the user.
-#ifdef CONFIGURE_INIT
- #if defined(CONFIGURE_SCHEDULER)
- CONFIGURE_SCHEDULER;
- #endif
- const Scheduler_Control _Scheduler_Table[] = {
- #define _CONFIGURE_SCHEDULER_COUNT RTEMS_ARRAY_SIZE( _Scheduler_Table )
- const size_t _Scheduler_Count = _CONFIGURE_SCHEDULER_COUNT;
- const Scheduler_Assignment _Scheduler_Initial_assignments[] = {
- #if defined(CONFIGURE_SCHEDULER_ASSIGNMENTS)
- CONFIGURE_SCHEDULER_ASSIGNMENTS
- #else
- #define _CONFIGURE_SCHEDULER_ASSIGN \
- RTEMS_SCHEDULER_ASSIGN( \
- 0, \
- RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL \
- _CONFIGURE_SCHEDULER_ASSIGN
- #if _CONFIGURE_MAXIMUM_PROCESSORS >= 2
- , _CONFIGURE_SCHEDULER_ASSIGN
- #endif
- #if _CONFIGURE_MAXIMUM_PROCESSORS >= 3
- #endif
- #if _CONFIGURE_MAXIMUM_PROCESSORS >= 4
- #endif
- #if _CONFIGURE_MAXIMUM_PROCESSORS >= 5
- #endif
- #if _CONFIGURE_MAXIMUM_PROCESSORS >= 6
- #endif
- #if _CONFIGURE_MAXIMUM_PROCESSORS >= 7
- #endif
- #if _CONFIGURE_MAXIMUM_PROCESSORS >= 8
- #endif
- #if _CONFIGURE_MAXIMUM_PROCESSORS >= 9
- #endif
- #if _CONFIGURE_MAXIMUM_PROCESSORS >= 10
- #endif
- #if _CONFIGURE_MAXIMUM_PROCESSORS >= 11
- #endif
- #if _CONFIGURE_MAXIMUM_PROCESSORS >= 12
- #endif
- #if _CONFIGURE_MAXIMUM_PROCESSORS >= 13
- #endif
- #if _CONFIGURE_MAXIMUM_PROCESSORS >= 14
- #endif
- #if _CONFIGURE_MAXIMUM_PROCESSORS >= 15
- #endif
- #if _CONFIGURE_MAXIMUM_PROCESSORS >= 16
- #endif
- #if _CONFIGURE_MAXIMUM_PROCESSORS >= 17
- #endif
- #if _CONFIGURE_MAXIMUM_PROCESSORS >= 18
- #endif
- #if _CONFIGURE_MAXIMUM_PROCESSORS >= 19
- #endif
- #if _CONFIGURE_MAXIMUM_PROCESSORS >= 20
- #endif
- #if _CONFIGURE_MAXIMUM_PROCESSORS >= 21
- #endif
- #if _CONFIGURE_MAXIMUM_PROCESSORS >= 22
- #endif
- #if _CONFIGURE_MAXIMUM_PROCESSORS >= 23
- #endif
- #if _CONFIGURE_MAXIMUM_PROCESSORS >= 24
- #endif
- #if _CONFIGURE_MAXIMUM_PROCESSORS >= 25
- #endif
- #if _CONFIGURE_MAXIMUM_PROCESSORS >= 26
- #endif
- #if _CONFIGURE_MAXIMUM_PROCESSORS >= 27
- #endif
- #if _CONFIGURE_MAXIMUM_PROCESSORS >= 28
- #endif
- #if _CONFIGURE_MAXIMUM_PROCESSORS >= 29
- #endif
- #if _CONFIGURE_MAXIMUM_PROCESSORS >= 30
- #endif
- #if _CONFIGURE_MAXIMUM_PROCESSORS >= 31
- #endif
- #if _CONFIGURE_MAXIMUM_PROCESSORS >= 32
- #endif
- #undef _CONFIGURE_SCHEDULER_ASSIGN
- #endif
- RTEMS_STATIC_ASSERT(
- _CONFIGURE_MAXIMUM_PROCESSORS
- == RTEMS_ARRAY_SIZE( _Scheduler_Initial_assignments ),
- _Scheduler_Initial_assignments
- #endif
-#endif
-/**@}*/ /* end of Scheduler Configuration */
* @defgroup ConfigurationMalloc RTEMS Malloc configuration
@@ -2129,23 +1695,6 @@ struct _reent *__getreent(void)
#endif
#endif /* !defined(RTEMS_SCHEDSIM) */
- * Validate the configured maximum priority
-#if ((CONFIGURE_MAXIMUM_PRIORITY != 3) && \
- (CONFIGURE_MAXIMUM_PRIORITY != 7) && \
