[PATCH v2 25/44] config: Add <rtems/confdefs/bsp.h>
Sebastian Huber
Fri Feb 21 10:52:37 UTC 2020
Remove all comments and copyrightable content from the moved content.
Use BSD-2-Clause license for new file.
Update #3053.
Update #3875.
cpukit/headers.am | 1 +
cpukit/include/rtems/confdefs.h | 14 +--------
cpukit/include/rtems/confdefs/bsp.h | 60 +++++++++++++++++++++++++++++++++++++
3 files changed, 62 insertions(+), 13 deletions(-)
create mode 100644 cpukit/include/rtems/confdefs/bsp.h
diff --git a/cpukit/headers.am b/cpukit/headers.am
index 658444cf9e..9f736e0c87 100644
--- a/cpukit/headers.am
+++ b/cpukit/headers.am
@@ -183,6 +183,7 @@ include_rtems_HEADERS += include/rtems/userenv.h
include_rtems_HEADERS += include/rtems/version.h
include_rtems_HEADERS += include/rtems/vmeintr.h
include_rtems_HEADERS += include/rtems/watchdogdrv.h
+include_rtems_confdefs_HEADERS += include/rtems/confdefs/bsp.h
include_rtems_confdefs_HEADERS += include/rtems/confdefs/libpci.h
include_rtems_confdefs_HEADERS += include/rtems/confdefs/obsolete.h
include_rtems_debugger_HEADERS += include/rtems/debugger/rtems-debugger-bsp.h
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index b2a10902e4..eca210190c 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -51,23 +51,11 @@
#include <rtems/posix/shm.h>
#include <rtems/posix/timer.h>
#include <rtems/confdefs/obsolete.h>
+#include <rtems/confdefs/bsp.h>
#include <rtems/confdefs/libpci.h>
#include <limits.h>
-#ifdef CONFIGURE_DISABLE_BSP_SETTINGS
- #undef BSP_DEFAULT_UNIFIED_WORK_AREAS
- #undef BSP_IDLE_TASK_BODY
- #undef BSP_IDLE_TASK_STACK_SIZE
- #undef BSP_INITIAL_EXTENSION
- #undef BSP_INTERRUPT_STACK_SIZE
- #undef BSP_MAXIMUM_DEVICES
- #undef CONFIGURE_BSP_PREREQUISITE_DRIVERS
- #undef CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK
-#else
- #include <bsp.h>
-#endif
#ifdef RTEMS_NEWLIB
#include <sys/reent.h>
#endif
diff --git a/cpukit/include/rtems/confdefs/bsp.h b/cpukit/include/rtems/confdefs/bsp.h
new file mode 100644
index 0000000000..7dab15a472
--- /dev/null
+++ b/cpukit/include/rtems/confdefs/bsp.h
@@ -0,0 +1,60 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2013 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * @file
+ * @ingroup RTEMSApplicationConfiguration
+ * @brief Evaluate BSP Related Configuration Options
+#ifndef _RTEMS_CONFDEFS_BSP_H
+#define _RTEMS_CONFDEFS_BSP_H
+#ifndef __CONFIGURATION_TEMPLATE_h
+#error "Do not include this file directly, use <rtems/confdefs.h> instead"
+#endif
+#ifdef CONFIGURE_INIT
+#ifdef CONFIGURE_DISABLE_BSP_SETTINGS
+ #undef BSP_DEFAULT_UNIFIED_WORK_AREAS
+ #undef BSP_IDLE_TASK_BODY
+ #undef BSP_IDLE_TASK_STACK_SIZE
+ #undef BSP_INITIAL_EXTENSION
+ #undef BSP_INTERRUPT_STACK_SIZE
+ #undef BSP_MAXIMUM_DEVICES
+ #undef CONFIGURE_BSP_PREREQUISITE_DRIVERS
+ #undef CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK
+#else
+ #include <bsp.h>
+#endif
+#endif /* CONFIGURE_INIT */
+#endif /* _RTEMS_CONFDEFS_BSP_H */
2.16.4