- (CONFIGURE_MAXIMUM_PRIORITY != 15) && \
- (CONFIGURE_MAXIMUM_PRIORITY != 31) && \
- (CONFIGURE_MAXIMUM_PRIORITY != 63) && \
- (CONFIGURE_MAXIMUM_PRIORITY != 127) && \
- (CONFIGURE_MAXIMUM_PRIORITY != 255))
- #error "Maximum priority is not 1 less than a power of 2 between 4 and 256"
-#endif
-#if (CONFIGURE_MAXIMUM_PRIORITY > PRIORITY_DEFAULT_MAXIMUM)
- #error "Maximum priority configured higher than supported by target."
-#endif
* POSIX Key pair shouldn't be less than POSIX Key, which is highly
* likely to be error.
diff --git a/cpukit/include/rtems/confdefs/scheduler.h b/cpukit/include/rtems/confdefs/scheduler.h
new file mode 100644
index 0000000000..12f7c631fa
--- /dev/null
+++ b/cpukit/include/rtems/confdefs/scheduler.h
@@ -0,0 +1,370 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * @file
+ * @ingroup RTEMSApplicationConfiguration
+ * @brief Evaluate Scheduler Configuration Options
+#ifndef _RTEMS_CONFDEFS_SCHEDULER_H
+#define _RTEMS_CONFDEFS_SCHEDULER_H
+#ifndef __CONFIGURATION_TEMPLATE_h
+#error "Do not include this file directly, use <rtems/confdefs.h> instead"
+#endif
+#ifdef CONFIGURE_INIT
+#include <rtems/confdefs/percpu.h>
+#if !defined(CONFIGURE_SCHEDULER_CBS) \
+ && !defined(CONFIGURE_SCHEDULER_EDF) \
+ && !defined(CONFIGURE_SCHEDULER_EDF_SMP) \
+ && !defined(CONFIGURE_SCHEDULER_PRIORITY) \
+ && !defined(CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP) \
+ && !defined(CONFIGURE_SCHEDULER_PRIORITY_SMP) \
+ && !defined(CONFIGURE_SCHEDULER_SIMPLE) \
+ && !defined(CONFIGURE_SCHEDULER_SIMPLE_SMP) \
+ && !defined(CONFIGURE_SCHEDULER_STRONG_APA) \
+ && !defined(CONFIGURE_SCHEDULER_USER)
+ #if defined(RTEMS_SMP) && _CONFIGURE_MAXIMUM_PROCESSORS > 1
+ #define CONFIGURE_SCHEDULER_EDF_SMP
+ #else
+ #define CONFIGURE_SCHEDULER_PRIORITY
+ #endif
+#endif
+#include <rtems/scheduler.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+#ifndef CONFIGURE_MAXIMUM_PRIORITY
+ #define CONFIGURE_MAXIMUM_PRIORITY PRIORITY_DEFAULT_MAXIMUM
+#endif
+#if CONFIGURE_MAXIMUM_PRIORITY != 3 \
+ && CONFIGURE_MAXIMUM_PRIORITY != 7 \
+ && CONFIGURE_MAXIMUM_PRIORITY != 15 \
+ && CONFIGURE_MAXIMUM_PRIORITY != 31 \
+ && CONFIGURE_MAXIMUM_PRIORITY != 63 \
+ && CONFIGURE_MAXIMUM_PRIORITY != 127 \
+ && CONFIGURE_MAXIMUM_PRIORITY != 255
+ #error "CONFIGURE_MAXIMUM_PRIORITY must be one of 3, 7, 15, 31, 63, 127, and 255"
+#endif
+#if CONFIGURE_MAXIMUM_PRIORITY > PRIORITY_DEFAULT_MAXIMUM
+ #error "CONFIGURE_SCHEDULER_PRIORITY must be less than or equal to the architecture defined maximum priority"
+#endif
+#ifdef CONFIGURE_SCHEDULER_PRIORITY
+ #ifndef CONFIGURE_SCHEDULER_NAME
+ #define CONFIGURE_SCHEDULER_NAME rtems_build_name( 'U', 'P', 'D', ' ' )
+ #endif
+ #ifndef CONFIGURE_SCHEDULER_TABLE_ENTRIES
+ #define CONFIGURE_SCHEDULER \
+ RTEMS_SCHEDULER_PRIORITY( \
+ dflt, \
+ CONFIGURE_MAXIMUM_PRIORITY + 1 \
+ #define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
+ RTEMS_SCHEDULER_TABLE_PRIORITY( dflt, CONFIGURE_SCHEDULER_NAME )
+ #endif
+#endif
+#ifdef CONFIGURE_SCHEDULER_PRIORITY_SMP
+ #define CONFIGURE_SCHEDULER_NAME rtems_build_name( 'M', 'P', 'D', ' ' )
+ #endif
+ RTEMS_SCHEDULER_PRIORITY_SMP( \
+ dflt, \
+ RTEMS_SCHEDULER_TABLE_PRIORITY_SMP( dflt, CONFIGURE_SCHEDULER_NAME )
+ #endif
+#endif
+#ifdef CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP
+ #define CONFIGURE_SCHEDULER_NAME rtems_build_name( 'M', 'P', 'A', ' ' )
+ #endif
+ RTEMS_SCHEDULER_PRIORITY_AFFINITY_SMP( \
+ dflt, \
+ RTEMS_SCHEDULER_TABLE_PRIORITY_AFFINITY_SMP( \
+ dflt, \
+ CONFIGURE_SCHEDULER_NAME \
+ #endif
+#endif
+#ifdef CONFIGURE_SCHEDULER_STRONG_APA
+ #define CONFIGURE_SCHEDULER_NAME rtems_build_name( 'M', 'A', 'P', 'A' )
+ #endif
+ RTEMS_SCHEDULER_STRONG_APA( \
+ dflt, \
+ RTEMS_SCHEDULER_TABLE_STRONG_APA( dflt, CONFIGURE_SCHEDULER_NAME )
+ #endif
+#endif
+#ifdef CONFIGURE_SCHEDULER_SIMPLE
+ #define CONFIGURE_SCHEDULER_NAME rtems_build_name( 'U', 'P', 'S', ' ' )
+ #endif
+ #define CONFIGURE_SCHEDULER RTEMS_SCHEDULER_SIMPLE( dflt )
+ RTEMS_SCHEDULER_TABLE_SIMPLE( dflt, CONFIGURE_SCHEDULER_NAME )
+ #endif
+#endif
+#ifdef CONFIGURE_SCHEDULER_SIMPLE_SMP
+ #define CONFIGURE_SCHEDULER_NAME rtems_build_name( 'M', 'P', 'S', ' ' )
+ #endif
+ RTEMS_SCHEDULER_SIMPLE_SMP( dflt )
+ RTEMS_SCHEDULER_TABLE_SIMPLE_SMP( dflt, CONFIGURE_SCHEDULER_NAME )
+ #endif
+#endif
+#ifdef CONFIGURE_SCHEDULER_EDF
+ #define CONFIGURE_SCHEDULER_NAME rtems_build_name( 'U', 'E', 'D', 'F' )
+ #endif
+ #define CONFIGURE_SCHEDULER RTEMS_SCHEDULER_EDF( dflt )
+ RTEMS_SCHEDULER_TABLE_EDF( dflt, CONFIGURE_SCHEDULER_NAME )
+ #endif
+#endif
+#ifdef CONFIGURE_SCHEDULER_EDF_SMP
+ #define CONFIGURE_SCHEDULER_NAME rtems_build_name( 'M', 'E', 'D', 'F' )
+ #endif
+ #define CONFIGURE_SCHEDULER RTEMS_SCHEDULER_EDF_SMP( dflt )
+ RTEMS_SCHEDULER_TABLE_EDF_SMP( dflt, CONFIGURE_SCHEDULER_NAME )
+ #endif
+#endif
+#ifdef CONFIGURE_SCHEDULER_CBS
+ #define CONFIGURE_SCHEDULER_NAME rtems_build_name( 'U', 'C', 'B', 'S' )
+ #endif
+ #define CONFIGURE_SCHEDULER RTEMS_SCHEDULER_CBS( dflt )
+ RTEMS_SCHEDULER_TABLE_CBS( dflt, CONFIGURE_SCHEDULER_NAME )
+ #endif
+ #ifndef CONFIGURE_CBS_MAXIMUM_SERVERS
+ #define CONFIGURE_CBS_MAXIMUM_SERVERS CONFIGURE_MAXIMUM_TASKS
+ #endif
+ const uint32_t _Scheduler_CBS_Maximum_servers =
+ CONFIGURE_CBS_MAXIMUM_SERVERS;
+ Scheduler_CBS_Server
+ _Scheduler_CBS_Server_list[ CONFIGURE_CBS_MAXIMUM_SERVERS ];
+#endif
+ CONFIGURE_SCHEDULER;
+#endif
+const Scheduler_Control _Scheduler_Table[] = {
+ CONFIGURE_SCHEDULER_TABLE_ENTRIES
+#define _CONFIGURE_SCHEDULER_COUNT RTEMS_ARRAY_SIZE( _Scheduler_Table )
+#ifdef RTEMS_SMP
+const size_t _Scheduler_Count = _CONFIGURE_SCHEDULER_COUNT;
+const Scheduler_Assignment _Scheduler_Initial_assignments[] = {
+ #ifdef CONFIGURE_SCHEDULER_ASSIGNMENTS
+ CONFIGURE_SCHEDULER_ASSIGNMENTS
+ #else
+ #define _CONFIGURE_SCHEDULER_ASSIGN \
+ RTEMS_SCHEDULER_ASSIGN( \
+ 0, \
+ RTEMS_SCHEDULER_ASSIGN_PROCESSOR_OPTIONAL \
+ _CONFIGURE_SCHEDULER_ASSIGN
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 2
+ , _CONFIGURE_SCHEDULER_ASSIGN
+ #endif
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 3
+ #endif
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 4
+ #endif
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 5
+ #endif
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 6
+ #endif
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 7
+ #endif
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 8
+ #endif
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 9
+ #endif
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 10
+ #endif
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 11
+ #endif
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 12
+ #endif
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 13
+ #endif
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 14
+ #endif
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 15
+ #endif
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 16
+ #endif
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 17
+ #endif
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 18
+ #endif
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 19
+ #endif
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 20
+ #endif
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 21
+ #endif
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 22
+ #endif
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 23
+ #endif
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 24
+ #endif
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 25
+ #endif
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 26
+ #endif
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 27
+ #endif
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 28
+ #endif
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 29
+ #endif
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 30
+ #endif
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 31
+ #endif
+ #if _CONFIGURE_MAXIMUM_PROCESSORS >= 32
+ #endif
+ #undef _CONFIGURE_SCHEDULER_ASSIGN
+ #endif
+RTEMS_STATIC_ASSERT(
+ _CONFIGURE_MAXIMUM_PROCESSORS
+ == RTEMS_ARRAY_SIZE( _Scheduler_Initial_assignments ),
+ _Scheduler_Initial_assignments
+#endif /* RTEMS_SMP */
+#ifdef __cplusplus
+#endif
+#endif /* CONFIGURE_INIT */
+#endif /* _RTEMS_CONFDEFS_SCHEDULER_H */
2.16.4
